GEOSATpro SL2PLL issue | SatelliteGuys.US
iBoston
2,663
2,233
North Central
I swapped out my Titanium SL1PLL and put this in. Since i did this, about every couple hours, all the sudden, ill start getting pixelization and then NO SIGNAL. If i go into the STB options and turn off the LNB power, and then turn it back on, the signal comes back.
Whats up with that? Anyone have explanation?
I just put the Titanium back in.
Hi, the SL1PLL is a geosatpro product unless your talking about the Titanium PLL1KS?
Sounds like a bad unit. I would contact satav or the reseller you bought it from :)
Reactions: iBoston
Questions For First Time FTA Install
