If it has any guide data at all, I believe it's fine on Dish's end. Occasional errors are likely either the station's mistake or Tribune's, I think....while WXIX 19.2 (Bounce) has the occasional error.
I agree. I think WXIX tries to insert local programs or infomercials from time to time then cancels them at the last second.If it has any guide data at all, I believe it's fine on Dish's end. Occasional errors are likely either the station's mistake or Tribune's, I think.
This isn't the purpose of this thread. Contact the station or Tribune to fix it and it will automagically be right on Dish.The very SAME error as described above also appears on my TiVo's (including subsequent correct length and block on the guide), so this looks to be a Tribune problem/fault or KCET, 28 is at fault, but not Dish or TiVo.
Not waning to thread to leave orignial purpose, but I must add that In the LA DMA there is an INconsistency with Dish providing EPG data for OTA's that does NOT fit the "only Dish carries" theory.If Dish does something -- and I'll emphasize if again -- is it safe to say they won't do anything for stations that they don't carry ? In the post I listed Dayton's locals, I didn't include "WKOI", which is a TBN affiliate, because Dish doesn't carry them. In a later post, @TNGTony did list them (for Dayton / Cincinnati).
I am not referring to channels like GRIT TV, MyTV, etc that are sub-channels under a "major" network that is carried by Dish.
Actually, my post is the purpose of this thread. This is a cut and past of Scott's post requesting information for this thread: "Please use this thread to report any guide issues you see on DISH here. Please be sure to include as much detail as possible in your report."This isn't the purpose of this thread. Contact the station or Tribune to fix it and it will automagically be right on Dish.
Chicago DMA
WWTO channel 35 OTA
35-1 TBN
35-02 the church channel
35-03 juice
35-04 enlace
35-05 soac
i talked to wwto and they said that all dish has to is too add the guide data for these channels
i sure appreciate it very much
No, they don't. Right now there are four channel 2's out of Delaware. They are currently transmitting incorrect guide data on all four channels. 2.1 and 2.2 show no data while 2.3 has the data for 2.1 and 2.4 shows the data for 2.2. Dish has no control over that. They can only retransmit what they receive. Do you seriously think they have a responsibility, or manpower, to spell check every single OTA channels guide info for the entire country?
Limited time offer
