yep. but the tech said the dish pole won't work because the LOS was poor. i told him i'd pay for the pole and wiring and he is installing now.What did you have with Dish? Pole mount?
pole mount and 80 feet of wiring he saidFor JUST the pole mount .... ?
I'd pass, but thats just me.
Thats almost a dollar a foot + 75 for the pole ....pole mount and 80 feet of wiring he said
Yes he is burying itThats almost a dollar a foot + 75 for the pole ....
Hopefully it's BURIED coax and he's trenching it.
that myth has been busted many, many times!for a pole and bury that far, its approx right. usually the bury charge doesnt include the first 20 ft, so he is probably a subcontractor. make sure he changes out the wall barrel connectors before he leaves, if they are white/grey/clear they are much more prone to failure!
Really, care to explain ?that myth has been busted many, many times!
Sure. Directv has been saying for the longest that the clear barrels don't pass sat frequencies, but those in the know with the right equipment and tools had performed various test and found out there is really no difference between the clear and blue insert F-81 connectorsReally, care to explain ?
These companies, (probably more than just D*) that are using the Blue ones, probably have a deal with the vendor.Sure. Directv has been saying for the longest that the clear barrels don't pass sat frequencies, but those in the know with the right equipment and tools had performed various test and found out there is really no difference between the clear and blue insert F-81 connectors
It's probably MonsterThese companies, (probably more than just D*) that are using the Blue ones, probably have a deal with the vendor.
I kinda doubt it ... Most major companies use the cheapest reasonably good equipment they can find.It's probably Monster![]()
Limited time offer
