HopperGo Reset Button On Unit | SatelliteGuys.US
rlee22
197
25
Lewisport, Ky
Does anyone know how do you reset hoppergo to default settings from the unit , not from Dishanywhere
I have tried to hold button down for a few seconds and then tried for 30 seconds, but the unit still does not reset
is there a proper way to reset ?
Isn't there a tiny hole for a pin next to power button?
It's on the back... labeled reset. :)
Yes, the button on back of the hoppergo is the button I am pressing.
I have tried to have the hoppergo on then pressing for a few seconds and then turn off then trying to do same thing but holding reset for 30 seconds , but it is still not resetting , the wifi password for the hoppergo is not going back to the default password which is myHopperGO
I thought it was HopperGo.
Nope... myHopperGo. Hmmm
Try 60 seconds. :(
If you are avoiding a reset through Dishanywhere app due to forgotten password you can skip the password by connecting to the H3 first.
In case you skipped the fun above.
I just know you are gonna come back and say "but I'm out of town so I can't connect to the H3". In 3.2.1.... :)
Well if this is a password issue a new password can be entered w/o knowing the old one if connected to the H3. No reset needed.
Yes, I would like to know how to reset the HopperGo unit, without being hooked to hopper 3 or dishanywhere
there is a reset button on back of the HopperGo and I would like to know what you have to do to do a reset of the unit.
Cancelled Service
Missing Ports
