Netflix goes to black on hopper. | SatelliteGuys.US
Red_dog
60
I have has and super Joey. Netflix works on the Joey, but not the hopper.
I have try the reboot, Chanel 370, the app, none of them work.
The hopper is hard wire to my network and Internet, pandora works and other apps.
So any ideas?
To give you an update, if all dish tech support.
They new of the problem, said I might be able to fix it if I do a factory reset.
I said, this in not a good option, then I was told that a fix should be out in 10 days.
I said I will wait, will let you know when fix
It is a known issue, and they're working on a fix. No timeline on it though.
This afternoon when I attempted to get Netflix tuned in for my daughter, the movies she watches most all were error messaged as unavailable try later. When I exited CH 370, I got a black screen and no sound. This happened on a number of channels I tried. The only fix was to reset the hopper. I called Dish as I had this happen for the past 3 weeks now. I was told they are aware of the problem and the engineers are working on a solution. The fix will be download to customers boxes when available. I should have checked here before contacting support.
This happened to me today for the first time. Froze up the Hopper and had to reboot. Worked ok after that. I do have the latest software.
Jay
This has happened to me twice in the past week. Hit Netflix through the menu button and screen went black. After about 2 minutes the Netflix logo finally appeared and everything work normally.
Upgrading From Hopper to Hopper W/Sling
