Some people claimed that the Wally may work connected to port 2 on the Hybrid LNB but I never tried it?
I'm thinking your hybrid ea lnb with a duo hub should run both receivers.
Sent from my Pixel 2 XL using the SatelliteGuys app!
A Hopper 3 and a Wally on one Hybrid LNB? I'm thinking it won't. In fact, I know it won't.
Why? I'd be willing to bet it would. I've pre downloaded wallys on my hybrid lnb at home. And 722's... I know for a fact that ANY single receiver will run on a hybrid lnb. I download two hopper slings at the same time on my hybrid lnb at home.
Wish I could like more than once.Yup, all those receivers work just like you say on a Hybrid LNB but if you connect a Hopper 3 to port #1 on a Hybrid LNB then port #2 is disabled. I'll take any bet on this that you want to make as I have tried it in the past and I just tried it again this afternoon to be absolutely positive before I responded to your post.
And like I said earlier, if you run two lines into a DUO HUB, you can run TWO HOPPER 3's off that one hybrid lnb. I'm fully aware without the hub, port two gets disabled.Yup, all those receivers work just like you say on a Hybrid LNB but if you connect a Hopper 3 to port #1 on a Hybrid LNB then port #2 is disabled. I'll take any bet on this that you want to make as I have tried it in the past and I just tried it again this afternoon to be absolutely positive before I responded to your post.
Because a Hopper 3 disables port 2 which is why you need a DPP LNB and a 42 switch for 2 Hopper 3's.Why? I'd be willing to bet it would. I've pre downloaded wallys on my hybrid lnb at home. And 722's... I know for a fact that ANY single receiver will run on a hybrid lnb. I download two hopper slings at the same time on my hybrid lnb at home.
Limited time offer
