I currently have a HR24-100 and three HR25-500's
If i upgrade to 4K and trade in the HR24-100 will the HR25-500's still work?
It should, not sure why it wouldn't.I currently have a HR24-100 and three HR25-500's
The current AT&T/DirecTV 4K is a two-piece setup - a HR54 & a C61.I currently have a HR24-100 and three HR25-500's
This, but ONLY if youre getting a reverse band lnb or a swm 16 and a kaku, the swim three supports 8 tuners, the 4k genie has 7, while the hr24 has 2, the h25 has 1, a 4k genie will overload your swm3 and you will get prompts to disconnect the extra tuners. It won't happen automatically, but it will once you hit the limit.Claude Greyou're post: 3952925 said:Why trade in an HR24? Trade in one of the H25's
For myself, I actually recently upgraded to a 4K Reverse Band 5 LNB. (Previously had a 4K Reverse Band 3 LNB.) It was the only one on the guy's truck.This, but ONLY if youre getting a reverse band lnb or a swm 16 and a kaku, the swim three supports 8 tuners, the 4k genie has 7, while the hr24 has 2, the h25 has 1, a 4k genie will overload your swm3 and you will get prompts to disconnect the extra tuners. It won't happen automatically, but it will once you hit the limit.
I usually only see this in 5 or 6 box installs, but it does happen.
1 4k channel uses 2 tuners, every recording uses 1, every other channel being watched uses 1.
Even as a tech, I'mstill not sure if the reverse band aka digital swm supports 13 or 18 tuners, but it's at least 13
Nice. Now you get an extra 4 or 5 Spanish channels in the 400s.For myself, I actually recently upgraded to a 4K Reverse Band 5 LNB. (Previously had a 4K Reverse Band 3 LNB.) It was the only one on the guy's truck.
I couldn't care less about the Spanish channels (except that Latinas often happen to be gorgeous). I wanted all the SonicTap channels, especially for the fact that channel 815 (only on the 119 satellite) gets Christmas music a few weeks earlier than channel 801.Nice. Now you get an extra 4 or 5 Spanish channels in the 400s.
So I like it, big deal. And so I like Christmas music; it happens to be my favorite holiday.You can't be serious.
I am shocked that someone listens to the terrible audio on Sonic Tap. And Christmas music??
Limited time offer
