I normally used 73(cable), looks like the rf quality has drop, i might be wrongIf you haven't, change the modulator to cable and put TV to channel 73, many times that will clear up a bad picture.
Well I tried. Enjoy your VIP receiver till they pry it from your cold,dead hands.Nope. Those HDMI to component adapters usually produce sub-par picture, plus many times the HDCP blocks recording. Plus with only one HDMI output, I'd have to have the recorder and the adapter powered on all the time to pass through the video to the TV. HDMI to TV and a separate component signal to the recorder solves all those issues.
FYI, I'm not talking composite SD recording (like the mentioned DVD recorder), I'm talking component HD recording.
I tried not to correct you guys, but it's driving me crazy. It's a composite output!
Wally and Joey have no component outputs. Hopper has them.I'm losing the train of this conversation. Which receiver has no component outputs? Wally? Joey? Hopper?
Wally has that. (yellow, white, red RCA output) The discussion was about what the Wally does not have. (red, blue, green component video output)I tried not to correct you guys, but it's driving me crazy. It's a composite output!
Also, to round out the Hopper compatible equipment, the 211k has them, the 211z does not.Wally and Joey have no component outputs. Hopper has them.
Also the 211 has component output.Also, to round out the Hopper compatible equipment, the 211k has them, the 211z does not.
Exactly my point. Would you be able to do that now with deactivated more modern equipment? Or even play previously recorded DVR content?My deactivated 512 still records Perry Mason episodes from FETV just fine without any need for a pay-tv subscription.![]()
With a ViP? Yes, as long as it still has the purple G3 Smart Card, and has been kept connected to a satellite signal the entire time. It is the white G4 Smart Card that takes away the ability to watch and record free channels on deactivated equipment, and Flex Pack is the eye candy being used to lure customers to white G4 Smart Cards.Exactly my point. Would you be able to do that now with deactivated more modern equipment? Or even play previously recorded DVR content?
As far as I know, every Hopper came with a white G4 Smart Card, which is why I did not mention them.Good point, but I was referring to the "more modern" Hopper equipment. So those mocking my holding on to older equipment by equating it to analog cell phones just don't get it, and are already locked inside that windowless van. At least component gives me a window I can crawl out of, and I'm not just limited to free channels.
I don't have a white G4 Smart Card in my Hopper 3s. No cards at all.As far as I know, every Hopper came with a white G4 Smart Card, which is why I did not mention them.
That is new enough that the card is built-in, and it is at least a G4 card, if not newer. If you log into your online mydish account and see Flex Pack listed as an available option to switch to, then you have at least a G4.I don't have a white G4 Smart Card in my Hopper 3s. No cards at all.
Your Smart Cards are built in, so to speak. There is a slot for new ones, should the need ever arise, on the left side of the receiver. My original 722 was the same way. Dish sent me a new card and I slipped it into the empty slot.I don't have a white G4 Smart Card in my Hopper 3s. No cards at all.
Thanks. I see Flex Pack in my on line mydish account.That is new enough that the card is built-in, and it is at least a G4 card, if not newer. If you log into your online mydish account and see Flex Pack listed as an available option to switch to, then you have at least a G4.
I'll bet the 411 does likewise since it was basically a 211 w/o a network interface.
It is the carrot-and-the-stick approach. If Dish doesn't get you with the carrot (introducing new Hoppers (with new features) or new programming packages (that require the G4 card) to tempt you to switch) then they will get you with the stick (forcing you to replace your old equipment).Interesting. I had my 722 and both 612's fail one way or another and Dish replaced them. I am now on the white smart cards on all 3 receivers independently of the existence of Flex Pack.![]()
Limited time offer
