try using a powered hub between your drives and hopper. This is the way I have my WD and never had any problems. You have 2 drives and are asking a lot of from the usb ports of the hopper. Normally a usb port can provide only 500 ma. I don't the the power supply on hopper has that much in power reserves.
That's just the model number but if you actually looked at the label on the bottom of the item, there is a more complete part number... The one I have is a -C which I think is Revision C, that one doesn't work with the Hopper 3, works fine with the Hopper 1. I had to use the Unitek Y-3322A USB 3.0 to IDE+SATA Converter https://www.unitek-products.com/en/product_detail.php?id=196 before it will work.
I tried that, used a powered USB hub, and tried it with two separate drives, one at a time. Still have the problem. Also, my main drive is a destktop external USB HD and uses it's own power supply, so that one doesn't try to get powered by the H3. And it has the same problem.
So - one drive is a WD Mybook Destop External USB drive with it's own power - every morning is no longer recognized by the H3. Tried a Seagate USB3.0 drive connected via a powered USB Hub - every morning no longer recognized by the H3.
It's something that happens in the early morning (does the H3 do some kind of reset at 3 am or so?) I can do my red button reboot (usually takes two in a row) and get the EHD recognized at, say, 6:30 AM, and it will stay recognized all day and night long, say, to midnight or 1. But sometime between then and a few hours later (say, between 1:30 am and 5 am) something happens to lose the recognition of the EHD. Every day. I haven't had it recognized in the morning when I get up in at least a couple of months.
Thermaltake model number ST0005U
There should be something after the ST0005U like ST0005U-x where x is some letter that follows it.
Nope. P/N is ST0005U only. S/N ST0005UHK010016. I don't think this has anything to do it it. The issue is not specific to the model or make of the dock.
Yes, the USB interface chipset makes a difference. But both this BlackX dock and the white "Plugable" brand USB 3.0 dock (which uses the ASMedia 1051E chipset and firmware with UASP and BOT support) work with the H3. The file index is read just fine and I can read and write to both of them with no problem. Of course, the BlackX is USB 2.0 and the Pluggable is USB 3.0. The problem is that early each morning the Hopper looses sight of the EHD requiring a receiver reboot to see it again.
I thought people from the Dish tech team were reading here. Is that not the case?
haha.... I guess they think that users don't know enough or that too many users would annoy them. They must have a beta test team for new firmware and a punch list of priorities for each rev. Well, if anyone knows how to get through I hope they'll pipe up.My assumption is that if no one from Dish acknowledges they are reading an issue/problem and are working on it, they aren't.
There have been enough reports of this exact problem with people with very different EHD setups that it is clearly an H3 bug. May be a challenge for Dish to pin it down if some people don't have the problem. I wonder how we could let Dish know about this? If individuals call we get a tech service rep who simply reads off of a branching what to do sheet/screen and they assume the problem is specific to the customer. I'd really like some people high up in Dish technical to know many of us have this bug so they can try to fix it.
Hmm. Just saw that my H3 updated to U347 at 12:39 AM this morning (4/12/17.)
I also noticed that my EHD did NOT dissappear this morning the way it has EVERY morning for a long time? Coincidence? I hope not!
Limited time offer
