Yes, the backlight is very nice.The backlight will come in handy.
I was surprised since the Apps and Search button are no longer there that DISH didn't add them to the Options menu.
Yep, I knew they are in the Menu list. I just thought it was strange DISH didn't put them in the Options list since they were buttons on the 52.0 remote.Instead of the Options button click Home twice, you'll find both Apps and Search there....
My 50.0 has an Apps button only. My 52.0 has both Apps and Search button.There a several remotes being used out there by Hopper users. The 40, the 50, the 52, and now the 54. The 40 doesn't have an Apps buttonor an Options button, the 50 has both Apps and Search buttons, the 52 has an Apps button but not a Search button. The 54 has neither. Both Apps and Search have always been in the Menu List. If you moved Apps and Search to Options you have a real problem because the folks using the 40, and there are many, don't have an Options button to go to. Those using the 50 or 52 would have to be retrained to find Apps and Search in a different area than they were used to.
... the Hopper about five minutes later. It does this with the remote control HDMI-CEC setting turned on or off.
Yes, I saw that. You would think the Hopper would just turn back on instead of a shut down clock.That delay appears to be by design. If you turn the TV itself back on while the Hopper is in that state, you'll see a countdown clock prior to it shutting down.
While the blue button on the 40 remote will get you most of the apps available it doesn't give you all of them.The blue button on the 40 is the Apps button
IC, thanks. Well, I guess that is a good idea and could come in handy.That keeps the buffers going just in case you didn't mean to turn things off.![]()
Since forever, check it out for yourself. With blue button I count 12 tiles. Going to Menu, Apps, I count 19 tiles....Since when?
I think with the 40.0 Blue Button method if you scroll up or down there is more Apps.Since forever, check it out for yourself. With blue button I count 12 tiles. Going to Menu, Apps, I count 19 tiles....
Limited time offer
