Join the SatelliteGuys Folding@Home Team! | Page 221 | SatelliteGuys.US
You shouldn't have to do anything except replace the card. Do wait for the current work unit to finish as it won't transfer from one card to another. Curious, what card are you getting?
If you aren't running the latest Beta version of the client, I'd recommend updating to it. It seems to handle most of the more complicated GPU configurations a lot better than the 7.4.4 release. Also, It would be best to finish your GPU slot's WU before adding the new card, just to make sure you don't lose any work (and Science is preserved!) Edit: I see EatMyVolts already suggested that.
Reactions: DWS44
Where does one obtain the beta versions?
Side Note... The big brown truck delivered the new 1080 yesterday...Good God at the size of this thing! o_O
Looking forward to the quality time with my computer installing it this weekend! :hungry
Reactions: Foxbat
With over 930K points today, I'd hazard a guess DWS44 is liking his new 1080. That's one powerful card.
I'm inclined to agree with you:
But, I would also say the entire SatelliteGuys Team is also liking DWS44's new GTX 1080!
Hopefully we'll see the Top 50 before 2017 is over! Another 10 days should see us break 4,000,000,000 Points!
And, who knows? This time next year maybe the first of NVIDIA's Volta GPU Family boards will start showing up? They've already announced the GV100 Module like the GP100 a couple of years back. Twice the performance? That would be nice...
Anyone know if the newer drivers for the 1070 work correctly yet? I am still on 21.21.13.7653 for my drivers for the 1070.
I just updated to the latest Folding@HOME Beta. (I haven't updated in about 6 months)
The word on the FAH support forum is to still stay with 373.06 (which I believe translates to 21.21.13.7306). That version does support the 1070. Later versions give lower ppd. Step back to this earlier version any you should see more points, I know when I did they went up.
I'm using 373.06 on my Win10 machine (1070 & 970) and 370.28 on my Linux mint machine (1060).
Reactions: KE4EST
:yessign
Glad to help...SatGuys has helped me a ton over the years. :thumbup
Here's some geek porn from the swap:
System with old 670 / comparison shot of the 670 vs. 1080 / System with 1080 installed.
upload_2017-5-15_17-32-10.png upload_2017-5-15_17-27-21.png upload_2017-5-15_17-34-44.png
So far, the new card has been quite nice. The thing is impressively quiet, even with the large fans! The other nice benefit is my system is much snappier even with the FAH client running full steam. With the 670, regular browsing scrolling pages and the occasional video would lag a bit. With the 1080, hard to tell FAH is even running! :D
I moved the 670 to an older Dell XPS box I'd been running with a pair of 7900 GS cards. Interestingly, even in the older machine, the 670 is generating roughly the same PPD so far as it did in my newer primary box.
Now, that said... Let me post some info and see if y'all see anything I need to adjust. My process, I uninstalled the old FAH client after letting it finish the WUs it was processing Sat. morning. Shut down, swapped cards, fired back up, and installed the most recent NVIDIA driver, 382.05. Once the new card was up and running, I installed the beta version of the FAH client as Foxbat suggested. During the first 24 hours, it was generally reporting estimated PPD over 900K and seemed to be consistently generating close to that level. After about midday yesterday, though, seems like it got a little more sporadic, and since thenits only been estimating in the 750K PPD range. Check the stat table below. Even before the range shown below, I had been consistently over 100K per 3hr period from shortly after the install up to the oldest one shown below:
Between 3PM and 6PM yesterday, seems to be where the consistency started tailing off a bit. Maybe I'm putting too much stock in it too soon, just seemed to tail off a little after a strong first 24 hours.
Last thing I've noticed that seemed odd. Though the client clearly identifies the card as a GTX 1080 and is going to town with it, in the beta client, it shows "GPUs 0" in the System Info tab. (screenshots below) Should that be of it that indicative of a problem? My others machine, the Dell XPS with the old 670, (also beta client), shows "GPUs 1".
...and for good measure, here's the current log, if it tells you all anything:
Code:
******************************* Date: 2017-05-15 *******************************
04:35:55:WU02:FS00:0xa4:Completed 725000 out of 1250000 steps  (58%)
04:36:33:WU01:FS01:0x21:Completed 760000 out of 2000000 steps (38%)
04:38:32:WU01:FS01:0x21:Completed 780000 out of 2000000 steps (39%)
04:39:49:WU02:FS00:0xa4:Completed 737500 out of 1250000 steps  (59%)
04:40:32:WU01:FS01:0x21:Completed 800000 out of 2000000 steps (40%)
04:42:30:WU01:FS01:0x21:Completed 820000 out of 2000000 steps (41%)
04:43:42:WU02:FS00:0xa4:Completed 750000 out of 1250000 steps  (60%)
04:44:30:WU01:FS01:0x21:Completed 840000 out of 2000000 steps (42%)
04:46:29:WU01:FS01:0x21:Completed 860000 out of 2000000 steps (43%)
04:47:35:WU02:FS00:0xa4:Completed 762500 out of 1250000 steps  (61%)
04:48:11:WARNING:FS01:Size of positions 18935 does not match topology 18851
04:48:36:WU01:FS01:0x21:Completed 880000 out of 2000000 steps (44%)
04:50:35:WU01:FS01:0x21:Completed 900000 out of 2000000 steps (45%)
04:51:29:WU02:FS00:0xa4:Completed 775000 out of 1250000 steps  (62%)
04:52:34:WU01:FS01:0x21:Completed 920000 out of 2000000 steps (46%)
04:54:33:WU01:FS01:0x21:Completed 940000 out of 2000000 steps (47%)
04:55:22:WU02:FS00:0xa4:Completed 787500 out of 1250000 steps  (63%)
04:56:32:WU01:FS01:0x21:Completed 960000 out of 2000000 steps (48%)
04:58:31:WU01:FS01:0x21:Completed 980000 out of 2000000 steps (49%)
04:59:14:WU02:FS00:0xa4:Completed 800000 out of 1250000 steps  (64%)
05:00:30:WU01:FS01:0x21:Completed 1000000 out of 2000000 steps (50%)
05:00:42:WARNING:FS01:Size of positions 18935 does not match topology 18851
05:02:36:WU01:FS01:0x21:Completed 1020000 out of 2000000 steps (51%)
05:03:07:WU02:FS00:0xa4:Completed 812500 out of 1250000 steps  (65%)
05:04:35:WU01:FS01:0x21:Completed 1040000 out of 2000000 steps (52%)
05:06:35:WU01:FS01:0x21:Completed 1060000 out of 2000000 steps (53%)
05:07:00:WU02:FS00:0xa4:Completed 825000 out of 1250000 steps  (66%)
05:08:34:WU01:FS01:0x21:Completed 1080000 out of 2000000 steps (54%)
05:10:33:WU01:FS01:0x21:Completed 1100000 out of 2000000 steps (55%)
05:10:53:WU02:FS00:0xa4:Completed 837500 out of 1250000 steps  (67%)
05:12:32:WU01:FS01:0x21:Completed 1120000 out of 2000000 steps (56%)
05:13:14:WARNING:FS01:Size of positions 18935 does not match topology 18851
05:14:38:WU01:FS01:0x21:Completed 1140000 out of 2000000 steps (57%)
05:14:46:WU02:FS00:0xa4:Completed 850000 out of 1250000 steps  (68%)
05:16:38:WU01:FS01:0x21:Completed 1160000 out of 2000000 steps (58%)
05:18:37:WU01:FS01:0x21:Completed 1180000 out of 2000000 steps (59%)
05:18:39:WU02:FS00:0xa4:Completed 862500 out of 1250000 steps  (69%)
05:20:36:WU01:FS01:0x21:Completed 1200000 out of 2000000 steps (60%)
05:22:32:WU02:FS00:0xa4:Completed 875000 out of 1250000 steps  (70%)
05:22:35:WU01:FS01:0x21:Completed 1220000 out of 2000000 steps (61%)
05:24:34:WU01:FS01:0x21:Completed 1240000 out of 2000000 steps (62%)
05:25:46:WARNING:FS01:Size of positions 18935 does not match topology 18851
05:26:25:WU02:FS00:0xa4:Completed 887500 out of 1250000 steps  (71%)
05:26:40:WU01:FS01:0x21:Completed 1260000 out of 2000000 steps (63%)
05:28:39:WU01:FS01:0x21:Completed 1280000 out of 2000000 steps (64%)
05:30:18:WU02:FS00:0xa4:Completed 900000 out of 1250000 steps  (72%)
05:30:38:WU01:FS01:0x21:Completed 1300000 out of 2000000 steps (65%)
05:32:38:WU01:FS01:0x21:Completed 1320000 out of 2000000 steps (66%)
05:34:11:WU02:FS00:0xa4:Completed 912500 out of 1250000 steps  (73%)
05:34:37:WU01:FS01:0x21:Completed 1340000 out of 2000000 steps (67%)
05:36:35:WU01:FS01:0x21:Completed 1360000 out of 2000000 steps (68%)
05:38:04:WU02:FS00:0xa4:Completed 925000 out of 1250000 steps  (74%)
05:38:17:WARNING:FS01:Size of positions 18935 does not match topology 18851
05:38:42:WU01:FS01:0x21:Completed 1380000 out of 2000000 steps (69%)
05:40:40:WU01:FS01:0x21:Completed 1400000 out of 2000000 steps (70%)
05:41:57:WU02:FS00:0xa4:Completed 937500 out of 1250000 steps  (75%)
05:42:40:WU01:FS01:0x21:Completed 1420000 out of 2000000 steps (71%)
05:44:39:WU01:FS01:0x21:Completed 1440000 out of 2000000 steps (72%)
05:45:50:WU02:FS00:0xa4:Completed 950000 out of 1250000 steps  (76%)
05:46:38:WU01:FS01:0x21:Completed 1460000 out of 2000000 steps (73%)
05:48:37:WU01:FS01:0x21:Completed 1480000 out of 2000000 steps (74%)
05:49:42:WU02:FS00:0xa4:Completed 962500 out of 1250000 steps  (77%)
05:50:36:WU01:FS01:0x21:Completed 1500000 out of 2000000 steps (75%)
05:50:48:WARNING:FS01:Size of positions 18935 does not match topology 18851
05:52:42:WU01:FS01:0x21:Completed 1520000 out of 2000000 steps (76%)
05:53:35:WU02:FS00:0xa4:Completed 975000 out of 1250000 steps  (78%)
05:54:41:WU01:FS01:0x21:Completed 1540000 out of 2000000 steps (77%)
05:56:40:WU01:FS01:0x21:Completed 1560000 out of 2000000 steps (78%)
05:57:28:WU02:FS00:0xa4:Completed 987500 out of 1250000 steps  (79%)
05:58:39:WU01:FS01:0x21:Completed 1580000 out of 2000000 steps (79%)
06:00:38:WU01:FS01:0x21:Completed 1600000 out of 2000000 steps (80%)
06:01:21:WU02:FS00:0xa4:Completed 1000000 out of 1250000 steps  (80%)
06:02:37:WU01:FS01:0x21:Completed 1620000 out of 2000000 steps (81%)
06:03:19:WARNING:FS01:Size of positions 18935 does not match topology 18851
06:04:44:WU01:FS01:0x21:Completed 1640000 out of 2000000 steps (82%)
06:05:14:WU02:FS00:0xa4:Completed 1012500 out of 1250000 steps  (81%)
06:06:42:WU01:FS01:0x21:Completed 1660000 out of 2000000 steps (83%)
06:08:41:WU01:FS01:0x21:Completed 1680000 out of 2000000 steps (84%)
06:09:07:WU02:FS00:0xa4:Completed 1025000 out of 1250000 steps  (82%)
06:10:40:WU01:FS01:0x21:Completed 1700000 out of 2000000 steps (85%)
06:12:39:WU01:FS01:0x21:Completed 1720000 out of 2000000 steps (86%)
06:13:00:WU02:FS00:0xa4:Completed 1037500 out of 1250000 steps  (83%)
06:14:38:WU01:FS01:0x21:Completed 1740000 out of 2000000 steps (87%)
06:15:50:WARNING:FS01:Size of positions 18935 does not match topology 18851
06:16:44:WU01:FS01:0x21:Completed 1760000 out of 2000000 steps (88%)
06:16:53:WU02:FS00:0xa4:Completed 1050000 out of 1250000 steps  (84%)
06:18:44:WU01:FS01:0x21:Completed 1780000 out of 2000000 steps (89%)
06:20:43:WU01:FS01:0x21:Completed 1800000 out of 2000000 steps (90%)
06:20:46:WU02:FS00:0xa4:Completed 1062500 out of 1250000 steps  (85%)
06:22:42:WU01:FS01:0x21:Completed 1820000 out of 2000000 steps (91%)
06:24:39:WU02:FS00:0xa4:Completed 1075000 out of 1250000 steps  (86%)
06:24:41:WU01:FS01:0x21:Completed 1840000 out of 2000000 steps (92%)
06:26:41:WU01:FS01:0x21:Completed 1860000 out of 2000000 steps (93%)
06:28:22:WARNING:FS01:Size of positions 18935 does not match topology 18851
06:28:32:WU02:FS00:0xa4:Completed 1087500 out of 1250000 steps  (87%)
06:28:47:WU01:FS01:0x21:Completed 1880000 out of 2000000 steps (94%)
06:30:46:WU01:FS01:0x21:Completed 1900000 out of 2000000 steps (95%)
06:32:26:WU02:FS00:0xa4:Completed 1100000 out of 1250000 steps  (88%)
06:32:45:WU01:FS01:0x21:Completed 1920000 out of 2000000 steps (96%)
06:34:44:WU01:FS01:0x21:Completed 1940000 out of 2000000 steps (97%)
06:36:19:WU02:FS00:0xa4:Completed 1112500 out of 1250000 steps  (89%)
06:36:42:WU01:FS01:0x21:Completed 1960000 out of 2000000 steps (98%)
06:38:41:WU01:FS01:0x21:Completed 1980000 out of 2000000 steps (99%)
06:38:42:WU00:FS01:Connecting to 171.67.108.45:80
06:38:43:WU00:FS01:Assigned to work server 140.163.4.242
06:38:43:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.242
06:38:43:WU00:FS01:Connecting to 140.163.4.242:8080
06:38:43:WU00:FS01:Downloading 4.22MiB
06:38:46:WU00:FS01:Download complete
06:38:46:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11403 run:13 clone:2 gen:135 core:0x21 unit:0x000000a48ca304f255ed4fc043a4ad3c
06:40:13:WU02:FS00:0xa4:Completed 1125000 out of 1250000 steps  (90%)
06:40:39:WU01:FS01:0x21:Completed 2000000 out of 2000000 steps (100%)
06:40:47:WU01:FS01:0x21:Saving result file logfile_01.txt
06:40:47:WU01:FS01:0x21:Saving result file checkpointState.xml
06:40:51:WARNING:FS01:Size of positions 18935 does not match topology 18851
06:40:52:WU01:FS01:0x21:Saving result file checkpt.crc
06:40:52:WU01:FS01:0x21:Saving result file log.txt
06:40:52:WU01:FS01:0x21:Saving result file positions.xtc
06:40:54:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
06:40:55:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:40:55:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:10496 run:26 clone:28 gen:43 core:0x21 unit:0x000000358ca304f558895d6948534b99
06:40:55:WU01:FS01:Uploading 21.88MiB to 140.163.4.245
06:40:55:WU01:FS01:Connecting to 140.163.4.245:8080
06:40:55:WU00:FS01:Starting
06:40:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
06:40:55:WU00:FS01:Started FahCore on PID 1980
06:40:55:WU00:FS01:Core PID:6600
06:40:55:WU00:FS01:FahCore 0x21 started
06:40:56:WU00:FS01:0x21:*********************** Log Started 2017-05-15T06:40:55Z ***********************
06:40:56:WU00:FS01:0x21:Project: 11403 (Run 13, Clone 2, Gen 135)
06:40:56:WU00:FS01:0x21:Unit: 0x000000a48ca304f255ed4fc043a4ad3c
06:40:56:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:40:56:WU00:FS01:0x21:Machine: 1
06:40:56:WU00:FS01:0x21:Reading tar file core.xml
06:40:56:WU00:FS01:0x21:Reading tar file system.xml
06:40:56:WU00:FS01:0x21:Reading tar file integrator.xml
06:40:56:WU00:FS01:0x21:Reading tar file state.xml
06:40:56:WU00:FS01:0x21:Digital signatures verified
06:40:56:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:40:56:WU00:FS01:0x21:Version 0.0.18
06:41:01:WU01:FS01:Upload 10.28%
06:41:06:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
06:41:06:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:41:07:WU01:FS01:Upload 20.28%
06:41:13:WU01:FS01:Upload 30.28%
06:41:19:WU01:FS01:Upload 41.13%
06:41:25:WU01:FS01:Upload 50.56%
06:41:31:WU01:FS01:Upload 60.84%
06:41:37:WU01:FS01:Upload 71.41%
06:41:43:WU01:FS01:Upload 81.41%
06:41:49:WU01:FS01:Upload 91.41%
06:42:13:WU01:FS01:Upload complete
06:42:13:WU01:FS01:Server responded WORK_ACK (400)
06:42:13:WU01:FS01:Final credit estimate, 88535.00 points
06:42:13:WU01:FS01:Cleaning up
06:43:17:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
06:44:07:WU02:FS00:0xa4:Completed 1137500 out of 1250000 steps  (91%)
06:45:26:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
06:46:38:WARNING:FS01:Size of positions 4919 does not match topology 4916
06:47:38:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
06:48:01:WU02:FS00:0xa4:Completed 1150000 out of 1250000 steps  (92%)
06:49:48:WU00:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
06:51:54:WU02:FS00:0xa4:Completed 1162500 out of 1250000 steps  (93%)
06:51:57:WU00:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
06:52:04:WARNING:FS01:Size of positions 4919 does not match topology 4916
