4/15/2015 12:44 - Uplink Report - 46 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 4/15/2015 12:44 - 46 Changes
Uplink Comparison Range: 4/15/2015 12:38 - 4/15/2015 12:44 (PST)
Channel Additions:
4212(215) - WNE [MPEG4 HD] added to Echostar16 61.5W TP 10 Conus (WNE)(NA)(H)
4212(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
4213 - WN [MPEG4 HD] added to Nimiq5 72.7W TP 23 ConUS (WN)(NA)(H)
4213 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
4352 - WN [MPEG4 HD] added to Nimiq5 72.7W TP 23 ConUS (WN)(NA)(H)
4352 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
4353(215) - WNE [MPEG4 HD] added to Echostar16 61.5W TP 10 Conus (WNE)(NA)(H)
4353(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
4476 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
4477(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
4711 - WN [MPEG4 SD] added to Echostar16 61.5W TP 03 Conus (WN)(NA)(H)
4711 - WN [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (WN)(NA)(H)
4712 - WN [MPEG4 HD] added to Nimiq5 72.7W TP 23 ConUS (WN)(NA)(H)
4712 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
4751 - WNE [MPEG4 SD] added to Echostar16 61.5W TP 03 Conus (WNE)(NA)(H)
4751 - WNE [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (WNE)(NA)(H)
4752 - WNE [MPEG4 HD] added to Echostar16 61.5W TP 10 Conus (WNE)(NA)(H)
4752 - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
4946 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
4947(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
5051 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
5052(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
5369 - WN [MPEG4 HD] added to Nimiq5 72.7W TP 23 ConUS (WN)(NA)(H)
5369 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
5370(215) - WNE [MPEG4 HD] added to Echostar16 61.5W TP 10 Conus (WNE)(NA)(H)
5370(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
5542 - WN [MPEG4 HD] added to Nimiq5 72.7W TP 23 ConUS (WN)(NA)(H)
5542 - WN [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS (WN)(NA)(H)
5550(215) - WNE [MPEG4 HD] added to Echostar16 61.5W TP 10 Conus (WNE)(NA)(H)
5550(215) - WNE [MPEG4 HD] added to EchoStar11 110W TP 22 ConUS (WNE)(NA)(H)
Channel Removals:
245 - ARTS [MPEG4 SD] (A) removed from Echostar16 61.5W TP 12 Conus (Classic Arts Showcase)
245 - ARTS [MPEG2 SD] (A) removed from EchoStar11 110W TP 01 ConUS (Classic Arts Showcase)
4576 - ARTS [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 12 Conus (Classic Arts Showcase)
4576 - ARTS [MPEG2 SD] (A)(H) removed from EchoStar11 110W TP 01 ConUS (Classic Arts Showcase)
MAP Changed:
9602 - WNELM [MPEG4 HD] Echostar16 61.5W TP 10 Conus renamed to WNE , map (215) added (WNE)(NA)(H)
9602 - WNELM [MPEG4 HD] EchoStar11 110W TP 22 ConUS renamed to WNE , map (215) added (WNE)(NA)(H)
Tier Changed:
242 - TRU [MPEG4 SD] Echostar16 61.5W TP 09 Conus changed to Free Preview (truTV)(A)(FP)
242 - TRU [MPEG4 SD] Quetzsat1 77W TP 11 ConUS changed to Free Preview (truTV)(A)(FP)
242 - TRU [MPEG2 SD] EchoStar14 119W TP 10 ConUS changed to Free Preview (truTV)(A)(FP)
844 - TVDOM [MPEG2 SD] EchoStar10 110W TP 29 Spotbeam 49 changed to Available (TVDOM)(A)(H)
6331(44) - KXLA [MPEG4 HD] Ciel-2 129W TP 11 Spotbeam 33 changed to Available (Mkt: Los Angeles,CA (CA-IND))(A)(H)
6332(31) - KVMD [MPEG4 HD] Ciel-2 129W TP 11 Spotbeam 33 changed to Available (Mkt: Los Angeles,CA (CA-IND))(A)(H)
7309(39) - KABE [MPEG2 SD] EchoStar10 110W TP 25 Spotbeam 42 changed to Available (KABE)(Mkt: Bakersfield,CA)(A)(H)
7744(15) - KPIF [MPEG2 SD] EchoStar10 110W TP 29 Spotbeam 37 changed to Available (Mkt: Idaho Falls,ID (ID-RTN))(A)(H)
Name Changed:
215 - WNELM [MPEG4 SD] Echostar16 61.5W TP 03 Conus renamed to WNE (WNE)(NA)(H)
215 - WNELM [MPEG2 SD] EchoStar14 119W TP 15 ConUS renamed to WNE (WNE)(NA)(H)
Transponder Changes:
EchoStar11 110W TP 19 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 23 ConUS (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 12 Conus (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 01 ConUS (20.000 QPSK 7/8) removed.
Channels in the system: 9712
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
here comes weathernation all they need to do is to turn it on?i thought there was suppose to be another weathernation hd channel coming also.dish need to put WN HD on 213 right under the weather channel.
looks like they put it on 215 they will probaley put the app on 215 also like they do with the other apps.
So, does it still look like 2 WN channels are coming along with the App? Wonder why WNELM changed to WNE?
Forgive me but is the 20th still rumored?
according to scott he told me that it will be the 20th when it will turned that is the rumor what i heard from here what i know there are suppose to be two weathernation hd channels and a app also.
4/13/2015 23:45 - Uplink Report - 24 Changes
4/16/2015 21:50 - Uplink Report - 4 Changes
