Has anyone tried steaming 4:2:2 yet, besides FTA4PA.
Another great reason to own a Amiko Mini HD SE!![]()
Excellent!
Successful streaming and display of both MPEG2 and h.264 4:2:2?
Should make no difference if it's MPEG2 or H.264 as it's the PC that's doing all the decoding so it will work as long as the PC has the proper codecs installed and is powerful enough to handle the task.
This is nothing special as any STB which supports streaming the currently tuned channel over the network can do this.
Well, if it can stream Cozi and NBC's from 103 West then it's special! Your Mini-me couldn't do that last time I tried. I told you this before!
Excellent!
Just tried with the NBC MUX on 105W and have no issues using VLC full screen on a Dell Inspiron N5010 laptop using a wired 100 Meg connection.
However, I was not able to stream this channel properly using WiFi or on an older laptop. Keep in mind that the stream just gets passed on to your PC's media player unaltered so it has to be capable of handling a 20Mbps+ H.264 stream.
I've got 75/30 fibre op. and an I5 laptop. Go back and read my post. I'm not on 105. Your reply has nothing to do with 103, especially Cozi
Limited time offer