06:54:09:WU00:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
06:55:47:WU02:FS00:0xa4:Completed 1175000 out of 1250000 steps  (94%)
06:56:19:WU00:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
06:57:31:WARNING:FS01:Size of positions 4919 does not match topology 4916
06:58:31:WU00:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
06:59:40:WU02:FS00:0xa4:Completed 1187500 out of 1250000 steps  (95%)
07:00:40:WU00:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
07:02:50:WU00:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
07:02:57:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:03:34:WU02:FS00:0xa4:Completed 1200000 out of 1250000 steps  (96%)
07:05:02:WU00:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
07:07:12:WU00:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
07:07:31:WU02:FS00:0xa4:Completed 1212500 out of 1250000 steps  (97%)
07:08:24:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:09:23:WU00:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
07:11:25:WU02:FS00:0xa4:Completed 1225000 out of 1250000 steps  (98%)
07:11:33:WU00:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
07:13:43:WU00:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
07:13:50:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:15:19:WU02:FS00:0xa4:Completed 1237500 out of 1250000 steps  (99%)
07:15:19:WU01:FS00:Connecting to 171.67.108.45:8080
07:15:20:WU01:FS00:Assigned to work server 155.247.166.220
07:15:20:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.220
07:15:20:WU01:FS00:Connecting to 155.247.166.220:8080
07:15:21:WU01:FS00:Downloading 335.84KiB
07:15:21:WU01:FS00:Download complete
07:15:21:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8658 run:64 clone:0 gen:22 core:0xa4 unit:0x000000180002894c57fe64afd67468bb
07:15:55:WU00:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
07:18:05:WU00:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
07:19:12:WU02:FS00:0xa4:Completed 1250000 out of 1250000 steps  (100%)
07:19:12:WU02:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
07:19:17:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:19:22:WU02:FS00:0xa4:
07:19:22:WU02:FS00:0xa4:Finished Work Unit:
07:19:22:WU02:FS00:0xa4:- Reading up to 3922944 from "02/wudata_01.trr": Read 3922944
07:19:22:WU02:FS00:0xa4:trr file hash check passed.
07:19:22:WU02:FS00:0xa4:- Reading up to 149088 from "02/wudata_01.xtc": Read 149088
07:19:22:WU02:FS00:0xa4:xtc file hash check passed.
07:19:22:WU02:FS00:0xa4:edr file hash check passed.
07:19:22:WU02:FS00:0xa4:logfile size: 37239
07:19:22:WU02:FS00:0xa4:Leaving Run
07:19:27:WU02:FS00:0xa4:- Writing 4128971 bytes of core data to disk...
07:19:27:WU02:FS00:0xa4:Done: 4128459 -> 3374927 (compressed to 81.7 percent)
07:19:27:WU02:FS00:0xa4:  ... Done.
07:19:27:WU02:FS00:0xa4:- Shutting down core
07:19:27:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
07:19:28:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:19:28:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:8634 run:0 clone:310 gen:66 core:0xa4 unit:0x000000470002894b5820d757a9ec4ddc
07:19:28:WU02:FS00:Uploading 3.22MiB to 155.247.166.219
07:19:28:WU02:FS00:Connecting to 155.247.166.219:8080
07:19:28:WU01:FS00:Starting
07:19:28:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -np 6
07:19:28:WU01:FS00:Started FahCore on PID 4560
07:19:28:WU01:FS00:Core PID:9132
07:19:28:WU01:FS00:FahCore 0xa4 started
07:19:28:WU01:FS00:0xa4:
07:19:28:WU01:FS00:0xa4:*------------------------------*
07:19:28:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
07:19:28:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:19:28:WU01:FS00:0xa4:Preparing to commence simulation
07:19:28:WU01:FS00:0xa4:- Looking at optimizations...
07:19:28:WU01:FS00:0xa4:- Created dyn
07:19:28:WU01:FS00:0xa4:- Files status OK
07:19:28:WU01:FS00:0xa4:- Expanded 343392 -> 549472 (decompressed 160.0 percent)
07:19:28:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=343392 data_size=549472, decompressed_data_size=549472 diff=0
07:19:28:WU01:FS00:0xa4:- Digital signature verified
07:19:28:WU01:FS00:0xa4:Project: 8658 (Run 64, Clone 0, Gen 22)
07:19:28:WU01:FS00:0xa4:Assembly optimizations on if available.
07:19:28:WU01:FS00:0xa4:Entering M.D.
07:19:34:WU02:FS00:Upload 67.95%
07:19:34:WU01:FS00:0xa4:Mapping NT from 6 to 6
07:19:34:WU01:FS00:0xa4:Completed 0 out of 2500000 steps  (0%)
07:19:37:WU02:FS00:Upload complete
07:19:37:WU02:FS00:Server responded WORK_ACK (400)
07:19:37:WU02:FS00:Final credit estimate, 4765.00 points
07:19:37:WU02:FS00:Cleaning up
07:20:16:WU00:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
07:21:49:WU01:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
07:22:26:WU00:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
07:24:05:WU01:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
07:24:35:WU00:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
07:24:42:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:26:20:WU01:FS00:0xa4:Completed 75000 out of 2500000 steps  (3%)
07:26:47:WU00:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
07:28:36:WU01:FS00:0xa4:Completed 100000 out of 2500000 steps  (4%)
07:28:57:WU00:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
07:30:09:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:30:51:WU01:FS00:0xa4:Completed 125000 out of 2500000 steps  (5%)
07:31:09:WU00:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
07:33:06:WU01:FS00:0xa4:Completed 150000 out of 2500000 steps  (6%)
07:33:18:WU00:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
07:35:21:WU01:FS00:0xa4:Completed 175000 out of 2500000 steps  (7%)
07:35:28:WU00:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
07:35:35:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:37:37:WU01:FS00:0xa4:Completed 200000 out of 2500000 steps  (8%)
07:37:40:WU00:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
07:39:50:WU00:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
07:39:52:WU01:FS00:0xa4:Completed 225000 out of 2500000 steps  (9%)
07:41:01:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:42:01:WU00:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
07:42:07:WU01:FS00:0xa4:Completed 250000 out of 2500000 steps  (10%)
07:44:11:WU00:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
07:44:23:WU01:FS00:0xa4:Completed 275000 out of 2500000 steps  (11%)
07:46:21:WU00:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
07:46:28:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:46:38:WU01:FS00:0xa4:Completed 300000 out of 2500000 steps  (12%)
07:48:33:WU00:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
07:48:54:WU01:FS00:0xa4:Completed 325000 out of 2500000 steps  (13%)
07:50:42:WU00:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
07:51:09:WU01:FS00:0xa4:Completed 350000 out of 2500000 steps  (14%)
07:51:54:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:52:54:WU00:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
07:53:25:WU01:FS00:0xa4:Completed 375000 out of 2500000 steps  (15%)
07:55:04:WU00:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
07:55:41:WU01:FS00:0xa4:Completed 400000 out of 2500000 steps  (16%)
07:57:14:WU00:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
07:57:21:WARNING:FS01:Size of positions 4919 does not match topology 4916
07:57:56:WU01:FS00:0xa4:Completed 425000 out of 2500000 steps  (17%)
07:59:26:WU00:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
08:00:12:WU01:FS00:0xa4:Completed 450000 out of 2500000 steps  (18%)
08:01:35:WU00:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
08:02:28:WU01:FS00:0xa4:Completed 475000 out of 2500000 steps  (19%)
08:02:47:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:03:47:WU00:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
08:04:44:WU01:FS00:0xa4:Completed 500000 out of 2500000 steps  (20%)
08:05:57:WU00:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
08:07:00:WU01:FS00:0xa4:Completed 525000 out of 2500000 steps  (21%)
08:08:07:WU00:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
08:08:14:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:09:16:WU01:FS00:0xa4:Completed 550000 out of 2500000 steps  (22%)
08:10:19:WU00:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
08:11:31:WU01:FS00:0xa4:Completed 575000 out of 2500000 steps  (23%)
08:12:29:WU00:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
08:13:41:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:13:47:WU01:FS00:0xa4:Completed 600000 out of 2500000 steps  (24%)
08:14:41:WU00:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
08:16:02:WU01:FS00:0xa4:Completed 625000 out of 2500000 steps  (25%)
08:16:50:WU00:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
08:18:18:WU01:FS00:0xa4:Completed 650000 out of 2500000 steps  (26%)
08:19:00:WU00:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
08:19:07:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:20:33:WU01:FS00:0xa4:Completed 675000 out of 2500000 steps  (27%)
08:21:12:WU00:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
08:22:49:WU01:FS00:0xa4:Completed 700000 out of 2500000 steps  (28%)
08:23:22:WU00:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
08:24:33:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:25:04:WU01:FS00:0xa4:Completed 725000 out of 2500000 steps  (29%)
08:25:34:WU00:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
08:27:20:WU01:FS00:0xa4:Completed 750000 out of 2500000 steps  (30%)
08:27:43:WU00:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
08:29:36:WU01:FS00:0xa4:Completed 775000 out of 2500000 steps  (31%)
08:29:53:WU00:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
08:30:00:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:31:52:WU01:FS00:0xa4:Completed 800000 out of 2500000 steps  (32%)
08:32:05:WU00:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
08:34:08:WU01:FS00:0xa4:Completed 825000 out of 2500000 steps  (33%)
08:34:14:WU00:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
08:35:26:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:36:24:WU01:FS00:0xa4:Completed 850000 out of 2500000 steps  (34%)
08:36:26:WU00:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
08:38:36:WU00:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
08:38:40:WU01:FS00:0xa4:Completed 875000 out of 2500000 steps  (35%)
08:40:46:WU00:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
08:40:53:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:40:56:WU01:FS00:0xa4:Completed 900000 out of 2500000 steps  (36%)
08:42:58:WU00:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
08:43:12:WU01:FS00:0xa4:Completed 925000 out of 2500000 steps  (37%)
08:45:08:WU00:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
08:45:27:WU01:FS00:0xa4:Completed 950000 out of 2500000 steps  (38%)
08:46:20:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:47:20:WU00:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
08:47:44:WU01:FS00:0xa4:Completed 975000 out of 2500000 steps  (39%)
08:49:29:WU00:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
08:49:59:WU01:FS00:0xa4:Completed 1000000 out of 2500000 steps  (40%)
08:51:39:WU00:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
08:51:46:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:52:15:WU01:FS00:0xa4:Completed 1025000 out of 2500000 steps  (41%)
08:53:51:WU00:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
08:54:30:WU01:FS00:0xa4:Completed 1050000 out of 2500000 steps  (42%)
08:56:00:WU00:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
08:56:46:WU01:FS00:0xa4:Completed 1075000 out of 2500000 steps  (43%)
08:57:13:WARNING:FS01:Size of positions 4919 does not match topology 4916
08:58:13:WU00:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
08:59:01:WU01:FS00:0xa4:Completed 1100000 out of 2500000 steps  (44%)
09:00:22:WU00:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
09:01:17:WU01:FS00:0xa4:Completed 1125000 out of 2500000 steps  (45%)
09:02:32:WU00:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
09:02:39:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:03:32:WU01:FS00:0xa4:Completed 1150000 out of 2500000 steps  (46%)
09:04:44:WU00:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
09:05:48:WU01:FS00:0xa4:Completed 1175000 out of 2500000 steps  (47%)
09:06:53:WU00:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
09:08:04:WU01:FS00:0xa4:Completed 1200000 out of 2500000 steps  (48%)
09:08:05:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:09:05:WU00:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
09:10:20:WU01:FS00:0xa4:Completed 1225000 out of 2500000 steps  (49%)
09:11:15:WU00:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
09:12:35:WU01:FS00:0xa4:Completed 1250000 out of 2500000 steps  (50%)
09:13:25:WU00:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
09:13:32:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:14:51:WU01:FS00:0xa4:Completed 1275000 out of 2500000 steps  (51%)
09:15:37:WU00:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
09:17:07:WU01:FS00:0xa4:Completed 1300000 out of 2500000 steps  (52%)
09:17:46:WU00:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
09:18:58:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:19:22:WU01:FS00:0xa4:Completed 1325000 out of 2500000 steps  (53%)
09:19:58:WU00:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
09:21:39:WU01:FS00:0xa4:Completed 1350000 out of 2500000 steps  (54%)
09:22:08:WU00:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
09:23:55:WU01:FS00:0xa4:Completed 1375000 out of 2500000 steps  (55%)
09:24:18:WU00:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
09:24:25:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:26:10:WU01:FS00:0xa4:Completed 1400000 out of 2500000 steps  (56%)
09:26:30:WU00:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
09:28:26:WU01:FS00:0xa4:Completed 1425000 out of 2500000 steps  (57%)
09:28:39:WU00:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
09:29:51:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:30:41:WU01:FS00:0xa4:Completed 1450000 out of 2500000 steps  (58%)
09:30:51:WU00:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
09:32:57:WU01:FS00:0xa4:Completed 1475000 out of 2500000 steps  (59%)
09:33:01:WU00:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
09:35:10:WU00:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
09:35:13:WU01:FS00:0xa4:Completed 1500000 out of 2500000 steps  (60%)
09:35:17:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:37:22:WU00:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
09:37:28:WU01:FS00:0xa4:Completed 1525000 out of 2500000 steps  (61%)
09:39:32:WU00:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
09:39:44:WU01:FS00:0xa4:Completed 1550000 out of 2500000 steps  (62%)
09:40:44:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:41:44:WU00:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
09:41:59:WU01:FS00:0xa4:Completed 1575000 out of 2500000 steps  (63%)
09:43:54:WU00:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
09:44:14:WU01:FS00:0xa4:Completed 1600000 out of 2500000 steps  (64%)
