New install | SatelliteGuys.US
New install
sgrace68
9
3
Hi - just had a new HR54/4K install done. Everything is great but can someone tell me how to program the RC73 remote volume button to my Marantz SR7005?
I noticed no difference except on 4K channels, they took a little longer to load.
Menu>settings & help>settings>remote control>program remote>audio device>find receiver>change the setting for "change volume lock" to use audio device.
Press menu, then go into settings and help on the screen, then on the left screen press remote control, then you will see the screen that says Program Remote, then press Audio devices, find your Audio receiver in the menu that will program the audio in your receiver and remote.
Must be the 54 is different- when the program remote comes up, it has program tv and done only - frustrating- but thanks for trying...
On Demand Not Working
Favorite Channel List
