Update Pulled | Page 8 | SatelliteGuys.US
Update Pulled
Done... I think it was faster than last time.
Ethernet transfer is "available" in the menus. Can't say if it works though, but it's there.
You can access your EHD with this version you have to go into menu-dvr-sources-click EHD.You can play downloads from your EHD without transferring them back to the HWS.Is that new or could you do that before?
And I'm liking the Netflix integration
I hope Netflix operates better. When I try and use it through Dish, it routinely gets stuck at 25% or 81% (so often, I know the specific percentages) and never starts. Connecting by Ethernet made no difference over WiFi. I sometimes thought I could blame Time Warner for throttling Netflix but we can use our TV's Netflix app flawlessly. No one else in my family uses the Dish way because of this....
Software is u202 with 5 different versions for Joey so far so good . The more I mess around with it the faster it is responding.
My hopper is up and running. Everything seems to be very fast as it gets settled down initially. I wasn't able to let my joeys. install their new builds(damn family). And I have good news. Super Joey and Joey are both working perfectly with the hopper even though they are still on their old software. Paired perfectly with the hopper. Good job dish.
Reactions: Patrick Smith
Just tested Netflix. Still twitchy though it does work. But still nothing but stereo sound. But it still makes search a bit better because if I find a show that isn't available on Dish and it shows on Netflix, I can shift to a box that does Netflix better.
Sent from my iPad Pro using Tapatalk
Hopper 3 Postponed (Not really)
Yet another H3 question...