09:46:03:WU00:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
09:46:10:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:46:30:WU01:FS00:0xa4:Completed 1625000 out of 2500000 steps  (65%)
09:48:15:WU00:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
09:48:45:WU01:FS00:0xa4:Completed 1650000 out of 2500000 steps  (66%)
09:50:25:WU00:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
09:51:01:WU01:FS00:0xa4:Completed 1675000 out of 2500000 steps  (67%)
09:51:37:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:52:37:WU00:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
09:53:17:WU01:FS00:0xa4:Completed 1700000 out of 2500000 steps  (68%)
09:54:46:WU00:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
09:55:32:WU01:FS00:0xa4:Completed 1725000 out of 2500000 steps  (69%)
09:56:56:WU00:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
09:57:03:WARNING:FS01:Size of positions 4919 does not match topology 4916
09:57:48:WU01:FS00:0xa4:Completed 1750000 out of 2500000 steps  (70%)
09:59:08:WU00:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
10:00:04:WU01:FS00:0xa4:Completed 1775000 out of 2500000 steps  (71%)
10:01:18:WU00:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
10:02:19:WU01:FS00:0xa4:Completed 1800000 out of 2500000 steps  (72%)
10:02:30:WARNING:FS01:Size of positions 4919 does not match topology 4916
10:03:30:WU00:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
10:04:35:WU01:FS00:0xa4:Completed 1825000 out of 2500000 steps  (73%)
10:05:40:WU00:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
10:06:51:WU01:FS00:0xa4:Completed 1850000 out of 2500000 steps  (74%)
10:07:49:WU00:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
10:07:56:WARNING:FS01:Size of positions 4919 does not match topology 4916
10:09:07:WU01:FS00:0xa4:Completed 1875000 out of 2500000 steps  (75%)
10:10:01:WU00:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
10:11:22:WU01:FS00:0xa4:Completed 1900000 out of 2500000 steps  (76%)
10:12:11:WU00:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
10:13:23:WARNING:FS01:Size of positions 4919 does not match topology 4916
10:13:38:WU01:FS00:0xa4:Completed 1925000 out of 2500000 steps  (77%)
10:14:23:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
10:15:53:WU01:FS00:0xa4:Completed 1950000 out of 2500000 steps  (78%)
10:16:33:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
10:16:34:WU02:FS01:Connecting to 171.67.108.45:80
10:16:34:WU02:FS01:Assigned to work server 171.67.108.157
10:16:34:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
10:16:34:WU02:FS01:Connecting to 171.67.108.157:8080
10:16:35:WU02:FS01:Downloading 5.18MiB
10:16:36:WU02:FS01:Download complete
10:16:36:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9415 run:157 clone:0 gen:296 core:0x21 unit:0x00000155ab436c9d585e06ca126a8955
10:18:08:WU01:FS00:0xa4:Completed 1975000 out of 2500000 steps  (79%)
10:18:43:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
10:18:45:WU00:FS01:0x21:Saving result file logfile_01.txt
10:18:45:WU00:FS01:0x21:Saving result file checkpointState.xml
10:18:46:WU00:FS01:0x21:Saving result file checkpt.crc
10:18:46:WU00:FS01:0x21:Saving result file log.txt
10:18:46:WU00:FS01:0x21:Saving result file positions.xtc
10:18:48:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
10:18:48:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:18:48:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11403 run:13 clone:2 gen:135 core:0x21 unit:0x000000a48ca304f255ed4fc043a4ad3c
10:18:48:WU00:FS01:Uploading 11.02MiB to 140.163.4.242
10:18:48:WU00:FS01:Connecting to 140.163.4.242:8080
10:18:48:WU02:FS01:Starting
10:18:48:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:18:48:WU02:FS01:Started FahCore on PID 11252
10:18:48:WU02:FS01:Core PID:10564
10:18:48:WU02:FS01:FahCore 0x21 started
10:18:49:WU02:FS01:0x21:*********************** Log Started 2017-05-15T10:18:49Z ***********************
10:18:49:WU02:FS01:0x21:Project: 9415 (Run 157, Clone 0, Gen 296)
10:18:49:WU02:FS01:0x21:Unit: 0x00000155ab436c9d585e06ca126a8955
10:18:49:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
10:18:49:WU02:FS01:0x21:Machine: 1
10:18:49:WU02:FS01:0x21:Reading tar file core.xml
10:18:49:WU02:FS01:0x21:Reading tar file integrator.xml
10:18:49:WU02:FS01:0x21:Reading tar file state.xml
10:18:49:WU02:FS01:0x21:Reading tar file system.xml
10:18:49:WU02:FS01:0x21:Digital signatures verified
10:18:49:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
10:18:49:WU02:FS01:0x21:Version 0.0.18
10:18:52:WU02:FS01:0x21:Completed 0 out of 6250000 steps (0%)
10:18:52:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:18:54:WU00:FS01:Upload 18.15%
10:19:00:WU00:FS01:Upload 39.13%
10:19:06:WU00:FS01:Upload 58.98%
10:19:12:WU00:FS01:Upload 78.83%
10:19:18:WU00:FS01:Upload 99.25%
10:19:24:WU00:FS01:Upload complete
10:19:24:WU00:FS01:Server responded WORK_ACK (400)
10:19:24:WU00:FS01:Final credit estimate, 113618.00 points
10:19:24:WU00:FS01:Cleaning up
10:19:42:WARNING:FS01:Size of positions 394 does not match topology 391
10:19:48:WU02:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
10:20:25:WU01:FS00:0xa4:Completed 2000000 out of 2500000 steps  (80%)
10:20:26:WARNING:FS01:Size of positions 394 does not match topology 391
10:20:44:WU02:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
10:21:11:WARNING:FS01:Size of positions 394 does not match topology 391
10:21:39:WU02:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
10:21:55:WARNING:FS01:Size of positions 394 does not match topology 391
10:22:35:WU02:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
10:22:40:WARNING:FS01:Size of positions 394 does not match topology 391
10:22:42:WU01:FS00:0xa4:Completed 2025000 out of 2500000 steps  (81%)
10:23:24:WARNING:FS01:Size of positions 394 does not match topology 391
10:23:30:WU02:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
10:24:09:WARNING:FS01:Size of positions 394 does not match topology 391
10:24:26:WU02:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
10:24:53:WARNING:FS01:Size of positions 394 does not match topology 391
10:24:58:WU01:FS00:0xa4:Completed 2050000 out of 2500000 steps  (82%)
10:25:22:WU02:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
10:25:38:WARNING:FS01:Size of positions 394 does not match topology 391
10:26:17:WU02:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
10:26:22:WARNING:FS01:Size of positions 394 does not match topology 391
10:27:07:WARNING:FS01:Size of positions 394 does not match topology 391
10:27:13:WU02:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
10:27:15:WU01:FS00:0xa4:Completed 2075000 out of 2500000 steps  (83%)
10:27:51:WARNING:FS01:Size of positions 394 does not match topology 391
10:28:08:WU02:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
10:28:36:WARNING:FS01:Size of positions 394 does not match topology 391
10:29:04:WU02:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
10:29:20:WARNING:FS01:Size of positions 394 does not match topology 391
10:29:31:WU01:FS00:0xa4:Completed 2100000 out of 2500000 steps  (84%)
10:30:00:WU02:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
10:30:05:WARNING:FS01:Size of positions 394 does not match topology 391
10:30:49:WARNING:FS01:Size of positions 394 does not match topology 391
10:30:55:WU02:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
10:31:34:WARNING:FS01:Size of positions 394 does not match topology 391
10:31:48:WU01:FS00:0xa4:Completed 2125000 out of 2500000 steps  (85%)
10:31:51:WU02:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
10:32:18:WARNING:FS01:Size of positions 394 does not match topology 391
10:32:46:WU02:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
10:33:03:WARNING:FS01:Size of positions 394 does not match topology 391
10:33:42:WU02:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
10:33:47:WARNING:FS01:Size of positions 394 does not match topology 391
10:34:04:WU01:FS00:0xa4:Completed 2150000 out of 2500000 steps  (86%)
10:34:32:WARNING:FS01:Size of positions 394 does not match topology 391
10:34:38:WU02:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
10:35:16:WARNING:FS01:Size of positions 394 does not match topology 391
10:35:34:WU02:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
10:36:01:WARNING:FS01:Size of positions 394 does not match topology 391
10:36:21:WU01:FS00:0xa4:Completed 2175000 out of 2500000 steps  (87%)
10:36:29:WU02:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
10:36:45:WARNING:FS01:Size of positions 394 does not match topology 391
10:37:25:WU02:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
10:37:30:WARNING:FS01:Size of positions 394 does not match topology 391
10:38:14:WARNING:FS01:Size of positions 394 does not match topology 391
10:38:21:WU02:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
10:38:37:WU01:FS00:0xa4:Completed 2200000 out of 2500000 steps  (88%)
10:38:59:WARNING:FS01:Size of positions 394 does not match topology 391
10:39:16:WU02:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
10:39:43:WARNING:FS01:Size of positions 394 does not match topology 391
10:40:12:WU02:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
10:40:28:WARNING:FS01:Size of positions 394 does not match topology 391
10:40:54:WU01:FS00:0xa4:Completed 2225000 out of 2500000 steps  (89%)
10:41:07:WU02:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
10:41:12:WARNING:FS01:Size of positions 394 does not match topology 391
10:41:57:WARNING:FS01:Size of positions 394 does not match topology 391
10:42:03:WU02:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
10:42:41:WARNING:FS01:Size of positions 394 does not match topology 391
10:42:59:WU02:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
10:43:10:WU01:FS00:0xa4:Completed 2250000 out of 2500000 steps  (90%)
10:43:26:WARNING:FS01:Size of positions 394 does not match topology 391
10:43:54:WU02:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
10:44:10:WARNING:FS01:Size of positions 394 does not match topology 391
10:44:49:WU02:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
10:44:55:WARNING:FS01:Size of positions 394 does not match topology 391
10:45:27:WU01:FS00:0xa4:Completed 2275000 out of 2500000 steps  (91%)
10:45:39:WARNING:FS01:Size of positions 394 does not match topology 391
10:45:45:WU02:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
10:46:24:WARNING:FS01:Size of positions 394 does not match topology 391
10:46:41:WU02:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
10:47:08:WARNING:FS01:Size of positions 394 does not match topology 391
10:47:37:WU02:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
10:47:43:WU01:FS00:0xa4:Completed 2300000 out of 2500000 steps  (92%)
10:47:53:WARNING:FS01:Size of positions 394 does not match topology 391
10:48:32:WU02:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
10:48:37:WARNING:FS01:Size of positions 394 does not match topology 391
10:49:22:WARNING:FS01:Size of positions 394 does not match topology 391
10:49:28:WU02:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
10:50:00:WU01:FS00:0xa4:Completed 2325000 out of 2500000 steps  (93%)
10:50:06:WARNING:FS01:Size of positions 394 does not match topology 391
10:50:23:WU02:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
10:50:51:WARNING:FS01:Size of positions 394 does not match topology 391
10:51:19:WU02:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
10:51:35:WARNING:FS01:Size of positions 394 does not match topology 391
10:52:14:WU02:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
10:52:16:WU01:FS00:0xa4:Completed 2350000 out of 2500000 steps  (94%)
10:52:20:WARNING:FS01:Size of positions 394 does not match topology 391
10:53:04:WARNING:FS01:Size of positions 394 does not match topology 391
10:53:10:WU02:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
10:53:49:WARNING:FS01:Size of positions 394 does not match topology 391
10:54:06:WU02:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
10:54:33:WARNING:FS01:Size of positions 394 does not match topology 391
10:54:33:WU01:FS00:0xa4:Completed 2375000 out of 2500000 steps  (95%)
10:55:01:WU02:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
10:55:18:WARNING:FS01:Size of positions 394 does not match topology 391
10:55:57:WU02:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
10:56:02:WARNING:FS01:Size of positions 394 does not match topology 391
10:56:46:WARNING:FS01:Size of positions 394 does not match topology 391
10:56:50:WU01:FS00:0xa4:Completed 2400000 out of 2500000 steps  (96%)
10:56:53:WU02:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
10:57:31:WARNING:FS01:Size of positions 394 does not match topology 391
10:57:48:WU02:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
10:58:15:WARNING:FS01:Size of positions 394 does not match topology 391
10:58:43:WU02:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
10:59:00:WARNING:FS01:Size of positions 394 does not match topology 391
10:59:07:WU01:FS00:0xa4:Completed 2425000 out of 2500000 steps  (97%)
10:59:39:WU02:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
10:59:44:WARNING:FS01:Size of positions 394 does not match topology 391
11:00:29:WARNING:FS01:Size of positions 394 does not match topology 391
11:00:35:WU02:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
11:01:13:WARNING:FS01:Size of positions 394 does not match topology 391
11:01:24:WU01:FS00:0xa4:Completed 2450000 out of 2500000 steps  (98%)
11:01:30:WU02:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
11:01:58:WARNING:FS01:Size of positions 394 does not match topology 391
11:02:26:WU02:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
11:02:42:WARNING:FS01:Size of positions 394 does not match topology 391
11:03:21:WU02:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
11:03:27:WARNING:FS01:Size of positions 394 does not match topology 391
11:03:40:WU01:FS00:0xa4:Completed 2475000 out of 2500000 steps  (99%)
11:03:41:WU00:FS00:Connecting to 171.67.108.45:8080
11:03:42:WU00:FS00:Assigned to work server 155.247.166.219
11:03:42:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
11:03:42:WU00:FS00:Connecting to 155.247.166.219:8080
11:03:43:WU00:FS00:Downloading 858.69KiB
11:03:44:WU00:FS00:Download complete
11:03:44:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8636 run:5 clone:80 gen:119 core:0xa4 unit:0x0000007e0002894b582a281a65244fa8
11:04:11:WARNING:FS01:Size of positions 394 does not match topology 391
11:04:17:WU02:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
11:04:56:WARNING:FS01:Size of positions 394 does not match topology 391
11:05:13:WU02:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
11:05:40:WARNING:FS01:Size of positions 394 does not match topology 391
11:05:57:WU01:FS00:0xa4:Completed 2500000 out of 2500000 steps  (100%)
11:05:57:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
11:06:08:WU01:FS00:0xa4:
11:06:08:WU01:FS00:0xa4:Finished Work Unit:
11:06:08:WU01:FS00:0xa4:- Reading up to 1953936 from "01/wudata_01.trr": Read 1953936
11:06:08:WU01:FS00:0xa4:trr file hash check passed.
