2 hoppers | Page 2 | SatelliteGuys.US
2 hoppers
If you were at bedroom hopper and wanted to record something at that hopper but all the tuners were recording other shows would have have to go to your living room and Set the recording or could you do it from the bedroom hopper without having to walk into living room ?
I was told by a dirt member that I couldn't have a super Joey with 2 hoppers. Is this true ? Not discounting what dirt said. Just wondering if there's a way around this.
DANG IT.
I just signed up with DISH last night (install on the 29th) moved from DTV.
What I ordered: (4 rooms)
(2 hoppers (Living Room and Master) and 2 Joeys (bedroom and rec room))
I have been reading forums all day looking for a flaw in the Hopper. I didn't find any until now. So you are telling me, If I record a show in the master (hopper) I won't be able to watch that show in the living room (other hopper)? That isn't good..the wife isn't going to like that. Genie is 1 up on that feature...DANG IT!!
So what about putting the 2 Joeys in the master and the living room? Can the joey see both Hoppers?
This might be a deal breaker for us. Are there any work arounds on this?
What about 1 hopper and 2 Super Joeys and 1 reg joey? then could you watch a show in ANY room? That would give me 6 tuners + PTAT tuner....right?
. . . So you are telling me, If I record a show in the master (hopper) I won't be able to watch that show in the living room (other hopper)?
Not to worry. Your two Hoppers will be on a single network -- unless you want the Hoppers isolated from each other.
You'll be able to access the recordings on each Hopper (from the other Hopper & your Joeys).
I have 3 Hoppers on a single network and the recordings on each are accessed from the DVR screen (see below). I just select one of the Hoppers from a drop-down menu and the DVR contents of that Hopper will appear:
BTW, that External Device 1 is a hard drive connected to the Hopper I'm using the remote on (Living Room 1). I also have a hard drive attached to the Master Bedroom Hopper, but to access that drive's contents I'd have to use the Master Bedroom remote. Long story short . . . on a single network you can view all the recordings on each Hopper, but not the recordings on all of the hard drives attached to these Hoppers.
Reactions: Troch77
DANG IT.
As stated you can watch recordings from the other Hopper, they are just separate lists. You can not have 2 Super Joeys, or 2 Hoppers with 1 Super Joey. what is nice about the 2 Hoppers is that when you are setting up a timer it will tell you if there may be a conflict, and ask if you want to schedule it on the other Hopper.
Ryan
If you accept the Netflix offer, Your Non sling loaded hopper will not have a Netflix app.
What I did, was Took my Sling loaded Hopper , put it in my master bedroom, and linked the 2 Joeys to its so they could all have the Netflix option for the kids.
And I just have the Hopper 2000 in the livingroom, and use my smart TV for netflix in there.
You'll get 13.5 months free if you are Grandfathered to the $7.99 Netflix plan
12 months on the $8.99 plan
And 9 months on the $11.99 4 stream plan.
Ryan
What's the 9 to 13.5 months free grandfathered plan? Used to have a desktop Netflix plan that I let lapse about a month ago.
Thanks,
Dave
If you were a Netflix subscriber before they increased the price you only pay $7.99 per month for 2 stream HD service.
New customers Pay $8.99.
The $11.99 plan is 4 Stream HD service.
Dish gives you a Promo code that Applies $108 credit to your Netflix account.
Is the promo code only for new Dish customers? If not, how do I get the code?
What would be better, I want to maximize how many shows I can record at once?
#1: 2 Hoppers and 2 reg joeys
#2: 1 Hopper, 1 Super Joey, and 1 reg Joey
What do you all think?
Ryan,
The general opinion on here is #1. You get 6 tuners vs. 5. Advantages are:
* One more tuner to either watch or record from
* Twice as much storage
* If one Hopper fails, you still have television at 3 locations until it's replaced instead of no television.
Some suggestions that might save you some worry:
* Only connect one Hopper and no Joeys to the Internet (either wired or wireless)
* Enable bridging on that one Hopper only
* If you enable PTAT, do it only on one Hopper and everyone can watch from there rather than tie up 2 tuners every night recording the same programs
* Don't worry about minor problems for the first 72 hours, such as apps that don't work
Note that #1 provides for 4 televisions and #2 only provides for 3 televisions. #1 will cost you about $10 more per month. If you have 4 televisions, #2 should have an additional Joey and the costs would be almost the same for both.
Dave
Reactions: Skytrooper
dimcmurr,
Your suggestions are good. Two Hoppers are smart especially in my case with 5 Hopper failures recently. No Hopper, no TV. I just had a rash of bad luck. Up til recently, things were good. A tech came out and all is normal now. Don't know why you suggested not connecting one Hopper to the internet though.
I was angry thru all my bad luck and contacted two other providers. Decided to stay with Dish. The Hopper spoiled me.
dimcmurr,
Connecting both Hoppers to the internet can cause all sorts of strange problems. I went through that a while back. With bridging enabled, only one connection is needed, so pick whichever one is most convenient. Your internet will travel over the Hopper's MOCA network.
I have both of my Hoppers on Internet thru the Hopper Internet Connector. I have zero problems. I did notice when the Tech was here last week, he disabled Bridging. I see no difference when it is enabled or disabled. Am I missing something?
Add Hopper
722k dvr hd
