54.0 Volume Control | SatelliteGuys.US
54.0 Volume Control
rodder
2,351
105
Adairsville,Ga 30103
I have the Hopper Dou with 54.0 remote are there any way to adjust the volume control
since i have got this receiver when i change volume up are down it jumps 2 number's on
my LG sound bar say if i want to go from 10 to 11 it goes to 12 it dose not do it with
the lg remote are a Harmony remote
Ever since DISH started using the carbon user interface I have never been able to get learning to work.
That's weird. For my old HD TV (Trutech) none of the regular codes would work, so I had to use the learning function to program every button on my 54.0 to get it to work with that TV. I even used the learning function on another 54.0 to copy those commands from the first 54.0 to the second one.
U521?