11:06:08:WU01:FS00:0xa4:- Reading up to 2461604 from "01/wudata_01.xtc": Read 2461604
11:06:08:WU01:FS00:0xa4:xtc file hash check passed.
11:06:08:WU01:FS00:0xa4:edr file hash check passed.
11:06:08:WU01:FS00:0xa4:logfile size: 56329
11:06:08:WU01:FS00:0xa4:Leaving Run
11:06:08:WU02:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
11:06:10:WU01:FS00:0xa4:- Writing 4502429 bytes of core data to disk...
11:06:11:WU01:FS00:0xa4:Done: 4501917 -> 4359756 (compressed to 96.8 percent)
11:06:11:WU01:FS00:0xa4:  ... Done.
11:06:11:WU01:FS00:0xa4:- Shutting down core
11:06:11:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
11:06:11:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:06:11:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8658 run:64 clone:0 gen:22 core:0xa4 unit:0x000000180002894c57fe64afd67468bb
11:06:11:WU01:FS00:Uploading 4.16MiB to 155.247.166.220
11:06:11:WU01:FS00:Connecting to 155.247.166.220:8080
11:06:11:WU00:FS00:Starting
11:06:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -np 6
11:06:11:WU00:FS00:Started FahCore on PID 8444
11:06:11:WU00:FS00:Core PID:8276
11:06:11:WU00:FS00:FahCore 0xa4 started
11:06:12:WU00:FS00:0xa4:
11:06:12:WU00:FS00:0xa4:*------------------------------*
11:06:12:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
11:06:12:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:06:12:WU00:FS00:0xa4:Preparing to commence simulation
11:06:12:WU00:FS00:0xa4:- Looking at optimizations...
11:06:12:WU00:FS00:0xa4:- Created dyn
11:06:12:WU00:FS00:0xa4:- Files status OK
11:06:12:WU00:FS00:0xa4:- Expanded 878788 -> 2053928 (decompressed 233.7 percent)
11:06:12:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=878788 data_size=2053928, decompressed_data_size=2053928 diff=0
11:06:12:WU00:FS00:0xa4:- Digital signature verified
11:06:12:WU00:FS00:0xa4:Project: 8636 (Run 5, Clone 80, Gen 119)
11:06:12:WU00:FS00:0xa4:Assembly optimizations on if available.
11:06:12:WU00:FS00:0xa4:Entering M.D.
11:06:17:WU01:FS00:Upload 51.10%
11:06:18:WU00:FS00:0xa4:Mapping NT from 6 to 6
11:06:18:WU00:FS00:0xa4:Completed 0 out of 1250000 steps  (0%)
11:06:23:WU01:FS00:Upload complete
11:06:23:WU01:FS00:Server responded WORK_ACK (400)
11:06:23:WU01:FS00:Final credit estimate, 3433.00 points
11:06:23:WU01:FS00:Cleaning up
11:06:24:WARNING:FS01:Size of positions 394 does not match topology 391
11:07:03:WU02:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
11:07:09:WARNING:FS01:Size of positions 394 does not match topology 391
11:07:53:WARNING:FS01:Size of positions 394 does not match topology 391
11:07:59:WU02:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
11:08:38:WARNING:FS01:Size of positions 394 does not match topology 391
11:08:55:WU02:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
11:09:22:WARNING:FS01:Size of positions 394 does not match topology 391
11:09:51:WU02:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
11:10:07:WARNING:FS01:Size of positions 394 does not match topology 391
11:10:15:WU00:FS00:0xa4:Completed 12500 out of 1250000 steps  (1%)
11:10:46:WU02:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
11:10:52:WARNING:FS01:Size of positions 394 does not match topology 391
11:11:36:WARNING:FS01:Size of positions 394 does not match topology 391
11:11:43:WU02:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
11:12:21:WARNING:FS01:Size of positions 394 does not match topology 391
11:12:38:WU02:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
11:13:06:WARNING:FS01:Size of positions 394 does not match topology 391
11:13:34:WU02:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
11:13:50:WARNING:FS01:Size of positions 394 does not match topology 391
11:14:11:WU00:FS00:0xa4:Completed 25000 out of 1250000 steps  (2%)
11:14:30:WU02:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
11:14:35:WARNING:FS01:Size of positions 394 does not match topology 391
11:15:19:WARNING:FS01:Size of positions 394 does not match topology 391
11:15:26:WU02:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
11:16:04:WARNING:FS01:Size of positions 394 does not match topology 391
11:16:21:WU02:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
11:16:49:WARNING:FS01:Size of positions 394 does not match topology 391
11:17:17:WU02:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
11:17:33:WARNING:FS01:Size of positions 394 does not match topology 391
11:18:08:WU00:FS00:0xa4:Completed 37500 out of 1250000 steps  (3%)
11:18:12:WU02:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
11:18:18:WARNING:FS01:Size of positions 394 does not match topology 391
11:19:02:WARNING:FS01:Size of positions 394 does not match topology 391
11:19:09:WU02:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
11:19:47:WARNING:FS01:Size of positions 394 does not match topology 391
11:20:04:WU02:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
11:20:32:WARNING:FS01:Size of positions 394 does not match topology 391
11:21:00:WU02:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
11:21:16:WARNING:FS01:Size of positions 394 does not match topology 391
11:21:56:WU02:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
11:22:01:WARNING:FS01:Size of positions 394 does not match topology 391
11:22:06:WU00:FS00:0xa4:Completed 50000 out of 1250000 steps  (4%)
11:22:46:WARNING:FS01:Size of positions 394 does not match topology 391
11:22:52:WU02:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
11:23:30:WARNING:FS01:Size of positions 394 does not match topology 391
11:23:47:WU02:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
11:24:15:WARNING:FS01:Size of positions 394 does not match topology 391
11:24:43:WU02:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
11:24:59:WARNING:FS01:Size of positions 394 does not match topology 391
11:25:39:WU02:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
11:25:44:WARNING:FS01:Size of positions 394 does not match topology 391
11:26:02:WU00:FS00:0xa4:Completed 62500 out of 1250000 steps  (5%)
11:26:28:WARNING:FS01:Size of positions 394 does not match topology 391
11:26:35:WU02:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
11:27:13:WARNING:FS01:Size of positions 394 does not match topology 391
11:27:30:WU02:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
11:27:58:WARNING:FS01:Size of positions 394 does not match topology 391
11:28:26:WU02:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
11:28:42:WARNING:FS01:Size of positions 394 does not match topology 391
11:29:22:WU02:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
11:29:27:WARNING:FS01:Size of positions 394 does not match topology 391
11:30:00:WU00:FS00:0xa4:Completed 75000 out of 1250000 steps  (6%)
11:30:12:WARNING:FS01:Size of positions 394 does not match topology 391
11:30:18:WU02:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
11:30:56:WARNING:FS01:Size of positions 394 does not match topology 391
11:31:14:WU02:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
11:31:41:WARNING:FS01:Size of positions 394 does not match topology 391
11:32:09:WU02:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
11:32:26:WARNING:FS01:Size of positions 394 does not match topology 391
11:33:05:WU02:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
11:33:10:WARNING:FS01:Size of positions 394 does not match topology 391
11:33:55:WARNING:FS01:Size of positions 394 does not match topology 391
11:33:57:WU00:FS00:0xa4:Completed 87500 out of 1250000 steps  (7%)
11:34:01:WU02:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
11:34:39:WARNING:FS01:Size of positions 394 does not match topology 391
11:34:57:WU02:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
11:35:24:WARNING:FS01:Size of positions 394 does not match topology 391
11:35:52:WU02:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
11:36:09:WARNING:FS01:Size of positions 394 does not match topology 391
11:36:48:WU02:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
11:36:53:WARNING:FS01:Size of positions 394 does not match topology 391
11:37:38:WARNING:FS01:Size of positions 394 does not match topology 391
11:37:44:WU02:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
11:37:54:WU00:FS00:0xa4:Completed 100000 out of 1250000 steps  (8%)
11:38:22:WARNING:FS01:Size of positions 394 does not match topology 391
11:38:40:WU02:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
11:39:07:WARNING:FS01:Size of positions 394 does not match topology 391
11:39:35:WU02:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
11:39:52:WARNING:FS01:Size of positions 394 does not match topology 391
11:40:31:WU02:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
11:40:36:WARNING:FS01:Size of positions 394 does not match topology 391
11:41:21:WARNING:FS01:Size of positions 394 does not match topology 391
11:41:27:WU02:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
11:41:51:WU00:FS00:0xa4:Completed 112500 out of 1250000 steps  (9%)
11:42:05:WARNING:FS01:Size of positions 394 does not match topology 391
11:42:23:WU02:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
11:42:50:WARNING:FS01:Size of positions 394 does not match topology 391
11:43:18:WU02:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
11:43:35:WARNING:FS01:Size of positions 394 does not match topology 391
11:44:14:WU02:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
11:44:19:WARNING:FS01:Size of positions 394 does not match topology 391
11:45:04:WARNING:FS01:Size of positions 394 does not match topology 391
11:45:10:WU02:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
11:45:48:WU00:FS00:0xa4:Completed 125000 out of 1250000 steps  (10%)
11:45:49:WARNING:FS01:Size of positions 394 does not match topology 391
11:46:06:WU02:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
11:46:33:WARNING:FS01:Size of positions 394 does not match topology 391
11:47:01:WU02:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
11:47:18:WARNING:FS01:Size of positions 394 does not match topology 391
11:47:57:WU02:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
11:48:02:WARNING:FS01:Size of positions 394 does not match topology 391
11:48:47:WARNING:FS01:Size of positions 394 does not match topology 391
11:48:53:WU02:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
11:49:32:WARNING:FS01:Size of positions 394 does not match topology 391
11:49:46:WU00:FS00:0xa4:Completed 137500 out of 1250000 steps  (11%)
11:49:49:WU02:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
11:50:16:WARNING:FS01:Size of positions 394 does not match topology 391
11:50:44:WU02:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
11:50:45:WU01:FS01:Connecting to 171.67.108.45:80
11:50:46:WU01:FS01:Assigned to work server 171.67.108.105
11:50:46:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.105
11:50:46:WU01:FS01:Connecting to 171.67.108.105:8080
11:50:47:WU01:FS01:Downloading 20.47MiB
11:50:50:WU01:FS01:Download complete
11:50:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9178 run:5 clone:3 gen:119 core:0x21 unit:0x0000009cab436c6957b24c29cf888fac
11:51:01:WARNING:FS01:Size of positions 394 does not match topology 391
11:51:40:WU02:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
11:51:41:WU02:FS01:0x21:Saving result file logfile_01.txt
11:51:41:WU02:FS01:0x21:Saving result file checkpointState.xml
11:51:41:WU02:FS01:0x21:Saving result file checkpt.crc
11:51:41:WU02:FS01:0x21:Saving result file log.txt
11:51:41:WU02:FS01:0x21:Saving result file positions.xtc
11:51:41:WU02:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
11:51:41:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:51:41:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9415 run:157 clone:0 gen:296 core:0x21 unit:0x00000155ab436c9d585e06ca126a8955
11:51:41:WU02:FS01:Uploading 7.78MiB to 171.67.108.157
11:51:41:WU01:FS01:Starting
11:51:41:WU02:FS01:Connecting to 171.67.108.157:8080
11:51:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:51:41:WU01:FS01:Started FahCore on PID 8588
11:51:41:WU01:FS01:Core PID:4936
11:51:41:WU01:FS01:FahCore 0x21 started
11:51:42:WU01:FS01:0x21:*********************** Log Started 2017-05-15T11:51:41Z ***********************
11:51:42:WU01:FS01:0x21:Project: 9178 (Run 5, Clone 3, Gen 119)
11:51:42:WU01:FS01:0x21:Unit: 0x0000009cab436c6957b24c29cf888fac
11:51:42:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:51:42:WU01:FS01:0x21:Machine: 1
11:51:42:WU01:FS01:0x21:Reading tar file core.xml
11:51:42:WU01:FS01:0x21:Reading tar file integrator.xml
11:51:42:WU01:FS01:0x21:Reading tar file state.xml
11:51:42:WU01:FS01:0x21:Reading tar file system.xml
11:51:42:WU01:FS01:0x21:Digital signatures verified
11:51:42:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:51:42:WU01:FS01:0x21:Version 0.0.18
11:51:47:WU02:FS01:Upload 25.69%
11:51:51:WU01:FS01:0x21:Completed 0 out of 2500000 steps (0%)
11:51:51:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:51:53:WU02:FS01:Upload 54.60%
11:51:59:WU02:FS01:Upload 86.71%
11:52:03:WU02:FS01:Upload complete
11:52:03:WU02:FS01:Server responded WORK_ACK (400)
11:52:03:WU02:FS01:Final credit estimate, 45125.00 points
11:52:03:WU02:FS01:Cleaning up
11:52:42:WU01:FS01:0x21:Completed 25000 out of 2500000 steps (1%)
11:53:34:WU01:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
11:53:42:WU00:FS00:0xa4:Completed 150000 out of 1250000 steps  (12%)
11:54:25:WU01:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
11:55:17:WU01:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
11:56:10:WU01:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
11:57:01:WU01:FS01:0x21:Completed 150000 out of 2500000 steps (6%)
11:57:37:WU00:FS00:0xa4:Completed 162500 out of 1250000 steps  (13%)
11:57:53:WU01:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
11:58:44:WU01:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
11:59:37:WU01:FS01:0x21:Completed 225000 out of 2500000 steps (9%)
12:00:29:WU01:FS01:0x21:Completed 250000 out of 2500000 steps (10%)
12:01:20:WU01:FS01:0x21:Completed 275000 out of 2500000 steps (11%)
12:01:31:WU00:FS00:0xa4:Completed 175000 out of 1250000 steps  (14%)
12:02:11:WU01:FS01:0x21:Completed 300000 out of 2500000 steps (12%)
12:03:05:WU01:FS01:0x21:Completed 325000 out of 2500000 steps (13%)
12:03:56:WU01:FS01:0x21:Completed 350000 out of 2500000 steps (14%)
12:04:48:WU01:FS01:0x21:Completed 375000 out of 2500000 steps (15%)
12:05:25:WU00:FS00:0xa4:Completed 187500 out of 1250000 steps  (15%)
12:05:39:WU01:FS01:0x21:Completed 400000 out of 2500000 steps (16%)
12:06:32:WU01:FS01:0x21:Completed 425000 out of 2500000 steps (17%)
12:07:24:WU01:FS01:0x21:Completed 450000 out of 2500000 steps (18%)
12:08:15:WU01:FS01:0x21:Completed 475000 out of 2500000 steps (19%)
12:09:07:WU01:FS01:0x21:Completed 500000 out of 2500000 steps (20%)
12:09:20:WU00:FS00:0xa4:Completed 200000 out of 1250000 steps  (16%)
12:10:00:WU01:FS01:0x21:Completed 525000 out of 2500000 steps (21%)
12:10:52:WU01:FS01:0x21:Completed 550000 out of 2500000 steps (22%)
12:11:43:WU01:FS01:0x21:Completed 575000 out of 2500000 steps (23%)
12:12:35:WU01:FS01:0x21:Completed 600000 out of 2500000 steps (24%)
