Now you need an internet service that will get you that 25 mbps (or higher) that you require to stream 4K. If that service is not available in your area, then you upgraded your Netflix plan for nothing. It sounds like you are upgrading your hardware before the local infrastructure can support it.i upgraded to netflix 4k stream plan.
I have had little to no trouble streaming in 4k with 18mbps uverse. It will usually "ramp up", with about 30 seconds of 720 or 1080, then go to 4k and hold it until the show is over.Now you need an internet service that will get you that 25 mbps (or higher) that you require to stream 4K. If that service is not available in your area, then you upgraded your Netflix plan for nothing. It sounds like you are upgrading your hardware before the local infrastructure can support it.
But how do you know you are getting Full Res 4K on a consistent basis?I have had little to no trouble streaming in 4k with 18mbps uverse. It will usually "ramp up", with about 30 seconds of 720 or 1080, then go to 4k and hold it until the show is over.
Personally, I can see the difference when it changes, but with my tvs built in netflix app, you can see the res at any given time with the push of a button. Ive checked.But how do you know you are getting Full Res 4K on a consistent basis?
What button is this that tells you the "live" resolution ?Personally, I can see the difference when it changes, but with my tvs built in netflix app, you can see the res at any given time with the push of a button. Ive checked.
I would have to look, and it may only do it on built in apps, on a STB it will just tell you whatever the box is outputting. With streaming with the apps, you can watch it change from 720p to 1080p, to 2160p in real time.What button is this that tells you the "live" resolution ?
On my Samsung 4K its the info button.What button is this that tells you the "live" resolution ?
On my 4K Vizio while watching Netflix I can press the Info or the display mode button and it will give the live resolution speed. While watching Amazon the display mode gives the resolution but not the Info button. Strange.What button is this that tells you the "live" resolution ?
Thanks, now I know how to find the 4k on Amazon.Info button on my LG too. Took me forever to figure out how to access the 4k stuff on Amazon Prime. I was getting annoyed I couldn't get anything but 1080p with a 100M connection on Man in the High Castle. I just happened to look at thread on AVS on 4k titles and it had the info to scroll all the way to the bottom of the categories in the Amazon app and UHD titles appear there, but not in the individual show categories.
On my Panasonic TC-P60ZT60 it is also the Info button.What button is this that tells you the "live" resolution ?
Limited time offer
