Sports bar mode is here | Page 2 | SatelliteGuys.US
Everything looking good over here!
It's still not showing up for me...
Do you have the newest software update? Its U307. When you start up your H3, press the home button twice, then go to settings, then diagnostics and look for the software version of your H3. If its not showing u307, you wont have the sports bar feature. Make sure all of your receivers are off at the same time and that should prompt an upgrade, although I do not know what time it will show up (mine showed up at 407am). Hope it helps.
Sports Bar mode seems to be working well on my Hopper 3. I really wish it was possible to use this feature on the 4K Joey, but at this point I would just settle for working PIP.
I've had every issue mentioned, Blank screens, Dropping audio, even a full on H3 freeze up,
After about 4 separate reboots, it started working like it should.
DISH Comcast Dispute?
Joey 2.0 Joey4K on Hopper 3 bugs
