Two Hopper 3 Install is Scheduled | Page 13 | SatelliteGuys.US
Something to do with the DHP42 switch. There's a way around it but one of the folks who've gotten (2) H3s in the past week would have to comment.
I think the required download can be done if the H3 is connected to a dish with Hybrid LNBs and Solo Hub. Then the H3 when connected to a DPH42 switch will work. But, I am not sure of all that.
That's accurate, or you can just use a hybrid LNB and no hub at all. :)
That's probably true. The problem is, my configuration doesn't have a Hybrid LNB in it.
I am really hijacking this thread now, is it true the old Hopper w/sling remote cannot be paired with the Hopper 3? If so, how can I restore my settings/timers?
Dish just did me a favor and swapped the H3. I do not have to return it. They will take it and not charge me for a new one.
Awesome, you give me ammo to call the DISH President office and see if they will credit my account a $100. Good job monroef. I sure didn't have any luck on my install.
Reactions: stardust3
Yes, the old HWS 40.0 remote can be paired to the Hopper 3. I have 11 of them paired to my Hopper 3 / Joey system. Don't let the technician take your old remotes.
Reactions: DWS44
Had a chance to try out the Hybrid Duo Hub. Both H3s, both 4KJs, & both WJs are working great. All can see either Hopper in the DVR Sources menu. I will see how goes it for any issues that might pop up.
That defiantly works. I added a second H3 from DishDepot, I connected it to a Hybrid LNBF and downloaded the latest firmware and activated it. Then hooked up the DPH switch. The installers should have a hybrid LNBF to hook to a Dish 1000 antenna to do this and then install the DPH42.
My DISH technician kind of knew that. The problem is there is no LNBF that will work on a 1000+ dish from my understanding of things. That is the one of the reasons for the development of the DPH42 switch.
Reactions: pattykay
Can you fix that cable that goes from the DHP42 (??) and over the 'node' (?) to the splitter ? The radius doesn't follow the inner cable's radius nicely and it bugs me !! :D:D:D
LOL, ok Hall, but not today. I am sick of that there f----- board and all this latest install experience. Going to sit back and enjoy my new Hopper 3 system. It has been so nice not having conflicts. The Hopper 3s sure run a lot better than the HWSs. :rolleyes
Audio and Video Intermittently Out of Sync
H371 update problem recording live event Golf
