100 hours of shows I been meaning to watch...feels like it did when I had a EHD fail. LoLAs someone that has switched from 211k's to Wallys I can say for a fact that when you switch the Wally will reformat the EHD.
I hoope so, since I live in an EA market and innstall them all the time.Got my wally today. Will it work fine with a eastern arc? I'm having issues aquiring a signal..... : /
I picture finally.![]()
Ok. Thanks. Updating now.Be sure and do a manual update. Go to "Settings", "Diagnostics", "Tools". You should end up with Software U448 from 12/12/2018.
Which remote you have??? And yes, they're used in RV's tooOk. Thanks. Updating now.
I have real nice remote. It has voice commands I believe I haven't messed with it yet.Which remote you have??? And yes, they're used in RV's too
54. When you're done updating, hit Home, go to Settings, TV - Click on Pair TV Wizard, put in your Make of TV, it'll do a scan, then check the Volume. If it works, hit Save and the remote will work your TV. If you have AV, do the same thing for Auxiliary Device. A sound bar is an Audio Accessory and a Receiver is, obviously, an Audio Receiver. After it scans, you have to press the AUX button on the side, then check the volume. If it works, hit SAT on the side and save it, then scroll down further and change Default Volume and Mute to Auxiliary Device.I have real nice remote. It has voice commands I believe I haven't messed with it yet.
Thanks for your help.54. When you're done updating, hit Home, go to Settings, TV - Click on Pair TV Wizard, put in your Make of TV, it'll do a scan, then check the Volume. If it works, hit Save and the remote will work your TV. If you have AV, do the same thing for Auxiliary Device. A sound bar is an Audio Accessory and a Receiver is, obviously, an Audio Receiver. After it scans, you have to press the AUX button on the side, then check the volume. If it works, hit SAT on the side and save it, then scroll down further and change Default Volume and Mute to Auxiliary Device.
After that, back out, go to TV, set your resolution, drop down to Screen Size and adjust it so the green circle fit into the corners.
Also, you need a USB WiFi Adapter or direct Ethernet connection for Voice and the apps to workThanks for your help.
USB wifi adapter on its way then everything will work. This receiver is a lot nicer than the old VIP211k and a lot smaller.Also, you need a USB WiFi Adapter or direct Ethernet connection for Voice and the apps to work
When I was calling to get it activated they asked if I lived in a RV ..odd question....are these for RV use?
Yep, it's a dual tuner.Just noticed on the Wally I can record two shows on different channels at the same time.![]()
Limited time offer