12:13:15:WU00:FS00:0xa4:Completed 212500 out of 1250000 steps  (17%)
12:13:28:WU01:FS01:0x21:Completed 625000 out of 2500000 steps (25%)
12:14:19:WU01:FS01:0x21:Completed 650000 out of 2500000 steps (26%)
12:15:11:WU01:FS01:0x21:Completed 675000 out of 2500000 steps (27%)
12:16:02:WU01:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
12:16:56:WU01:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
12:17:10:WU00:FS00:0xa4:Completed 225000 out of 1250000 steps  (18%)
12:17:47:WU01:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
12:18:38:WU01:FS01:0x21:Completed 775000 out of 2500000 steps (31%)
12:19:30:WU01:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
12:20:23:WU01:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
12:21:05:WU00:FS00:0xa4:Completed 237500 out of 1250000 steps  (19%)
12:21:15:WU01:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
12:22:07:WU01:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
12:22:58:WU01:FS01:0x21:Completed 900000 out of 2500000 steps (36%)
12:23:51:WU01:FS01:0x21:Completed 925000 out of 2500000 steps (37%)
12:24:43:WU01:FS01:0x21:Completed 950000 out of 2500000 steps (38%)
12:25:00:WU00:FS00:0xa4:Completed 250000 out of 1250000 steps  (20%)
12:25:34:WU01:FS01:0x21:Completed 975000 out of 2500000 steps (39%)
12:26:26:WU01:FS01:0x21:Completed 1000000 out of 2500000 steps (40%)
12:27:19:WU01:FS01:0x21:Completed 1025000 out of 2500000 steps (41%)
12:28:10:WU01:FS01:0x21:Completed 1050000 out of 2500000 steps (42%)
12:28:54:WU00:FS00:0xa4:Completed 262500 out of 1250000 steps  (21%)
12:29:02:WU01:FS01:0x21:Completed 1075000 out of 2500000 steps (43%)
12:29:54:WU01:FS01:0x21:Completed 1100000 out of 2500000 steps (44%)
12:30:47:WU01:FS01:0x21:Completed 1125000 out of 2500000 steps (45%)
12:31:39:WU01:FS01:0x21:Completed 1150000 out of 2500000 steps (46%)
12:32:31:WU01:FS01:0x21:Completed 1175000 out of 2500000 steps (47%)
12:32:50:WU00:FS00:0xa4:Completed 275000 out of 1250000 steps  (22%)
12:33:22:WU01:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
12:33:26:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
12:33:26:WARNING:WU01:FS01:FahCore returned: WU_STALLED (127 = 0x7f)
12:33:27:WU01:FS01:Starting
12:33:27:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:33:27:WU01:FS01:Started FahCore on PID 8240
12:33:27:WU01:FS01:Core PID:6596
12:33:27:WU01:FS01:FahCore 0x21 started
12:33:29:WU01:FS01:0x21:*********************** Log Started 2017-05-15T12:33:29Z ***********************
12:33:29:WU01:FS01:0x21:Project: 9178 (Run 5, Clone 3, Gen 119)
12:33:29:WU01:FS01:0x21:Unit: 0x0000009cab436c6957b24c29cf888fac
12:33:29:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:33:29:WU01:FS01:0x21:Machine: 1
12:33:29:WU01:FS01:0x21:Digital signatures verified
12:33:29:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:33:29:WU01:FS01:0x21:Version 0.0.18
12:33:29:WU01:FS01:0x21:  Found a checkpoint file
12:33:36:WU01:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
12:33:36:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:34:28:WU01:FS01:0x21:Completed 1225000 out of 2500000 steps (49%)
12:35:20:WU01:FS01:0x21:Completed 1250000 out of 2500000 steps (50%)
12:36:12:WU01:FS01:0x21:Completed 1275000 out of 2500000 steps (51%)
12:37:01:WU00:FS00:0xa4:Completed 287500 out of 1250000 steps  (23%)
12:37:03:WU01:FS01:0x21:Completed 1300000 out of 2500000 steps (52%)
12:37:57:WU01:FS01:0x21:Completed 1325000 out of 2500000 steps (53%)
12:38:48:WU01:FS01:0x21:Completed 1350000 out of 2500000 steps (54%)
12:39:40:WU01:FS01:0x21:Completed 1375000 out of 2500000 steps (55%)
12:40:31:WU01:FS01:0x21:Completed 1400000 out of 2500000 steps (56%)
12:40:56:WU00:FS00:0xa4:Completed 300000 out of 1250000 steps  (24%)
12:41:25:WU01:FS01:0x21:Completed 1425000 out of 2500000 steps (57%)
12:42:16:WU01:FS01:0x21:Completed 1450000 out of 2500000 steps (58%)
12:43:08:WU01:FS01:0x21:Completed 1475000 out of 2500000 steps (59%)
12:43:59:WU01:FS01:0x21:Completed 1500000 out of 2500000 steps (60%)
12:44:51:WU00:FS00:0xa4:Completed 312500 out of 1250000 steps  (25%)
12:44:53:WU01:FS01:0x21:Completed 1525000 out of 2500000 steps (61%)
12:45:44:WU01:FS01:0x21:Completed 1550000 out of 2500000 steps (62%)
12:46:36:WU01:FS01:0x21:Completed 1575000 out of 2500000 steps (63%)
12:47:28:WU01:FS01:0x21:Completed 1600000 out of 2500000 steps (64%)
12:48:21:WU01:FS01:0x21:Completed 1625000 out of 2500000 steps (65%)
12:48:48:WU00:FS00:0xa4:Completed 325000 out of 1250000 steps  (26%)
12:49:13:WU01:FS01:0x21:Completed 1650000 out of 2500000 steps (66%)
12:49:29:252:127.0.0.1:New Web connection
12:50:05:WU01:FS01:0x21:Completed 1675000 out of 2500000 steps (67%)
12:50:57:WU01:FS01:0x21:Completed 1700000 out of 2500000 steps (68%)
12:51:50:WU01:FS01:0x21:Completed 1725000 out of 2500000 steps (69%)
12:52:42:WU01:FS01:0x21:Completed 1750000 out of 2500000 steps (70%)
12:52:47:WU00:FS00:0xa4:Completed 337500 out of 1250000 steps  (27%)
12:53:34:WU01:FS01:0x21:Completed 1775000 out of 2500000 steps (71%)
12:54:26:WU01:FS01:0x21:Completed 1800000 out of 2500000 steps (72%)
12:55:19:WU01:FS01:0x21:Completed 1825000 out of 2500000 steps (73%)
12:56:11:WU01:FS01:0x21:Completed 1850000 out of 2500000 steps (74%)
12:56:42:WU00:FS00:0xa4:Completed 350000 out of 1250000 steps  (28%)
12:57:03:WU01:FS01:0x21:Completed 1875000 out of 2500000 steps (75%)
12:57:55:WU01:FS01:0x21:Completed 1900000 out of 2500000 steps (76%)
12:58:48:WU01:FS01:0x21:Completed 1925000 out of 2500000 steps (77%)
12:59:40:WU01:FS01:0x21:Completed 1950000 out of 2500000 steps (78%)
13:00:32:WU01:FS01:0x21:Completed 1975000 out of 2500000 steps (79%)
13:00:42:WU00:FS00:0xa4:Completed 362500 out of 1250000 steps  (29%)
13:01:24:WU01:FS01:0x21:Completed 2000000 out of 2500000 steps (80%)
13:02:17:WU01:FS01:0x21:Completed 2025000 out of 2500000 steps (81%)
13:03:09:WU01:FS01:0x21:Completed 2050000 out of 2500000 steps (82%)
13:04:01:WU01:FS01:0x21:Completed 2075000 out of 2500000 steps (83%)
13:04:39:WU00:FS00:0xa4:Completed 375000 out of 1250000 steps  (30%)
13:04:52:WU01:FS01:0x21:Completed 2100000 out of 2500000 steps (84%)
13:05:46:WU01:FS01:0x21:Completed 2125000 out of 2500000 steps (85%)
13:06:38:WU01:FS01:0x21:Completed 2150000 out of 2500000 steps (86%)
13:07:29:WU01:FS01:0x21:Completed 2175000 out of 2500000 steps (87%)
13:08:21:WU01:FS01:0x21:Completed 2200000 out of 2500000 steps (88%)
13:08:35:WU00:FS00:0xa4:Completed 387500 out of 1250000 steps  (31%)
13:09:14:WU01:FS01:0x21:Completed 2225000 out of 2500000 steps (89%)
13:10:06:WU01:FS01:0x21:Completed 2250000 out of 2500000 steps (90%)
13:10:58:WU01:FS01:0x21:Completed 2275000 out of 2500000 steps (91%)
13:11:50:WU01:FS01:0x21:Completed 2300000 out of 2500000 steps (92%)
13:12:34:WU00:FS00:0xa4:Completed 400000 out of 1250000 steps  (32%)
13:12:44:WU01:FS01:0x21:Completed 2325000 out of 2500000 steps (93%)
13:13:36:WU01:FS01:0x21:Completed 2350000 out of 2500000 steps (94%)
13:14:29:WU01:FS01:0x21:Completed 2375000 out of 2500000 steps (95%)
13:15:21:WU01:FS01:0x21:Completed 2400000 out of 2500000 steps (96%)
13:16:14:WU01:FS01:0x21:Completed 2425000 out of 2500000 steps (97%)
13:16:34:WU00:FS00:0xa4:Completed 412500 out of 1250000 steps  (33%)
13:17:06:WU01:FS01:0x21:Completed 2450000 out of 2500000 steps (98%)
13:17:59:WU01:FS01:0x21:Completed 2475000 out of 2500000 steps (99%)
13:18:01:WU02:FS01:Connecting to 171.67.108.45:80
13:18:01:WU02:FS01:Assigned to work server 171.67.108.105
13:18:01:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.105
13:18:01:WU02:FS01:Connecting to 171.67.108.105:8080
13:18:02:ERROR:WU02:FS01:Exception: Server did not assign work unit
13:18:02:WU02:FS01:Connecting to 171.67.108.45:80
13:18:02:WU02:FS01:Assigned to work server 140.163.4.241
13:18:02:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
13:18:02:WU02:FS01:Connecting to 140.163.4.241:8080
13:18:02:WU02:FS01:Downloading 3.66MiB
13:18:05:WU02:FS01:Download complete
13:18:05:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11429 run:1 clone:119 gen:93 core:0x21 unit:0x000000778ca304f158af65cc4966158b
13:18:52:WU01:FS01:0x21:Completed 2500000 out of 2500000 steps (100%)
13:18:54:WU01:FS01:0x21:Saving result file logfile_01.txt
13:18:54:WU01:FS01:0x21:Saving result file checkpointState.xml
13:18:54:WU01:FS01:0x21:Saving result file checkpt.crc
13:18:54:WU01:FS01:0x21:Saving result file log.txt
13:18:54:WU01:FS01:0x21:Saving result file positions.xtc
13:18:54:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
13:18:54:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:18:54:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9178 run:5 clone:3 gen:119 core:0x21 unit:0x0000009cab436c6957b24c29cf888fac
13:18:54:WU01:FS01:Uploading 12.28MiB to 171.67.108.105
13:18:54:WU02:FS01:Starting
13:18:54:WU01:FS01:Connecting to 171.67.108.105:8080
13:18:54:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:18:54:WU02:FS01:Started FahCore on PID 9580
13:18:54:WU02:FS01:Core PID:7780
13:18:54:WU02:FS01:FahCore 0x21 started
13:18:55:WU02:FS01:0x21:*********************** Log Started 2017-05-15T13:18:55Z ***********************
13:18:55:WU02:FS01:0x21:Project: 11429 (Run 1, Clone 119, Gen 93)
13:18:55:WU02:FS01:0x21:Unit: 0x000000778ca304f158af65cc4966158b
13:18:55:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
13:18:55:WU02:FS01:0x21:Machine: 1
13:18:55:WU02:FS01:0x21:Reading tar file core.xml
13:18:55:WU02:FS01:0x21:Reading tar file system.xml
13:18:55:WU02:FS01:0x21:Reading tar file integrator.xml
13:18:55:WU02:FS01:0x21:Reading tar file state.xml
13:18:56:WU02:FS01:0x21:Digital signatures verified
13:18:56:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
13:18:56:WU02:FS01:0x21:Version 0.0.18
13:19:00:WU01:FS01:Upload 17.81%
13:19:06:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
13:19:06:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:19:06:WU01:FS01:Upload 35.11%
13:19:12:WU01:FS01:Upload 53.43%
13:19:18:WU01:FS01:Upload 70.73%
13:19:24:WU01:FS01:Upload 89.05%
13:19:28:WU01:FS01:Upload complete
13:19:28:WU01:FS01:Server responded WORK_ACK (400)
13:19:28:WU01:FS01:Final credit estimate, 41840.00 points
13:19:28:WU01:FS01:Cleaning up
13:20:37:WU00:FS00:0xa4:Completed 425000 out of 1250000 steps  (34%)
13:21:01:WU02:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
13:22:55:WU02:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
13:23:59:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:24:38:WU00:FS00:0xa4:Completed 437500 out of 1250000 steps  (35%)
13:24:52:WU02:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
13:26:46:WU02:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
13:28:35:WU00:FS00:0xa4:Completed 450000 out of 1250000 steps  (36%)
13:28:38:WU02:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
13:28:45:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:30:33:WU02:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
13:32:26:WU02:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
13:32:32:WU00:FS00:0xa4:Completed 462500 out of 1250000 steps  (37%)
13:33:29:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:34:20:WU02:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
13:36:13:WU02:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
13:36:28:WU00:FS00:0xa4:Completed 475000 out of 1250000 steps  (38%)
13:38:05:WU02:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
13:38:12:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:39:59:WU02:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
13:40:24:WU00:FS00:0xa4:Completed 487500 out of 1250000 steps  (39%)
13:41:51:WU02:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
13:42:54:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:43:46:WU02:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
13:44:18:WU00:FS00:0xa4:Completed 500000 out of 1250000 steps  (40%)
13:45:38:WU02:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
13:47:30:WU02:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
13:47:37:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:48:13:WU00:FS00:0xa4:Completed 512500 out of 1250000 steps  (41%)
13:49:25:WU02:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
13:51:17:WU02:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
13:52:09:WU00:FS00:0xa4:Completed 525000 out of 1250000 steps  (42%)
13:52:20:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:53:11:WU02:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
13:55:04:WU02:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
13:56:06:WU00:FS00:0xa4:Completed 537500 out of 1250000 steps  (43%)
13:56:57:WU02:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
13:57:04:WARNING:FS01:Size of positions 4502 does not match topology 2734
13:58:52:WU02:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
14:00:02:WU00:FS00:0xa4:Completed 550000 out of 1250000 steps  (44%)
14:00:44:WU02:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
14:01:40:274:127.0.0.1:New Web connection
14:01:47:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:02:39:WU02:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
14:03:58:WU00:FS00:0xa4:Completed 562500 out of 1250000 steps  (45%)
14:04:31:WU02:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
14:06:24:WU02:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
14:06:31:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:07:54:WU00:FS00:0xa4:Completed 575000 out of 1250000 steps  (46%)
14:08:18:WU02:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
14:10:11:WU02:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
14:11:14:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:11:49:WU00:FS00:0xa4:Completed 587500 out of 1250000 steps  (47%)
14:12:05:WU02:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
14:13:57:WU02:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
14:15:43:WU00:FS00:0xa4:Completed 600000 out of 1250000 steps  (48%)
14:15:50:WU02:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
14:15:57:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:17:44:WU02:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
14:19:36:WU02:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
14:19:38:WU00:FS00:0xa4:Completed 612500 out of 1250000 steps  (49%)
14:20:39:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:21:31:WU02:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
14:23:23:WU02:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
14:23:34:WU00:FS00:0xa4:Completed 625000 out of 1250000 steps  (50%)
14:25:16:WU02:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
14:25:22:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:27:10:WU02:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
14:27:28:WU00:FS00:0xa4:Completed 637500 out of 1250000 steps  (51%)
14:29:02:WU02:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
14:30:05:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:30:56:WU02:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
14:31:23:WU00:FS00:0xa4:Completed 650000 out of 1250000 steps  (52%)
14:32:48:WU02:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
