need help sourcing parts | SatelliteGuys.US
talkdty
36
2
clover, sc
I posted some pics in "show your set-ups."
accounting for the bowl, I estimate it is a 7.5' diam.
3-piece
I'm looking for a "polar" mount and three LNB mounting legs.
any help or recycled parts welcomed. will pay fair money.
thank you
Dish looks to be in decent shape. If nobody offers parts here you could try Skyvision. They have an assortment of miscellaneous parts listed online. If they don't have a specific part you need you may be able to adapt something they have. They list three pages of parts but you might want to call and see if they have something that isn't shown online. Good Luck! First page here: http://www.skyvision.com/pages/parts1.html :)
Many have fashioned them from electrical conduit.
The 'thing' to consider is the focal length. You'll have to measure your dish and calculate it. Some 'fine' adjustment to this length is probably required to optimize it as calculations aren't perfect.
thanks much, for some reason I thought skyvision was defunct but someone did answer the phone after two or three mins on hold. Apparently this size dish with three LNB support rods is an oddity. I do have the center medallion somewhere around here. I seem to remember some letters or a flag or something in the center, will post after digging it out...thanks for the leads
It's a SAMI USA
will do, but that proves only that they have a Website........ its hard to trust these days - being burned twice in similar [old website/no product] scenarios. was hoping for a recent success story.
Could not find any info for Dave's on the Better Business Bureau website and no hit on a reverse search of the phone number either. Here is the link for the Ozark, Arkansas Chamber of Commerce. They are less than 15 miles from Mulberry, Arkansas (where this business is supposed to be located). Try giving them a call or email and see if they know anthing about Dave's or could possibly give you contact info for Mulberry, Arkansas CoC. http://www.ozarkchamberofcommerce.com
I figured this was going to be a custom rebuild job. ... just need to keep costs commensurate. ... so far I'm in for two bills for the polar rmount & actuator (tek2000) and still need. ..
ground mounting pole
Cement
Lnb
Lnb supports
Misc nuts bolts
Paul at skyvision was going to look around the warehouse to see what parts are left that MIGHT work.....haven't heard back yet...didn't try the other place yet
Some have taken to fabricating their own parts in a pinch. Hopefully they'll can find something you can use. :)
Cement
Lnb
Lnb supports
Misc nuts bolts
For 2 bills or less, you can probably find a used 10' with matching parts . In my area they are dwindling but I can still locate at least 5 that are not used. For the mounting pole you can probably pick one up at a scrap yard depending on how high you need to mount it.
adding transponder frequencies on a Coolsat 8000HD
103 Ion - No
