Can an ATSC TV without an NTSC,function be manufactured, marketed and or imported into the united states under the FCC requirements.
Congress has mandated that after February 17, 2009, television stations across the country must transmit only in digital signals, and may no longer transmit analog signals. After that date, consumers who rely on antennas (including outside antennas and "rabbit ears") to receive broadcast signals on TV sets having only analog tuners will need to obtain separate digital-to-analog set-top converter boxes to watch over-the-air TV.
The Commission's DTV-related enforcement efforts have focused on protecting consumers by enforcing our rules as this transition takes place. To date, the Commission has taken enforcement action in several areas: (1) the prohibition on the importation and shipment of television receivers without integrated digital tuners; (2) the labeling requirement for television receivers incapable of receiving over-the-air digital signals without a converter box; (3) the requirement that digital television receivers possess full V-Chip functionality, including not only the ability to block offensive programming, but also the ability to adjust to a future rating system; and (4) the DTV consumer education requirements for broadcasters, telecom carriers, cable operators, manufacturers, and others.
Yes. There are quite a few DVRs and standalone tuners that don't support NTSC. This includes the current OTA equipment from Channel Master. While NTSC tuners are dirt cheap, producing a DVR (or a convertible tuner) that can record an NTSC program is not.Can an ATSC TV without an NTSC,function be manufactured, marketed and or imported into the united states under the FCC requirements.
The 7001 was discontinued some time ago. It was originally offered at a time when NTSC was the official standard and there was a need for DTV converter boxes.
If the new channels you're receiving have .1 associated with them, they are ATSC channels and you're wasting your time fretting about about NTSC.
He asked if TVs without NTSC could be offered. Supposing the condition that the TV features NTSC and arguing the reverse isn't logical.Uh, he asked about TVs, not cable boxes, standalone tuners, etc. That is why I answered as I did.
With this in mind, it would appear that the current plan is to cease NTSC broadcasts no later than the Summer of 2021 (assuming those stations aren't forced to do something earlier by the repack).LPTV rules said:The FCC has established a new deadline for the termination of all analog operations by LPTV stations. That date is dependent upon the completion of the Commission's incentive auction, which involves a repacking process that will displace some LPTV stations. Therefore, the Commission has determined to allow LPTV stations to wait until the incentive auction is complete before transitioning to digital. LPTV stations will have 12 months from the completion of the 39-month post-incentive auction transition (51 months from the completion of the incentive auction) to cease analog operations and begin operating in digital, at which point analog television will no longer exist in the United States. Until that time, LPTV stations may continue to operate their analog facilities.
Limited time offer
