you believe incorrectlyI believe that the receiver will only format them to 2TB.
It would be nice if Dish had an official statement on this.... (hint, hint, hint, DIRT)
Thanks for your reply and help.....MikeI was able to finally get a 3TB drive to work, but I had to jump through alot of hoops to make it so. When I first plugged it in, I couldn't get it to work at all. It said it was formatting, but sometime after 36 hours I decided it was stuck. I ended up cloning one of my smaller drives to this new drive in order for it to be recognized by the Hopper. That was a start, but I was only getting use of a portion of the drive. After much trouble, I was finally able to expand one of the partitions which allowed me to use the rest of the available space.
If I had to do it all over again, I would just buy the 2TB and be done. Not having realized all this before I bought it and started the process, I kept at it until I finally got it to work. Some have been lucky I guess where they get it to work right out of the box. That wasn't my experience. I'm glad I finally got it to work, but I spent alot of time trying to figure it out. Just my 2 cents.
On another note, the "official line" about no USB drives that don't have their own independent power supply is incorrect, also. I copied my external hard drive (a W.D. My Book Essential 2TB that has 50-60 movies I wanted to keep/backup), over to a Seagate Backup Plus Slim 2TBb portable External Hard drive using Macrium Reflect cloning software. The Seagate is powered off the Hopper 3 hub (no external power supply) and works great. The software makes a "bit-by-bit" clone, so it doesn't care what encryption method is used by the Hopper. I can't, of course, look at the movies that are stored, but I can backup the movies I have. The real reason I switched over to the Seagate was because I kept getting the "media on USB disconnected/connected" message when nothing had been disconnected. I no longer get that message.
The 'official line' requiring self powered EHD's is to preserve the Hopper power supply because over time the extra draw on the USB line to power the EHD may cause damage to the Hopper power supply and cause the Hopper to fail prematurely.
Limited time offer
