Well, when you consider it is on a TALL tower and located in the highest point in lower Michigan, it should come in good......Or stick a paperclip up for an antenna, as channel 9 WWTV is about the easiest channel in the entire state to pick up.
I agree with you on the shorter distance. When VHF was being used, I could get Green Bay and most of the time Milwaukee from the other side of Lake Michigan. Now I can only pick them up when the atmosphere is having a "fit."Yes it is but with the transition to digital the signal distance is cut way down. They have added to auxiliary transmitters one in Traverse City and the other one near Gaylord. I have in the past talked to their chief engineer. He seems like a really good guy
Next time you talk with the 9 and 10 engineer, ask him why the do not transmit sound in 5.1 format. Almost all stations when 5.1 sound is being sent, my high quality receiver indicator shows that sound type. It only shows pro-logic from 9 and 10. Very odd since that was something CBS had for a long time in their ads for HD TV.
WWTV is off the air due to a power outage at the transmitter/studio
You should have seen the storm that went through here! The middle of Michigan got POUNDED with baseball sized hail, high winds, and thunderstorms. I live just South of that area, and the storm finally hit us around 7pm. We had winds over 30mph all day, and they suddenly STOPPED like flipping a switch. We were right in the eye of the hunderstorm, and all the wind got sucked out.
It finally passed through after a couple hours and we didn't lose power, (miracle) but the whole middle of Michigan (Houghton Lake belt area, just North of us) below Traverse City got wasted all the way across to East Tawas. Most are still without power, and probably won't get it back for a few days.
Here's Consumers outage map. You can zoom in and see: https://www.consumersenergy.com/outagemap
Limited time offer