14:34:40:WU02:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
14:34:47:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:35:18:WU00:FS00:0xa4:Completed 662500 out of 1250000 steps  (53%)
14:36:34:WU02:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
14:38:27:WU02:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
14:39:13:WU00:FS00:0xa4:Completed 675000 out of 1250000 steps  (54%)
14:39:29:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:40:20:WU02:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
14:42:12:WU02:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
14:43:08:WU00:FS00:0xa4:Completed 687500 out of 1250000 steps  (55%)
14:44:05:WU02:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
14:44:12:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:46:00:WU02:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
14:47:04:WU00:FS00:0xa4:Completed 700000 out of 1250000 steps  (56%)
14:47:52:WU02:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
14:48:55:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:49:47:WU02:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
14:51:05:WU00:FS00:0xa4:Completed 712500 out of 1250000 steps  (57%)
14:51:40:WU02:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
14:53:32:WU02:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
14:53:39:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:55:07:WU00:FS00:0xa4:Completed 725000 out of 1250000 steps  (58%)
14:55:28:WU02:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
14:57:22:WU02:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
14:58:26:WARNING:FS01:Size of positions 4502 does not match topology 2734
14:59:05:WU00:FS00:0xa4:Completed 737500 out of 1250000 steps  (59%)
14:59:17:WU02:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
15:01:09:WU02:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
15:03:00:WU00:FS00:0xa4:Completed 750000 out of 1250000 steps  (60%)
15:03:01:WU02:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
15:03:08:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:04:55:WU02:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
15:06:48:WU02:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
15:06:55:WU00:FS00:0xa4:Completed 762500 out of 1250000 steps  (61%)
15:07:51:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:08:42:WU02:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
15:10:34:WU02:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
15:10:49:WU00:FS00:0xa4:Completed 775000 out of 1250000 steps  (62%)
15:12:26:WU02:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
15:12:33:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:14:21:WU02:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
15:14:44:WU00:FS00:0xa4:Completed 787500 out of 1250000 steps  (63%)
15:16:13:WU02:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
15:17:16:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:18:07:WU02:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
15:18:39:WU00:FS00:0xa4:Completed 800000 out of 1250000 steps  (64%)
15:19:59:WU02:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
15:21:52:WU02:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
15:21:58:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:22:34:WU00:FS00:0xa4:Completed 812500 out of 1250000 steps  (65%)
15:23:46:WU02:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
15:25:38:WU02:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
15:26:28:WU00:FS00:0xa4:Completed 825000 out of 1250000 steps  (66%)
15:26:41:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:27:32:WU02:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
15:29:25:WU02:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
15:30:22:WU00:FS00:0xa4:Completed 837500 out of 1250000 steps  (67%)
15:31:17:WU02:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
15:31:24:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:33:12:WU02:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
15:34:17:WU00:FS00:0xa4:Completed 850000 out of 1250000 steps  (68%)
15:35:03:WU02:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
15:36:06:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:36:57:WU02:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
15:38:11:WU00:FS00:0xa4:Completed 862500 out of 1250000 steps  (69%)
15:38:49:WU02:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
15:40:41:WU02:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
15:40:48:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:42:05:WU00:FS00:0xa4:Completed 875000 out of 1250000 steps  (70%)
15:42:35:WU02:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
15:44:27:WU02:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
15:45:30:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:46:00:WU00:FS00:0xa4:Completed 887500 out of 1250000 steps  (71%)
15:46:21:WU02:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
15:48:13:WU02:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
15:49:54:WU00:FS00:0xa4:Completed 900000 out of 1250000 steps  (72%)
15:50:05:WU02:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
15:50:12:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:51:59:WU02:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
15:53:49:WU00:FS00:0xa4:Completed 912500 out of 1250000 steps  (73%)
15:53:51:WU02:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
15:54:54:WARNING:FS01:Size of positions 4502 does not match topology 2734
15:55:45:WU02:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
15:57:37:WU02:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
15:57:42:WU00:FS00:0xa4:Completed 925000 out of 1250000 steps  (74%)
15:59:29:WU02:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
15:59:35:WARNING:FS01:Size of positions 4502 does not match topology 2734
16:01:22:WU02:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
16:01:36:WU00:FS00:0xa4:Completed 937500 out of 1250000 steps  (75%)
16:03:15:WU02:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
16:04:17:WARNING:FS01:Size of positions 4502 does not match topology 2734
16:05:08:WU02:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
16:05:31:WU00:FS00:0xa4:Completed 950000 out of 1250000 steps  (76%)
16:07:00:WU02:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
16:08:52:WU02:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
16:08:59:WARNING:FS01:Size of positions 4502 does not match topology 2734
16:09:25:WU00:FS00:0xa4:Completed 962500 out of 1250000 steps  (77%)
16:10:46:WU02:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
16:12:38:WU02:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
16:13:19:WU00:FS00:0xa4:Completed 975000 out of 1250000 steps  (78%)
16:13:41:WARNING:FS01:Size of positions 4502 does not match topology 2734
16:14:32:WU02:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
16:16:24:WU02:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
16:17:14:WU00:FS00:0xa4:Completed 987500 out of 1250000 steps  (79%)
16:18:16:WU02:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
16:18:23:WARNING:FS01:Size of positions 4502 does not match topology 2734
16:20:11:WU02:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
16:21:09:WU00:FS00:0xa4:Completed 1000000 out of 1250000 steps  (80%)
16:22:03:WU02:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
16:23:05:WARNING:FS01:Size of positions 4502 does not match topology 2734
16:23:56:WU02:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
16:25:04:WU00:FS00:0xa4:Completed 1012500 out of 1250000 steps  (81%)
16:25:49:WU02:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
16:25:49:WU01:FS01:Connecting to 171.67.108.45:80
16:25:50:WU01:FS01:Assigned to work server 140.163.4.242
16:25:50:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.242
16:25:50:WU01:FS01:Connecting to 140.163.4.242:8080
16:25:50:WU01:FS01:Downloading 3.47MiB
16:25:52:WU01:FS01:Download complete
16:25:52:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11407 run:1 clone:13 gen:617 core:0x21 unit:0x0000034f8ca304f25686b24be1ce6bc2
16:27:40:WU02:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
16:27:43:WU02:FS01:0x21:Saving result file logfile_01.txt
16:27:43:WU02:FS01:0x21:Saving result file checkpointState.xml
16:27:44:WU02:FS01:0x21:Saving result file checkpt.crc
16:27:44:WU02:FS01:0x21:Saving result file log.txt
16:27:44:WU02:FS01:0x21:Saving result file positions.xtc
16:27:46:WU02:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
16:27:46:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:27:46:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11429 run:1 clone:119 gen:93 core:0x21 unit:0x000000778ca304f158af65cc4966158b
16:27:46:WU02:FS01:Uploading 9.22MiB to 140.163.4.241
16:27:46:WU01:FS01:Starting
16:27:46:WU02:FS01:Connecting to 140.163.4.241:8080
16:27:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:27:46:WU01:FS01:Started FahCore on PID 3900
16:27:46:WU01:FS01:Core PID:10404
16:27:46:WU01:FS01:FahCore 0x21 started
16:27:47:WU01:FS01:0x21:*********************** Log Started 2017-05-15T16:27:46Z ***********************
16:27:47:WU01:FS01:0x21:Project: 11407 (Run 1, Clone 13, Gen 617)
16:27:47:WU01:FS01:0x21:Unit: 0x0000034f8ca304f25686b24be1ce6bc2
16:27:47:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:27:47:WU01:FS01:0x21:Machine: 1
16:27:47:WU01:FS01:0x21:Reading tar file core.xml
16:27:47:WU01:FS01:0x21:Reading tar file system.xml
16:27:47:WU01:FS01:0x21:Reading tar file integrator.xml
16:27:47:WU01:FS01:0x21:Reading tar file state.xml
16:27:47:WU01:FS01:0x21:Digital signatures verified
16:27:47:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:27:47:WU01:FS01:0x21:Version 0.0.18
16:27:52:WU02:FS01:Upload 20.33%
16:27:56:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
16:27:56:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:27:58:WU02:FS01:Upload 45.40%
16:28:04:WU02:FS01:Upload 70.47%
16:28:11:WU02:FS01:Upload 96.90%
16:28:17:WU02:FS01:Upload complete
16:28:17:WU02:FS01:Server responded WORK_ACK (400)
16:28:17:WU02:FS01:Final credit estimate, 87625.00 points
16:28:17:WU02:FS01:Cleaning up
16:28:59:WU00:FS00:0xa4:Completed 1025000 out of 1250000 steps  (82%)
16:29:40:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
16:31:23:WU01:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
16:32:23:301:127.0.0.1:New Web connection
16:32:55:WU00:FS00:0xa4:Completed 1037500 out of 1250000 steps  (83%)
16:33:10:WU01:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
16:34:53:WU01:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
******************************* Date: 2017-05-15 *******************************
16:36:37:WU01:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
16:36:53:WU00:FS00:0xa4:Completed 1050000 out of 1250000 steps  (84%)
16:38:23:WU01:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
16:40:07:WU01:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
16:40:50:WU00:FS00:0xa4:Completed 1062500 out of 1250000 steps  (85%)
16:41:52:WU01:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
16:43:36:WU01:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
16:44:46:WU00:FS00:0xa4:Completed 1075000 out of 1250000 steps  (86%)
16:45:19:WU01:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
16:47:05:WU01:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
16:48:44:WU00:FS00:0xa4:Completed 1087500 out of 1250000 steps  (87%)
16:48:48:WU01:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
16:50:34:WU01:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
16:52:18:WU01:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
16:52:40:WU00:FS00:0xa4:Completed 1100000 out of 1250000 steps  (88%)
16:54:01:WU01:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
16:55:47:WU01:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
16:56:36:WU00:FS00:0xa4:Completed 1112500 out of 1250000 steps  (89%)
16:57:30:WU01:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
16:59:16:WU01:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
17:00:31:WU00:FS00:0xa4:Completed 1125000 out of 1250000 steps  (90%)
17:00:59:WU01:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
17:02:43:WU01:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
17:04:27:WU00:FS00:0xa4:Completed 1137500 out of 1250000 steps  (91%)
17:04:28:WU01:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
17:06:12:WU01:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
17:07:57:WU01:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
17:08:22:WU00:FS00:0xa4:Completed 1150000 out of 1250000 steps  (92%)
17:09:41:WU01:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
17:11:24:WU01:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
17:12:18:WU00:FS00:0xa4:Completed 1162500 out of 1250000 steps  (93%)
17:13:10:WU01:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
17:14:54:WU01:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
17:16:14:WU00:FS00:0xa4:Completed 1175000 out of 1250000 steps  (94%)
17:16:39:WU01:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
17:18:22:WU01:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
17:20:05:WU01:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
17:20:08:WU00:FS00:0xa4:Completed 1187500 out of 1250000 steps  (95%)
17:21:51:WU01:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
17:23:34:WU01:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
17:24:03:WU00:FS00:0xa4:Completed 1200000 out of 1250000 steps  (96%)
17:25:19:WU01:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
17:27:02:WU01:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
17:27:58:WU00:FS00:0xa4:Completed 1212500 out of 1250000 steps  (97%)
17:28:45:WU01:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
17:30:31:WU01:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
17:31:53:WU00:FS00:0xa4:Completed 1225000 out of 1250000 steps  (98%)
17:32:14:WU01:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
17:33:59:WU01:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
17:35:42:WU01:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
17:35:49:WU00:FS00:0xa4:Completed 1237500 out of 1250000 steps  (99%)
17:35:49:WU02:FS00:Connecting to 171.67.108.45:8080
17:35:50:WU02:FS00:Assigned to work server 155.247.166.219
17:35:50:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
17:35:50:WU02:FS00:Connecting to 155.247.166.219:8080
17:35:51:WU02:FS00:Downloading 338.92KiB
17:35:51:WU02:FS00:Download complete
17:35:51:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13721 run:83 clone:0 gen:13 core:0xa7 unit:0x000000100002894b58fd9059ed0da06b
17:37:25:WU01:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
17:39:10:WU01:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
17:39:43:WU00:FS00:0xa4:Completed 1250000 out of 1250000 steps  (100%)
17:39:44:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
17:39:54:WU00:FS00:0xa4:
17:39:54:WU00:FS00:0xa4:Finished Work Unit:
17:39:54:WU00:FS00:0xa4:- Reading up to 2939184 from "00/wudata_01.trr": Read 2939184
17:39:54:WU00:FS00:0xa4:trr file hash check passed.
