Carbon UI for Hopper2000 | Page 2 | SatelliteGuys.US
You're welcome. I can't see Dish doing that because if they did then customers with multiple Hopper 1's and 2's won't be able to share recordings between receivers, etc. That would be a mess.
One more thing you might try if you haven't. If you have another Hopper 1 or 2 then you might try connecting them on a MoCA network. The one with the old software might download the update from the CUI one.
I have to download a Hopper 1 in the next couple of days and I'll let you know what software it takes. We're on eastern arc 61.5 and 72 here but if it's still on this arc then it should still be on the western arc too.
Good luck.
I try the moca and leave it overnight, didn't work either
I just did a boot recovery on a previously downloaded not activated Hopper 2000 and it got U118 which is the latest CUI version. Eastern arc, 72 and 61.5.
Reactions: charlesrshell
Based on what JSheridan posted, it isn't true....
This was the post on the tech portal:
Re: Hopper 2k
by XXXXXXXXXXXXX » Mon Aug 07, 2017 8:12 am
There is work being done to speed up the UI on Hopper. While that it done we have stopped deploying new UI to Hopper.
Although to date, the CUI is still downloading to the H2K
Re: Hopper 2k
I can't log in to your link. Need your username and password please! :eeek
The Hooper I had never have any previous download software, there was no joey software on the drive either
Joey won't release tuner after use.
Wrong sat message
