Hard to describe Hopper problem - now with video. | SatelliteGuys.US
DW7000
6
Denver, CO
Hi!
I tried to explain this problem I've been having yesterday, but it's hard to explain in writing. The glitch just happened yet again, so I thought I would record it to show you guys. This is a brand new Hopper with Sling I just received as a replacement, as my previous Hopper's HDD failed.
Reactions: jimijam28
I've reported this same behavior several times. At least your picture came back. I have to do a front panel Red Button Reset. This and the 1am "unannounced", "uncontrollable" nightly reset/update. Just a few in many . . .
I had similar problems. Screen went blank, then nothing worked... channel up/down, DVR functions. Had to reboot or, if I waited the H3 auto rebooted. Solution was a H3 replacement with all the B.S. that causes.
With the replacement I've had only one event... screen freeze with sound continuing, then the left side of picture went to a vertical blind effect in green. Auto reboot again fixed the issue. Early adopter issues!
In case anyone is curious about the resolution of this, I ended up getting in touch with StephenH of the DIRT team. He was super helpful. I found out that I was eligible for an upgrade from HWS to H3, so I'm just going to go that route, rather than get another replacement HWS.
This reminds me of a James Bond scene where he is taking off in a helicopter and there's a priest giving him a "final" blessing.
Netflix on 4k Joey.....
Unable to create a daily manual recording schedule on Hopper3
