True - it may get some tech-savvy Directv customers to switch though. Same with cableco customers. Most of them are, in case you've seen the commercial, "settlers". They grew up with cable and have always had cable and don't give any thought to other options. Certainly can't drop cable and switch to "the dish" because "it goes out when it rains".While this HOPPER looks fantastic, I don't think this is going to bring the subscriber numbers up either.
The cracks appear. How long before theHave you seen any Wally specs? I think Vivek mentioned in your interview that it could also stream and takes an EHD like a 211. I wonder if it can also stream from home media. Too bad it only has 1 sat tuner, or it would be a good candidate to replace my 612's.
I hope they do, Believe me!Some guy who says he is an installer on the dish forum says they already have a whole warehouse full of them. I just got off the phone with my warehouse they have 0.
Maybe, maybe not, but it might keep up retention. Although the Hopper already rocks.Well, I've already heard late January, and Late 1st Quarter.
So I'm placing my bet on SOON.
Sent from my SAMSUNG-SM-G900A using Tapatalk
With moca 2.0 is it the same distance limitations as moca 1.1?
16 tuners WoW that nice but it all ready a BIG useless paper weight as the spec don't show any listing for HDMI 1.x, And sad part is the new Dish Hopper 4k along with Joey 4k you need all new a TV or Monitor that support 4k and has to have HDMI 2.x port and I wouldn't be at all surprise if some of premium channels will req HDPC 2.2 support in order for them to work.
To me this going to be a big failure unless you got income to burn on all gear.
You can ship pallets of these, anywhere in the country, in less than (7) days. There's no hurry... Then again, supposedly the 4K Joey was to be available by mid-month and someone alluded to the fact that the 4K Hopper would be at the same time, so if that's the case, they could be on the way to some and already delivered to others.They are bound to have some somewhere, with an imminent release set by end of the month.
If that where the case then it should also list support HDMI 1.xNeither the H3 or 4K Joey actually requires a 4K TV. Both will work fine on regular HDTVs.
Isn't HDMI backwards-compatible ?as the spec don't show any listing for HDMI 1.x
Wrongthe new Dish Hopper 4k along with Joey 4k you need all new a TV or Monitor that support 4k
See first answerand has to have HDMI 2.x port
Take that up with the channel providers, not Dish.premium channels will req HDPC 2.2 support in order for them to work.
No not alway 100% backwards-compatible as problem could be TV firmware that it keep from working rigth.Isn't HDMI backwards-compatible ?
Guest what all the channel providers start doing, on the non premium channelTake that up with the channel providers, not Dish.
Limited time offer
