USB port on 4K Joey | SatelliteGuys.US
USB port on 4K Joey
Disconnect the coax then plugin the adapter in for starters you should have instructions on the tv screen, if that's not it put the coax back on then plug in the adapter and look at the screen it should tell you what's going on. reply back I'm curious now.:D
I'm willing to try it. I have a Dish wifi adapter. How do I connect it to my Hopper wirelessly?
You can't connect directly to the Hopper but if the Hopper and the wireless adapter on the Joey are connected to your home network they should see each other. If you're trying this with a 4K Joey you would probably need a gigabit home network.
They are on the same network. I'll try it as soon as the Cardinals game is over ;)
Reactions: JSheridan
I can't get the 4K Joey to recognize the Dish wifi dongle. Granted, it's one I ordered for a Wally, but that should work right? It's the WNDA3100 v2
I'm fairly certain it would work over ethernet, but wireless would be cooler. Looks like Dish didn't load the wifi adapter drivers on the 4K Joeys.
If anybody wants me to try it over ethernet I will.
Hopper3, black screen, no audio, then reboots
Keep losing 72 and 61.5, 77 still good