17:39:54:WU00:FS00:0xa4:- Reading up to 161264 from "00/wudata_01.xtc": Read 161264
17:39:54:WU00:FS00:0xa4:xtc file hash check passed.
17:39:54:WU00:FS00:0xa4:edr file hash check passed.
17:39:54:WU00:FS00:0xa4:logfile size: 37359
17:39:54:WU00:FS00:0xa4:Leaving Run
17:39:56:WU00:FS00:0xa4:- Writing 3157507 bytes of core data to disk...
17:39:56:WU00:FS00:0xa4:Done: 3156995 -> 2573649 (compressed to 81.5 percent)
17:39:56:WU00:FS00:0xa4:  ... Done.
17:39:56:WU00:FS00:0xa4:- Shutting down core
17:39:56:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
17:39:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:39:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8636 run:5 clone:80 gen:119 core:0xa4 unit:0x0000007e0002894b582a281a65244fa8
17:39:57:WU00:FS00:Uploading 2.45MiB to 155.247.166.219
17:39:57:WU00:FS00:Connecting to 155.247.166.219:8080
17:39:57:WU02:FS00:Starting
17:39:57:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -np 6
17:39:57:WU02:FS00:Started FahCore on PID 9608
17:39:57:WU02:FS00:Core PID:7372
17:39:57:WU02:FS00:FahCore 0xa7 started
17:39:57:WU02:FS00:0xa7:*********************** Log Started 2017-05-15T17:39:57Z ***********************
17:39:57:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:39:57:WU02:FS00:0xa7:       Type: 0xa7
17:39:57:WU02:FS00:0xa7:       Core: Gromacs
17:39:57:WU02:FS00:0xa7:    Website: http://folding.stanford.edu/
17:39:57:WU02:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
17:39:57:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:39:57:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 704 -lifeline 9608 -checkpoint 15 -np 6
17:39:57:WU02:FS00:0xa7:     Config: <none>
17:39:57:WU02:FS00:0xa7:************************************ Build *************************************
17:39:57:WU02:FS00:0xa7:    Version: 0.0.11
17:39:57:WU02:FS00:0xa7:       Date: Sep 21 2016
17:39:57:WU02:FS00:0xa7:       Time: 01:43:48
17:39:57:WU02:FS00:0xa7: Repository: Git
17:39:57:WU02:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
17:39:57:WU02:FS00:0xa7:     Branch: master
17:39:57:WU02:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
17:39:57:WU02:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
17:39:57:WU02:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
17:39:57:WU02:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
17:39:57:WU02:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
17:39:57:WU02:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
17:39:57:WU02:FS00:0xa7:       Bits: 64
17:39:57:WU02:FS00:0xa7:       Mode: Release
17:39:57:WU02:FS00:0xa7:       SIMD: avx_256
17:39:57:WU02:FS00:0xa7:************************************ System ************************************
17:39:57:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
17:39:57:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
17:39:57:WU02:FS00:0xa7:       CPUs: 8
17:39:57:WU02:FS00:0xa7:     Memory: 15.97GiB
17:39:57:WU02:FS00:0xa7:Free Memory: 9.94GiB
17:39:57:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
17:39:57:WU02:FS00:0xa7: OS Version: 6.2
17:39:57:WU02:FS00:0xa7:Has Battery: false
17:39:57:WU02:FS00:0xa7: On Battery: false
17:39:57:WU02:FS00:0xa7: UTC Offset: -4
17:39:57:WU02:FS00:0xa7:        PID: 7372
17:39:57:WU02:FS00:0xa7:        CWD: C:\Users\DWS44\AppData\Roaming\FAHClient\work
17:39:57:WU02:FS00:0xa7:         OS: Windows 10 Pro
17:39:57:WU02:FS00:0xa7:    OS Arch: AMD64
17:39:57:WU02:FS00:0xa7:********************************************************************************
17:39:57:WU02:FS00:0xa7:Project: 13721 (Run 83, Clone 0, Gen 13)
17:39:57:WU02:FS00:0xa7:Unit: 0x000000100002894b58fd9059ed0da06b
17:39:57:WU02:FS00:0xa7:Reading tar file core.xml
17:39:57:WU02:FS00:0xa7:Reading tar file frame13.tpr
17:39:57:WU02:FS00:0xa7:Digital signatures verified
17:39:57:WU02:FS00:0xa7:Calling: mdrun -s frame13.tpr -o frame13.trr -cpt 15 -nt 6
17:39:57:WU02:FS00:0xa7:Steps: first=32500000 total=2500000
17:39:58:WU02:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
17:40:03:WU00:FS00:Upload 89.11%
17:40:04:WU00:FS00:Upload complete
17:40:04:WU00:FS00:Server responded WORK_ACK (400)
17:40:04:WU00:FS00:Final credit estimate, 4667.00 points
17:40:04:WU00:FS00:Cleaning up
17:40:53:WU01:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
17:42:27:WU02:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
17:42:38:WU01:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
17:44:21:WU01:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
17:44:56:WU02:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
17:46:05:WU01:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
17:47:26:WU02:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
17:47:50:WU01:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
17:49:33:WU01:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
17:49:55:WU02:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
17:51:18:WU01:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
17:52:24:WU02:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
17:53:01:WU01:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
17:54:44:WU01:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
17:54:54:WU02:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
17:56:30:WU01:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
17:57:23:WU02:FS00:0xa7:Completed 175000 out of 2500000 steps (7%)
17:58:13:WU01:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
17:59:52:WU02:FS00:0xa7:Completed 200000 out of 2500000 steps (8%)
17:59:58:WU01:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
18:01:42:WU01:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
18:02:22:WU02:FS00:0xa7:Completed 225000 out of 2500000 steps (9%)
18:03:26:WU01:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
18:05:01:WU02:FS00:0xa7:Completed 250000 out of 2500000 steps (10%)
18:05:13:WU01:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
18:05:15:326:127.0.0.1:New Web connection
18:06:57:WU01:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
18:07:31:WU02:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
18:08:43:WU01:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
18:10:01:WU02:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
18:10:26:WU01:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
18:12:09:WU01:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
18:12:31:WU02:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
18:13:54:WU01:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
18:15:01:WU02:FS00:0xa7:Completed 350000 out of 2500000 steps (14%)
18:15:38:WU01:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
18:17:23:WU01:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
18:17:30:WU02:FS00:0xa7:Completed 375000 out of 2500000 steps (15%)
18:19:06:WU01:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
18:20:00:WU02:FS00:0xa7:Completed 400000 out of 2500000 steps (16%)
18:20:50:WU01:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
18:22:29:WU02:FS00:0xa7:Completed 425000 out of 2500000 steps (17%)
18:22:35:WU01:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
18:24:18:WU01:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
18:24:58:WU02:FS00:0xa7:Completed 450000 out of 2500000 steps (18%)
18:26:04:WU01:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
18:27:27:WU02:FS00:0xa7:Completed 475000 out of 2500000 steps (19%)
18:27:47:WU01:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
18:29:30:WU01:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
18:29:56:WU02:FS00:0xa7:Completed 500000 out of 2500000 steps (20%)
18:31:16:WU01:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
18:32:25:WU02:FS00:0xa7:Completed 525000 out of 2500000 steps (21%)
18:32:59:WU01:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
18:34:44:WU01:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
18:34:54:WU02:FS00:0xa7:Completed 550000 out of 2500000 steps (22%)
18:36:27:WU01:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
18:37:23:WU02:FS00:0xa7:Completed 575000 out of 2500000 steps (23%)
18:38:11:WU01:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
18:39:51:WU02:FS00:0xa7:Completed 600000 out of 2500000 steps (24%)
18:39:56:WU01:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
18:41:40:WU01:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
18:42:20:WU02:FS00:0xa7:Completed 625000 out of 2500000 steps (25%)
18:43:25:WU01:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
18:44:49:WU02:FS00:0xa7:Completed 650000 out of 2500000 steps (26%)
18:45:08:WU01:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
18:46:52:WU01:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
18:47:18:WU02:FS00:0xa7:Completed 675000 out of 2500000 steps (27%)
18:48:37:WU01:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
18:49:47:WU02:FS00:0xa7:Completed 700000 out of 2500000 steps (28%)
18:50:20:WU01:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
18:52:05:WU01:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
18:52:16:WU02:FS00:0xa7:Completed 725000 out of 2500000 steps (29%)
18:53:48:WU01:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
18:54:45:WU02:FS00:0xa7:Completed 750000 out of 2500000 steps (30%)
18:55:31:WU01:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
18:57:14:WU02:FS00:0xa7:Completed 775000 out of 2500000 steps (31%)
18:57:16:WU01:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
18:58:59:WU01:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
18:59:43:WU02:FS00:0xa7:Completed 800000 out of 2500000 steps (32%)
19:00:44:WU01:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
19:02:12:WU02:FS00:0xa7:Completed 825000 out of 2500000 steps (33%)
19:02:27:WU01:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
19:04:11:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
19:04:42:WU02:FS00:0xa7:Completed 850000 out of 2500000 steps (34%)
19:05:56:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
19:07:11:WU02:FS00:0xa7:Completed 875000 out of 2500000 steps (35%)
19:07:39:WU01:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
19:09:24:WU01:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
19:09:40:WU02:FS00:0xa7:Completed 900000 out of 2500000 steps (36%)
19:11:07:WU01:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
19:12:09:WU02:FS00:0xa7:Completed 925000 out of 2500000 steps (37%)
19:12:50:WU01:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
19:14:35:WU01:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
19:14:38:WU02:FS00:0xa7:Completed 950000 out of 2500000 steps (38%)
19:16:18:WU01:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
19:17:07:WU02:FS00:0xa7:Completed 975000 out of 2500000 steps (39%)
19:18:04:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
19:18:37:352:127.0.0.1:New Web connection
19:19:38:WU02:FS00:0xa7:Completed 1000000 out of 2500000 steps (40%)
19:19:48:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
19:19:49:WU00:FS01:Connecting to 171.67.108.45:80
19:19:50:WU00:FS01:Assigned to work server 140.163.4.242
19:19:50:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.242
19:19:50:WU00:FS01:Connecting to 140.163.4.242:8080
19:19:50:WU00:FS01:Downloading 4.22MiB
19:19:52:WU00:FS01:Download complete
19:19:52:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11403 run:10 clone:39 gen:154 core:0x21 unit:0x000000cb8ca304f255ed4fa25a5606e4
19:21:31:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
19:21:33:WU01:FS01:0x21:Saving result file logfile_01.txt
19:21:33:WU01:FS01:0x21:Saving result file checkpointState.xml
19:21:35:WU01:FS01:0x21:Saving result file checkpt.crc
19:21:35:WU01:FS01:0x21:Saving result file log.txt
19:21:35:WU01:FS01:0x21:Saving result file positions.xtc
19:21:36:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
19:21:37:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:21:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11407 run:1 clone:13 gen:617 core:0x21 unit:0x0000034f8ca304f25686b24be1ce6bc2
19:21:37:WU01:FS01:Uploading 9.04MiB to 140.163.4.242
19:21:37:WU01:FS01:Connecting to 140.163.4.242:8080
19:21:37:WU00:FS01:Starting
19:21:37:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:21:37:WU00:FS01:Started FahCore on PID 9332
19:21:37:WU00:FS01:Core PID:5392
19:21:37:WU00:FS01:FahCore 0x21 started
19:21:38:WU00:FS01:0x21:*********************** Log Started 2017-05-15T19:21:37Z ***********************
19:21:38:WU00:FS01:0x21:Project: 11403 (Run 10, Clone 39, Gen 154)
19:21:38:WU00:FS01:0x21:Unit: 0x000000cb8ca304f255ed4fa25a5606e4
19:21:38:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:21:38:WU00:FS01:0x21:Machine: 1
19:21:38:WU00:FS01:0x21:Reading tar file core.xml
19:21:38:WU00:FS01:0x21:Reading tar file system.xml
19:21:38:WU00:FS01:0x21:Reading tar file integrator.xml
19:21:38:WU00:FS01:0x21:Reading tar file state.xml
19:21:38:WU00:FS01:0x21:Digital signatures verified
19:21:38:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:21:38:WU00:FS01:0x21:Version 0.0.18
19:21:43:WU01:FS01:Upload 24.88%
19:21:47:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
19:21:47:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:21:49:WU01:FS01:Upload 49.76%
19:21:55:WU01:FS01:Upload 73.95%
19:22:01:WU01:FS01:Upload 98.14%
19:22:06:WU01:FS01:Upload complete
19:22:06:WU01:FS01:Server responded WORK_ACK (400)
19:22:06:WU01:FS01:Final credit estimate, 92756.00 points
19:22:06:WU01:FS01:Cleaning up
19:22:12:WU02:FS00:0xa7:Completed 1025000 out of 2500000 steps (41%)
19:23:57:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
19:24:43:WU02:FS00:0xa7:Completed 1050000 out of 2500000 steps (42%)
19:26:08:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
19:27:16:WU02:FS00:0xa7:Completed 1075000 out of 2500000 steps (43%)
19:27:21:WARNING:FS01:Size of positions 4919 does not match topology 4916
19:28:21:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
19:29:48:WU02:FS00:0xa7:Completed 1100000 out of 2500000 steps (44%)
19:30:31:WU00:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
19:32:19:WU02:FS00:0xa7:Completed 1125000 out of 2500000 steps (45%)
19:32:41:WU00:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
19:32:49:WARNING:FS01:Size of positions 4919 does not match topology 4916
19:34:54:WU02:FS00:0xa7:Completed 1150000 out of 2500000 steps (46%)
19:34:55:WU00:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
19:37:05:WU00:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
19:37:27:WU02:FS00:0xa7:Completed 1175000 out of 2500000 steps (47%)
19:38:18:WARNING:FS01:Size of positions 4919 does not match topology 4916
19:39:18:WU00:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
19:39:58:WU02:FS00:0xa7:Completed 1200000 out of 2500000 steps (48%)
19:41:28:WU00:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
19:42:28:WU02:FS00:0xa7:Completed 1225000 out of 2500000 steps (49%)
19:43:38:WU00:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
19:43:45:WARNING:FS01:Size of positions 4919 does not match topology 4916
19:44:58:WU02:FS00:0xa7:Completed 1250000 out of 2500000 steps (50%)
19:45:49:WU00:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
19:47:28:WU02:FS00:0xa7:Completed 1275000 out of 2500000 steps (51%)
19:47:59:WU00:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
19:49:11:WARNING:FS01:Size of positions 4919 does not match topology 4916
19:49:58:WU02:FS00:0xa7:Completed 1300000 out of 2500000 steps (52%)
19:50:11:WU00:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
19:52:21:WU00:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
19:52:28:WU02:FS00:0xa7:Completed 1325000 out of 2500000 steps (53%)
19:54:31:WU00:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
19:54:38:WARNING:FS01:Size of positions 4919 does not match topology 4916
19:54:58:WU02:FS00:0xa7:Completed 1350000 out of 2500000 steps (54%)
19:56:43:WU00:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
19:57:28:WU02:FS00:0xa7:Completed 1375000 out of 2500000 steps (55%)
19:58:52:WU00:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
19:59:58:WU02:FS00:0xa7:Completed 1400000 out of 2500000 steps (56%)
20:00:05:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:01:05:WU00:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
20:02:28:WU02:FS00:0xa7:Completed 1425000 out of 2500000 steps (57%)
