My 55" LG OLED mated to a Hopper 3 picture is awesome.
Ditto.. Got the 65" OLED Ultra 4K and the picture is awesome with the hopper 3.
Worth every penny of that $3k I sunk into it!
Bring on CFB!!!
It looks good to you. That's what matters. However, it doesn't look like the picture is supposed to look. Vivid is going to be the furthest from what it should be than any other mode (very over-saturated colors).Relax, it looks really good on my tv with only minor adjustments.
I really wish people would stop pointing a finger at Dish's "compression" every time someone complains about their picture. That's hogwash. I have dish and when I can read the lettering on a golfball on a Sunday afternoon on my 56" Vizio believe me Dish's compression is not an issue and never has been. With any of these modern 4K TV's if you have a bad picture it's one of two things; a bad TV or incorrect settings. Did my Vizio have a great picture right out of the box? Uh, no, I had to spend some time tweaking the settings to achieve the best image and Dish's compression had/has nothing to do with it.
Thank you. This is what I believe too. Especially since I used the split screen feature to compare the ota version of ABC against the satellite version of ABC while watching Agents of Shield a few months ago. The sat version had noise in the backgrounds and looked worse to me during dark scenes. This show has a lot of dark scenes so it was easy to duplicate the poor picture quality. The ota version looked clear and no noticeable pixelation or noise in the picture.I disagree 100 percent. The difference between an OTA local and dish local is very obvious to me. Major additional compression. It may look ok on static images but motion causes lots of problems. Static black backgrounds on TV shows are also a mess.
In the end everyone sees things differently and values different aspects of picture quality.
Sent from my Pixel using Tapatalk
If you can read the lettering on a golf ball, that's a fairly static shot. It would take a LOT of compression to lose the quality. However, look at a detailed frame with a lot of motion. Even a moderate amount of compression will mess up the picture.I really wish people would stop pointing a finger at Dish's "compression" every time someone complains about their picture. That's hogwash. I have dish and when I can read the lettering on a golfball on a Sunday afternoon on my 56" Vizio believe me Dish's compression is not an issue and never has been. With any of these modern 4K TV's if you have a bad picture it's one of two things; a bad TV or incorrect settings. Did my Vizio have a great picture right out of the box? Uh, no, I had to spend some time tweaking the settings to achieve the best image and Dish's compression had/has nothing to do with it.
I still contend that not all OTA channels are created equal, and can have varying amounts of compression as well
Compared to high-bandwidth OTA, sure Dish PQ is inferior. Compared to Over-stuffed sub-channel OTA, DirecTV, or my local cable company (Spectrum), Dish looks just as good.
And DISH looks better than Spectrum.![]()
Did anyone say otherwise?I still contend that not all OTA channels are created equal, and can have varying amounts of compression as well
I got the impression that some were saying that OTA was always superior.Did anyone say otherwise?
It's going to be a rare situation where the Dish signal of an OTA signal is going to look better than the OTA signal itself.I got the impression that some were saying that OTA was always superior.
Limited time offer
