All Dish Network signals are digital.
Satellite internet requires it's own separate dish, electronics and wiring.
I would invest in a Super Buddy Satellite meter. If you travel that much and make decent money, I'm guessing you do, a few hundred bucks will go a long way. You can enter your zip code to set the meter to the proper settings, for one thing. Also, you should have the mast on that temp mount so the "elbow" is over the center of the mount, not pointing to the outside edge. Keeps the weight centered, plus you can pull the center bolt and fold the mast down when not in use.
It's a completely different dish, bigger, heavier pointing at a completely different SatelliteI thought Hues net said they could run off the dish.
Dish offers internet also, why would they make you have another satellite I wonder. I'll have to look into that. Thanks for posting though.
Maine - Elevation 20
Florida - Elevation 38
Elevation is important.
Even on a short day, we cover more than 60 miles.Now we talking for completely different things, if you are moving 1000 miles away the elevation need to be adjusted as well. I am talking for 50-60 miles moves.
Now we talking for completely different things, if you are moving 1000 miles away the elevation need to be adjusted as well. I am talking for 50-60 miles moves...
About the SuperBuddy how HipKat set you can enter the zip code and see the proper sku and elevation and when you lock to satellite there is a ID button to verify that you are at the right satellite.
Huh?? The Super Buddy is for almost any kind've Dish, including DTV dishesThe Super Buddy 29 is for a Hybrid dish for the Hopper 3. If using a non-hybrid dish, there are other good meters like the Acutrac 22 Pro and the First Strike FS-1 that cost a lot less.
I meant that a Hybrid LNBF disk requires a Super Buddy 29. It will handle all Dish dishes as well as others.Huh?? The Super Buddy is for almost any kind've Dish, including DTV dishes
Satelite recieverWhat do you mean by Decoder?
Hi...has anybody experienced full signal on the satfinder, but then no signal on the decoder. However if you connect the satfinder in series with decoder, all works fine with full signal...
Limited time offer
