Wiring diagram for 2 Hopper 3 and 6 Joey | SatelliteGuys.US
Gabe Paul
30
25
Gilroy, CA
The installation rep is at my home now. He has never installed a 2- Hopper 3 system, and can't find a wiring diagram. Also what type of dish would he use? Can anyone send me a wiring diagram. Thanks.
Reactions: dennispap
My install is Western Arc. Don't know what is used in CA.
He is WA. Your setup is specifically for use with the 118 satellite. If he is the usual setup. 110, 119 ,and 129, he will need a hybrid LNB and 2 solo hybrid hubs. If the installer uses a 42 switch, he can use the existing LNBs along with the 2 solo hybrid hubs.
Reactions: charlesrshell
I did not know you can run two Hopper 3s with one dish and no DPH42 switch.
Reactions: pattykay
The installer used a "42" switch and two hybrid hubs. Not sure what type of LNB he used, but he had to change it from the original one he used. System works great. 16 years with DTV and really like the Hopper 3 and Joeys. They all are very fast. Hardware is much better than DTV and image quality is equal or better than DTV.
Hopper 3/Joey 4k 10/19 Update Alexa & Voice Issues
Why no new competitor equipment upgrades?
Who Read This Thread (Total Members: 10)
