High Desert Reception | SatelliteGuys.US
Sandia Sam
3
Santa Fe, NM
Hello. I'm currently a DISH subscriber at my home. I've got a studio space with no TV reception about 1/2 mile from my residence. I want to add a dish and HD receiver at the studio. Can I do this without having to create a second, separate account and pay DISH for the additional receiver monthly? Guidance appreciated. Thanks!
You could purchase a Wally and separate dish, with the Wally activated on your existing account. That would be similar to what non-fulltime RV'ers often do for service on the road or folks with a seasonal second home. An alternative might be using a Firestick with an existing HDMI equipped TV and the Dish Anywhere app if you have a Hopper with Sling at home and an unlimited or high data limit Internet service at home and the studio.
Reactions: bspei and pattykay
If you have line of sight from home to the studio, you might consider one of the high-power WiFi links. Some brands are Ubiquity and SimpleWiFi, but there are lots of others.
Once you had connectivity, you could use the FireStick or a plain old Joey. The Joey would carry a monthly cost. If you currently pay for an internet connection at the studio, you'd be able to shed that cost as well.
Reactions: TheKrell
Dutch, my internet signal is not very good 5 mbps. So a streaming device may not work well. I do LIKE your idea about using Wally. I'm looking into that.
Reactions: pattykay
The Ubiquity idea is awesome! Unfortunately the studio doesn't have line of sight to home. ;-(
The way the answer was explained, would be streaming in network for the firestick.
I can confirm that this works well. Set up a Fire stick in my daughter's bedroom and tested it last night with Dish Anywhere. Looks like 1080i picture quality over the local network. Wouldn't make a difference how fast the speed is from your ISP.
Reactions: TheKrell
I've had pretty good success streaming program content even at 2-3Mbps 3G speeds at times using a grey market $5/mo Verizon unlimited 3G data only Jetpack. We usually have much better speeds though, with our current $20/mo unlimited 4G/LTE data plan from AT&T's "Connected Car" program. So data limits don't mean much to us anymore. ;)
Reactions: comfortably_numb
I think the Wally and a separate dish would be the better option if you have poor Internet access, but also the most expensive of course.
Reactions: pattykay
Current App Logins Supported?
