DVDR to Genie | SatelliteGuys.US
DVDR to Genie
fightfan
SatelliteGuys Guru
128
2
Parts unknown
If I swap out my 2 DVDRs for a new genie and 3 genie boxes, can the installer transfer the shows from the 2 dvdrs to the new genie?
Thank you for the response.
If I have two dvrs in two beadrooms and get the genie in the living room will the rooms with the two older dvrs be able to access the shows on the genie? and vise versa? I do have the whole home sharing currently.
Sorry, no.
really? so let me get this straight... with the whole home connection the rooms with the dvrs will not be able to watch the recorded shows on the Genie? And the room with the genie won't be able to watch shows on the drv in the other rooms? If that's the case then directv is either lying to me or don't know this. I just got off the phone with the tech department and they said they will all be able to access each other.
The original question was about transferring shows from a DVR to a Genie, no you can't transfer a recording. If the question is can a Genie watch recordings from a WHDVR connected HR2X or visa versa then the answer is yes you can.
Reactions: Jimbo
I had two questions and you answered both. Thank you!
You can watch what the Genie system puts out, just as you can connect a second TV to watch duplicate programming.
But your DVR will not "control" the Genie or select a recording to watch. But you can set it up to feed your selection from Genie to DVR/TV.
Did that make any sense?
Yes, makes sense. Thank you!
Hopper vs Genie, Will I Be Sorry?
Disney Junior On demand
