52.0 Remote - How to program without Hopper. | SatelliteGuys.US
Dish Sub 2015
218
47
The Matrix
Is there a way 52.0 dish Remote to be programed without Hopper to control a TV.
That is a good question. With the older remote controls you could do that. Since these 52.0 remote controls are programmed via the hopper , 4k joey ,2.0 joey, I would say no, that they would be able to work with a tv by itself. But I haven't tried to do it myself.
As Mike said, the Hopper is what programs the remote. If you don't have a Hopper you can't program the remote. Or at least I doubt that you can since the older units most likely don't have the proper software to do it.
Sent from my samus using Tapatalk
Reactions: MikeD-C05
Yes, you can, but you need to know the 4 digit code. It is programmed the same way as all remotes before. I believe something like Vizio would be 2505.
Thats great, what's are the steps getting the remote in programmable mode. I tried holding TV button down, but "TV" light did not stay on like the older remotes?
How long did you hold it down for? I did it on the 50.0, but I noticed I had to hold down the tv button significantly longer than on previous remotes.
21.0 IR/UHF remote seems to be dead
No more discounts on Starz?
