The scales on each side of the dish correspond to the way the dish is assembled. Assemble with one set of bolt holes and the low elevation scale is used. Assemble with the other set of bolt holes and the high elevation scale is used.
HUH?You're talking about the motor, I'm talking about the adjustments on the dish.
HUH?
Your dish looks to be adjusted close to where it should be I think... but your elevation on the motor looks to be a bit high but I am not used to seeing dishes at your latitude..
The motor bracket should be set to your latitude or elevation, depending which of the markings you are using. Elevation would be 90 - your latitude. So if your latitude is 34.4N, your elevation should be 55.6. I usually set this elevation/latitude scale on the motor, then set up the dish elevation adjustment to find the actual satellite. You may have to send your motor to a satellite via USALS if you don't have a satellite real close to 180deg from you to do the adjustment.
Of course the pole the motor is mounted to must be perfectly plumb when the dish/motor assembly is mounted to it for the angles to be accurate.
Get it working yet?
42 north latitude would be 48 degrees elevation of course... SHould easily find programming on 103W to aim for.
What frequency/polarity/symbol rate are the transponders that are locking? Maybe getting a false positive reading from another satellite?
Set to scan all channels and not only FTA?
OK, Kaffeine is a pain in this area. You have to have the transponders that it scans in the "scanfile.dvb" file and it is a plain text tile and you will get the required format from what is already there.
It is found here: ~/.kde/share/apps/kaffeine
If you are setting up and making sure of the arc track, I would do my south sat and the farthest east and west ones, then sort the rest out later. Lyngsat and sathint will help you get the needed info together.
Limited time offer
