I don't think so. Those SR numbers, just like the frequency, are often off by 1 or 2mine shows 11760 H 30001 not 30000 could this be a reason?
A few weeks ago, I was watching the CNN feeds on 22W and I was also able to receive Telstar 12 @15W. But now the leaves have appeared on the trees, and I no longer get any of that. Likewise I will probably lose most of the C-Band west of 113W. But hey at least i was able to put away the snow shovel... And by December they will come back, and so will the snow shovel...I really think it has to do with my tree problem and line of site.
Mines on ku 6159 v 30000..Can anyone get cozi on 103 or is that toast?
What is your LNB L.O. setting in your menu. Your L.O. should be 10750Mines on ku 6159 v 30000..
5150-13515What is your LNB L.O. setting in your menu. Your L.O. should be 10750
Lol, ok. On thing miasong is nbc on 105, i have chs that sites dont list. Just like i cannot get 120cm sigs on 80 cm BUT I do. 125w is via a 24" with nothing missing or not working. Every single site azimuth, skew, elevation is off too. Between 3 birds i get 60 chs. Fta english. .105 i see the ch in list but no audio/video. They are avenger lnbs. 221 or 421 have to look. Not bashing just pointing things out.. Seller of my stb said this site was a bad site, missleading and part of why cband died.The receiver LO must match the LNB LO to display the correct transponder frequency. Services will not be missing if the correct LO frequency is entered in the receiver. Some transponders may be missed if the LO is not correctly set.
If the incorrect LO setting is used, incorrect frequencies will be logged. These logged frequencies will not match those listed on satellite service sites such as Lyngsat or Sathint, other hobbyists will not have any idea what transponder you are receiving and you will be unable to input missing transponders that may not be automatically logged.
There aren't such a LO settings as 5150-13515 or 9150-10750. Something is wrong with the receiver LO settings.
What brand and model LNB are you using?
...or someone that is just disgruntled.The seller of your STB is likely a disgruntled bootlegger who was banned from this site for posting about hacker boxes.
Limited time offer
