Still a little tweaking to do on heat control but not real bad. First batch of WUs is running out at 275,000 PPD
A side exhaust fan down by the two video cards would probably take care of any heat issues. Nice, clean looking rig.Still a little tweaking to do on heat control but not real bad. First batch of WUs is running out at 275,000 PPD
In two hours I will complete my 100th WU and with that unit I hit the 1M point mark too![]()
Well, the T7400 did not like working with the 980 and 750ti. It keeps rebooting. I need to review the error logs to try and find out what is causing the problem. In the mean time, I have removed the 750ti and will put it in another machine.
I use MSI Afterburner to monitor the video cards. The 980 was running at 68C and the 750 at 60C when the last reboot occurred. I also set a fan profile for each video card to keep them cool. The 750 is bus powered and does not need additional power. The T7400 has been rock steady otherwise with just the 980 in it.
I will try this when I get the chance. Thanks. I didn't think about the different driver for the 750ti.Try this.
Install just the 750Ti and un-install any graphics drivers and go to the website and in selecting the driver, tell it you have a 750Ti.
Download and install. Re-boot see how it runs for a few hours.
Then put the 980 back in, leaving drivers as is. See what that does.
I have a 970 and a 770. Mine was not rebooting but just acting real sluggish, like it was a computer from the 90's.
Swapped cards around, tried this, tried that...then I decided to just put in one card at a time and see what happened.
That is when I discovered it would not fold with the 900 series drivers with the 770.
Did what I said above and now it is humming along.
I briefly thought about it and then forgot...and assumed they would be the same.I will try this when I get the chance. Thanks. I didn't think about the different driver for the 750ti.
Not all that surprising. Each GPU client imposes a load on the CPU. Two GPU's plus the CPU client should have the CPU running flat out. There's the explanation for the heat. The fact that the CPU is no longer maxed out could mean that the GPU's get services quicker and therefore produce more. I may be wrong but there is logic (and lore (BS?) that I've accumulated over the years) there.I have been trying some different configurations and I think I have it all set for now. I am running only three GPU clients on the two computers. I discontinued the CPU client in the PC with the two 960s. Oddly enough the PPD went up and my temps went downIt looks like I'll be in the 350,000 PPD range with the three clients.
Sure, I post that, fully expecting the update to come through and king3pj would tick over the next milestone. Instead he appears to have pulled the plug on his production. Zippo all day.Congratulations to king3pj for passing 6,000,000 Points! (okay, maybe a little early...)
Sure, I post that, fully expecting the update to come through and king3pj would tick over the next milestone. Instead he appears to have pulled the plug on his production. Zippo all day.![]()
Limited time offer