20:03:14:WU00:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
20:04:59:WU02:FS00:0xa7:Completed 1450000 out of 2500000 steps (58%)
20:05:25:WU00:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
20:05:32:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:07:33:WU02:FS00:0xa7:Completed 1475000 out of 2500000 steps (59%)
20:07:38:WU00:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
20:09:49:WU00:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
20:10:11:WU02:FS00:0xa7:Completed 1500000 out of 2500000 steps (60%)
20:11:02:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:12:03:WU00:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
20:12:48:WU02:FS00:0xa7:Completed 1525000 out of 2500000 steps (61%)
20:14:14:WU00:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
20:15:26:WU02:FS00:0xa7:Completed 1550000 out of 2500000 steps (62%)
20:16:25:WU00:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
20:16:32:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:18:01:WU02:FS00:0xa7:Completed 1575000 out of 2500000 steps (63%)
20:18:39:WU00:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
20:20:34:WU02:FS00:0xa7:Completed 1600000 out of 2500000 steps (64%)
20:20:50:WU00:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
20:22:02:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:23:04:WU00:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
20:23:09:WU02:FS00:0xa7:Completed 1625000 out of 2500000 steps (65%)
20:25:15:WU00:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
20:25:45:WU02:FS00:0xa7:Completed 1650000 out of 2500000 steps (66%)
20:27:27:WU00:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
20:27:34:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:28:20:WU02:FS00:0xa7:Completed 1675000 out of 2500000 steps (67%)
20:29:41:WU00:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
20:30:56:WU02:FS00:0xa7:Completed 1700000 out of 2500000 steps (68%)
20:31:52:WU00:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
20:33:05:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:33:31:WU02:FS00:0xa7:Completed 1725000 out of 2500000 steps (69%)
20:34:05:WU00:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
20:36:06:WU02:FS00:0xa7:Completed 1750000 out of 2500000 steps (70%)
20:36:17:WU00:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
20:38:28:WU00:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
20:38:35:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:38:42:WU02:FS00:0xa7:Completed 1775000 out of 2500000 steps (71%)
20:40:42:WU00:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
20:41:19:WU02:FS00:0xa7:Completed 1800000 out of 2500000 steps (72%)
20:42:53:WU00:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
20:43:53:WU02:FS00:0xa7:Completed 1825000 out of 2500000 steps (73%)
20:44:06:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:45:07:WU00:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
20:46:30:WU02:FS00:0xa7:Completed 1850000 out of 2500000 steps (74%)
20:47:18:WU00:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
20:49:02:WU02:FS00:0xa7:Completed 1875000 out of 2500000 steps (75%)
20:49:28:WU00:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
20:49:36:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:51:37:WU02:FS00:0xa7:Completed 1900000 out of 2500000 steps (76%)
20:51:42:WU00:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
20:53:53:WU00:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
20:54:11:WU02:FS00:0xa7:Completed 1925000 out of 2500000 steps (77%)
20:55:05:WARNING:FS01:Size of positions 4919 does not match topology 4916
20:56:06:WU00:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
20:56:45:WU02:FS00:0xa7:Completed 1950000 out of 2500000 steps (78%)
20:58:17:WU00:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
20:59:18:WU02:FS00:0xa7:Completed 1975000 out of 2500000 steps (79%)
21:00:27:WU00:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
21:00:35:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:01:50:WU02:FS00:0xa7:Completed 2000000 out of 2500000 steps (80%)
21:02:40:WU00:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
21:04:21:WU02:FS00:0xa7:Completed 2025000 out of 2500000 steps (81%)
21:04:51:WU00:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
21:06:03:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:06:52:WU02:FS00:0xa7:Completed 2050000 out of 2500000 steps (82%)
21:07:03:WU00:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
21:09:14:WU00:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
21:09:25:WU02:FS00:0xa7:Completed 2075000 out of 2500000 steps (83%)
21:11:24:WU00:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
21:11:31:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:11:56:WU02:FS00:0xa7:Completed 2100000 out of 2500000 steps (84%)
21:13:37:WU00:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
21:14:26:WU02:FS00:0xa7:Completed 2125000 out of 2500000 steps (85%)
21:15:47:WU00:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
21:16:56:WU02:FS00:0xa7:Completed 2150000 out of 2500000 steps (86%)
21:16:59:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:17:58:WU00:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
21:19:11:380:127.0.0.1:New Web connection
21:19:26:WU02:FS00:0xa7:Completed 2175000 out of 2500000 steps (87%)
21:20:03:WU00:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
21:21:58:WU02:FS00:0xa7:Completed 2200000 out of 2500000 steps (88%)
21:22:08:WU00:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
21:22:15:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:24:15:WU00:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
21:24:30:WU02:FS00:0xa7:Completed 2225000 out of 2500000 steps (89%)
21:26:22:WU00:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
21:27:04:WU02:FS00:0xa7:Completed 2250000 out of 2500000 steps (90%)
21:27:32:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:28:31:WU00:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
21:29:47:WU02:FS00:0xa7:Completed 2275000 out of 2500000 steps (91%)
21:30:38:WU00:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
21:32:22:WU02:FS00:0xa7:Completed 2300000 out of 2500000 steps (92%)
21:32:44:WU00:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
21:32:51:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:34:52:WU00:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
21:34:57:WU02:FS00:0xa7:Completed 2325000 out of 2500000 steps (93%)
21:36:57:WU00:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
21:37:29:WU02:FS00:0xa7:Completed 2350000 out of 2500000 steps (94%)
21:38:07:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:39:05:WU00:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
21:40:00:WU02:FS00:0xa7:Completed 2375000 out of 2500000 steps (95%)
21:41:10:WU00:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
21:42:33:WU02:FS00:0xa7:Completed 2400000 out of 2500000 steps (96%)
21:43:16:WU00:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
21:43:23:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:45:09:WU02:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
21:45:26:WU00:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
21:47:33:WU00:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
21:47:47:WU02:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
21:48:44:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:49:43:WU00:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
21:50:28:WU02:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
21:50:29:WU01:FS00:Connecting to 171.67.108.45:8080
21:50:30:WU01:FS00:Assigned to work server 171.67.108.101
21:50:30:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.67.108.101
21:50:30:WU01:FS00:Connecting to 171.67.108.101:8080
21:50:30:ERROR:WU01:FS00:Exception: Server did not assign work unit
21:50:31:WU01:FS00:Connecting to 171.67.108.45:8080
21:50:31:WU01:FS00:Assigned to work server 128.252.203.4
21:50:31:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 128.252.203.4
21:50:31:WU01:FS00:Connecting to 128.252.203.4:8080
21:50:31:WU01:FS00:Downloading 7.32MiB
21:50:34:WU01:FS00:Download complete
21:50:34:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13804 run:0 clone:4639 gen:0 core:0xa7 unit:0x0000000180fccb04591a030be12c7922
21:51:51:WU00:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
21:53:09:WU02:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
21:53:09:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
21:53:09:WU02:FS00:0xa7:Saving result file frame13.trr
21:53:09:WU02:FS00:0xa7:Saving result file md.log
21:53:09:WU02:FS00:0xa7:Saving result file science.log
21:53:09:WU02:FS00:0xa7:Saving result file traj_comp.xtc
21:53:10:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:53:10:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:53:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13721 run:83 clone:0 gen:13 core:0xa7 unit:0x000000100002894b58fd9059ed0da06b
21:53:10:WU02:FS00:Uploading 4.26MiB to 155.247.166.219
21:53:10:WU01:FS00:Starting
21:53:10:WU02:FS00:Connecting to 155.247.166.219:8080
21:53:10:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DWS44\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 11256 -checkpoint 15 -np 6
21:53:10:WU01:FS00:Started FahCore on PID 9852
21:53:10:WU01:FS00:Core PID:10300
21:53:10:WU01:FS00:FahCore 0xa7 started
21:53:11:WU01:FS00:0xa7:*********************** Log Started 2017-05-15T21:53:11Z ***********************
21:53:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:53:11:WU01:FS00:0xa7:       Type: 0xa7
21:53:11:WU01:FS00:0xa7:       Core: Gromacs
21:53:11:WU01:FS00:0xa7:    Website: http://folding.stanford.edu/
21:53:11:WU01:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
21:53:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:53:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 9852 -checkpoint 15 -np 6
21:53:11:WU01:FS00:0xa7:     Config: <none>
21:53:11:WU01:FS00:0xa7:************************************ Build *************************************
21:53:11:WU01:FS00:0xa7:    Version: 0.0.11
21:53:11:WU01:FS00:0xa7:       Date: Sep 21 2016
21:53:11:WU01:FS00:0xa7:       Time: 01:43:48
21:53:11:WU01:FS00:0xa7: Repository: Git
21:53:11:WU01:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
21:53:11:WU01:FS00:0xa7:     Branch: master
21:53:11:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
21:53:11:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
21:53:11:WU01:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
21:53:11:WU01:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
21:53:11:WU01:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
21:53:11:WU01:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
21:53:11:WU01:FS00:0xa7:       Bits: 64
21:53:11:WU01:FS00:0xa7:       Mode: Release
21:53:11:WU01:FS00:0xa7:       SIMD: avx_256
21:53:11:WU01:FS00:0xa7:************************************ System ************************************
21:53:11:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
21:53:11:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
21:53:11:WU01:FS00:0xa7:       CPUs: 8
21:53:11:WU01:FS00:0xa7:     Memory: 15.97GiB
21:53:11:WU01:FS00:0xa7:Free Memory: 9.14GiB
21:53:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:53:11:WU01:FS00:0xa7: OS Version: 6.2
21:53:11:WU01:FS00:0xa7:Has Battery: false
21:53:11:WU01:FS00:0xa7: On Battery: false
21:53:11:WU01:FS00:0xa7: UTC Offset: -4
21:53:11:WU01:FS00:0xa7:        PID: 10300
21:53:11:WU01:FS00:0xa7:        CWD: C:\Users\DWS44\AppData\Roaming\FAHClient\work
21:53:11:WU01:FS00:0xa7:         OS: Windows 10 Pro
21:53:11:WU01:FS00:0xa7:    OS Arch: AMD64
21:53:11:WU01:FS00:0xa7:********************************************************************************
21:53:11:WU01:FS00:0xa7:Project: 13804 (Run 0, Clone 4639, Gen 0)
21:53:11:WU01:FS00:0xa7:Unit: 0x0000000180fccb04591a030be12c7922
21:53:11:WU01:FS00:0xa7:Reading tar file core.xml
21:53:11:WU01:FS00:0xa7:Reading tar file frame0.tpr
21:53:11:WU01:FS00:0xa7:Digital signatures verified
21:53:11:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpt 15 -nt 6
21:53:11:WU01:FS00:0xa7:Steps: first=0 total=250000
21:53:14:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:53:16:WU02:FS00:Upload 45.49%
21:53:22:WU02:FS00:Upload 99.78%
21:53:22:WU02:FS00:Upload complete
21:53:23:WU02:FS00:Server responded WORK_ACK (400)
21:53:23:WU02:FS00:Final credit estimate, 3252.00 points
21:53:23:WU02:FS00:Cleaning up
21:53:58:WU00:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
21:54:05:WARNING:FS01:Size of positions 4919 does not match topology 4916
21:56:09:WU00:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
21:58:08:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:58:15:WU00:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
21:59:25:WARNING:FS01:Size of positions 4919 does not match topology 4916
22:00:24:WU00:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
22:02:32:WU00:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
22:03:02:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
22:04:39:WU00:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
22:04:46:WARNING:FS01:Size of positions 4919 does not match topology 4916
Guess that turned into a long post, didn't it. :confused: Thanks if you read it all!
Reactions: Foxbat
To update...the whole thing seemed to go south overnight. Woke up this morning to find very little activity overnight, and the client was down to reporting 200K PPD. I decided to try the same driver EatMyVolts suggested to Scott just before my large post and rebooted. So far, it seems to be behaving a little better again. It now reports "GPUs 1" in Sys Info tab, and it settled back to reporting ~700K PPD. Not that 700K PPD is anything to sneeze at, I still wonder how it did so well on the first day, compared to how its running since.
Reactions: Foxbat
The word on the FAH support forum is to still stay with 373.06 (which I believe translates to 21.21.13.7306). That version does support the 1070. Later versions give lower ppd. Step back to this earlier version any you should see more points, I know when I did they went up.
I'm using 373.06 on my Win10 machine (1070 & 970) and 370.28 on my Linux mint machine (1060).
Well after months of getting crappy points and paying the little extra power bill for the Windows machine with the 1070 running and not getting very far, I am back for now. I was getting 700k-800k a day at first and then everything went down hill. I tried over the months, re-installing FAH, trying different versions of the NVIDIA drivers, etc, etc. Most of the time though looking at the logs, it would go through a WU and then say server didn't like the results and dumped it. Grrr.
I didn't give up though it has been folding 24/7, but 90% would get dumped.
I tried 373.06 in the past and it would start to fold and fail. So after your post Mr. Volts I tried again yesterday. Same thing it went to about 10% and would fail, restart and same again.
Before I thought well something with my machine just don't like that one and gave up on it. This time however, after reading what you said, that this seems to be the choice on the folding forums. Also, didn't see other people getting a fail.
....so I once again wiped out the FAH client and the the driver. Did a fresh install of the driver 373.06. Stop re-boot machine for good measure. Then re-install FAH. Tried the newest beta but that is giving me fits, it has before two the one ending in .16. Not sure why, but it is beta. So went with .15 beta. Fired up a WU and 10% and FAIL!!! ARGH!!! Okay, before I would say oh well and try another driver, this time I just thought well, re-boot again and see.
Well I'll be, it has been folding for 24 hours and no WU has been rejected. So for sure 376.06 is the one to use. At least if you have a 10XX series. My 970 seams to be running fine in my main machine forever and I allow it to get the latest and greatest drivers as they come out. So maybe I can stop wasting GPU cycles now. :D
Reactions: Foxbat
Hope it continues to work for you, it's done well by me. I've never run the beta client - this retired programmer knows first hand about beta releases. :boom
Disappearance - 103 W AMC1/Spaceway 1/DirecTV 10/DirecTV 12
Software Update Coming
