Newest live TV bandscan | SatelliteGuys.US
That you're getting 100% signal on frequencies that are theoretically unused gives a big boost to my suspicion about the HDHomerun tuners being unsuitable for relative signal strength numbers. There may be some TV frequencies being used for other purposes, but not that many.
It's not signal strength that I'm concerned about when fine tuning a signal; it's signal quality. The live bandscan metric shows this as "Curr MER."
I've found this method to be best for aiming an OTA antenna for distant stations, as I cannot afford an expensive professional meter.
I've found that signals from the same source register differently on each HD Home Run receiver. There's no way to compare signals from one unit to another.
The newer receivers have better receivers and reject multipath better, but the signal display seems worse that the older models.
KTFQ DT has bumped Charge! for Stadium sport TV network
Cutting The Cord And Looking For Help
