NYDutch SatelliteGuys Master Original poster Pub Member / Supporter Dec 28, 2013 9,222 18,420 Where our wheels go Feb 8, 2017 #1 HWS hooked to a 1K4 WA DPP LNB. To add a 300 as a wing dish for 61.5, does the wing need a DP LNB vs a legacy?
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Feb 9, 2017 #2 You can't mix DP and Legacy LNBs, all must be DP.
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Feb 9, 2017 #3 You might want to repost asking if you can do 4 satellites on a HWS.
Voyager6 *Cancelled* Pub Member / Supporter Lifetime Supporter Nov 30, 2005 17,097 5,324 Wokeville Feb 9, 2017 #4 boba said: You might want to repost asking if you can do 4 satellites on a HWS. Click to expand... No problem with the four sats but you do need the DP LNB. Reactions: pattykay
NYDutch SatelliteGuys Master Original poster Pub Member / Supporter Dec 28, 2013 9,222 18,420 Where our wheels go Feb 9, 2017 #5 Voyager6 said: No problem with the four sats but you do need the DP LNB. Click to expand... I was pretty sure I needed a DP LNB, but I wanted to confirm it before I chase one down. Thanks!
NYDutch SatelliteGuys Master Original poster Pub Member / Supporter Dec 28, 2013 9,222 18,420 Where our wheels go Feb 9, 2017 #6 boba said: You can't mix DP and Legacy LNBs, all must be DP. Click to expand... Thanks! That's the info I was looking for...
