10/28/2015 12:29 - Uplink Report - 13 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 10/28/2015 12:29 - 13 Changes
Uplink Comparison Range: 10/28/2015 12:23 - 10/28/2015 12:29 (PST)
Channel Additions:
7579(27) - KCWV [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 28 (Mkt: Duluth,MN (MN-IND))(NA)(H)
9535 - ALJAM [MPEG4 HD] added to Nimiq5 72.7W TP 30 ConUS (ALJAM)(NA)(H)
9535 - ALJAM [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS (ALJAM)(NA)(H)
Tier Changed:
164 - FUSE [MPEG2 SD] EchoStar14 119W TP 13 ConUS changed to Free Preview (Fuse)(A)(FP)
164 - FUSE [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS changed to Free Preview (Fuse)(A)(FP)
243 - FM [MPEG4 SD] Echostar16 61.5W TP 12 Conus changed to Free Preview (FM)(A)(FP)
243 - FM [MPEG2 SD] EchoStar14 119W TP 10 ConUS changed to Free Preview (FM)(A)(FP)
7337(62) - WDSI [MPEG4 SD] Echostar16 61.5W TP 21 Spotbeam 59 changed to Available (Mkt: Chattanooga,TN (TN-FOX))(A)(H)
7337(62) - WDSI [MPEG2 SD] EchoStar10 110W TP 27 Spotbeam 10 changed to Available (Mkt: Chattanooga,TN (TN-FOX))(A)(H)
9589(164) - FUSE [MPEG4 HD] Nimiq5 72.7W TP 04 ConUS changed to Free Preview (Fuse)(A)(FP)
9589(164) - FUSE [MPEG4 HD] Ciel-2 129W TP 19 ConUS changed to Free Preview (Fuse)(A)(FP)
Name Changed:
5153(61) - WDSI [MPEG4 HD] Echostar16 61.5W TP 24 Spotbeam 09 renamed to WTVC2 (Mkt: Chattanooga,TN)(A)(H)
7333(61) - WDSI [MPEG2 SD] EchoStar10 110W TP 27 Spotbeam 10 renamed to WTVC2 (WTVC2)(Mkt: Chattanooga,TN)(A)(H)
Transponder Changes:
Ciel-2 129W TP 29 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 30 ConUS (21.500 8PSK 2/3) added.
EchoStar10 110W TP 12 Spotbeam 28 (20.000 QPSK 5/6) added.
Channels in the system: 9790
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
A little chasing the tail. It isn't much watched but they have said one of the things they need to do is be seen in HD to gain viewers. But with limited viewers and limited bandwidth getting it in HD has not been easy. But if it is in HD they might gain viewers, but with low viewership ..... you get the idea....
If people really cared about what was on the channel they wouldn't care if it was in SD or HD.
That's just silly!
To a point I agree. But two problems, there are alternatives to Al Jazeera particularly since they switched from the much more popular international version to the current one in the U.S. It's channels with programming only seen on it that can get people to watch in SD if compelling enough.
Second some SD is better than others. Watching EuroNews as an example in SD is no problem, picture is not bad.
If someone really likes AlJazeera they could just listen I suppose even if the picture is bad.
Reactions: Jim S. and Troch77
It's a perfectly good alternative when the other channels tend to settle on one story a day, usually a political horse race story, and then debate it or spin it to death. AJA at least covers multiple stories over the course of a broadcast in a way that goes beyond having two people sit at a desk reading boilerplate rhetoric over and over.
On top of that they have reporters out in the field covering stories that aren't being covered on the others and it's nice to have those reports in high definition as long as they're going to the trouble and expense to make them.
11/04/2015 05:51 - Uplink Report - 8 Changes
11/09/2015 03:15 - Uplink Report - 2 Changes
