My previous timer gives me an error and I had to make a new timer for Battlebots this coming Friday. This is the 3rd timer in 11 episodes.
Try a seek and record timer. It might be more reliable.Had to make yet another timer for the episode coming up, the 2 timers already made are both blank for episodes. Dish needs to get their act together.
Nevermind about Seek and Record. Seems Dish removed that functionality from what I've read.Try a seek and record timer. It might be more reliable.
It certainly isn't easy but it can be done. (manually, I do not know how. I bet someone else does)Nevermind about Seek and Record. Seems Dish removed that functionality from what I've read.
Another reason for me to keep my ViP.
You can do it if the show has program info. This week's Battlebots does and I made a timer to record all of them on any channel but it doesn't matter because if that entry gets wiped out, the timer will show no programs. Last week, I was unable to make that timer because all entries were for the science Channel which I don't have, I'm watching on discovery. It's the guide that keeps getting screwed up, there is no timer that will record a show if the show has no entry in the guide. And even if it does, it might not record anyway.It certainly isn't easy but it can be done. (manually, I do not know how. I bet someone else does)
Last night I am watching a program when a promo ran for a show called "Carter" on TBS. Now I almost never watch TBS, but this promo showed that the star was Jerry O'Connell whom I've like since Sliders. So I go to the guide, ring up TBS and forward to the first airing of the show. I click the red 'record' button and it gives the normal choice of "This show" or "This series". But I notice that, just below the show's description, is a separate box that says [something like] Record All. I decided to peek at that and it says [again, something like] "Record 'Carter' across all times and channels". So we know you can get a search and record, now lets figure out how to do it manually and easily.
I will check tonight. Between your and wormil's response, it seems it might be easy to create a search and record timer. Maybe once that has happened, you can hit 'edit timer' and make the entry some truncated thing like "Battlebot". I know I missed some recordings when "Endeavour" was changed to "Endeavour on Masterpiece". Grrrrr.But can you search for partial names like I can with Dish Pass?
I currently have a Dish Pass timer set to search for "Battlebot" (no "s") in the title, and have recorded every new instance even when the show title changed last week.
Did you get a chance to try that out?I will check tonight. Between your and wormil's response, it seems it might be easy to create a search and record timer. Maybe once that has happened, you can hit 'edit timer' and make the entry some truncated thing like "Battlebot". I know I missed some recordings when "Endeavour" was changed to "Endeavour on Masterpiece". Grrrrr.
Yes. Editing did not allow me to go into the title and change it. But it's GOT to be there somewhere.Did you get a chance to try that out?
Limited time offer
