OR, WA, ID, NV, CA. I was in VA last month and couldn't figure out why all the ODUs looked strange until I realized the tilt was almost completely opposite of what I usually do.
That said, OP, it would be ideal to get your zip code because the differences between the 101 and 119 can vary significantly depending on where you are. With that we can give you an accurate elevation, azimuth and tilt. Definitely sounds to me like you are on the 119.
Wasn't there for work but I was in the Manassas DMAI hope you weren't working in Manassas dma because that's a bad dma
Don't worry about 110, the signals are pointed towards Puerto Rico so they should be low. The rest of your numbers look good, but what about 99c and 103ca/cb?
Limited time offer
