SWM16 outside? | SatelliteGuys.US
SWM16 outside?
ranmic
303
13
Sun, Sun and more Sun!!!!
Sorry if this has been asked before but is this supposed to be mounted outside?
I'd be a bit concerned about how some of the cables are angled. They should come straight out of the connector before turning.
Those cables are fine, as long as it's not a direct 90 they should be fine ...
Ranmic,
My SWM 16 is outside as well.
I just noticed that it gets pretty warm.
Reactions: ranmic
The way some of them exit the connector will eventually cause the cable loosen. There shouldn't ever be any pull on a connector.
You can stabilize the SWM-16 to the wall or surface with only 2 screws as shown in the picture? If that's true,it gives me a lot more options when I install mine.
Thanks to everyone for their input.
Also there was some slack in the lines so I don't have as much of a bend coming out of the SWM now.
It's pretty stable.
That's good to know,as soon as I get the cut to length coaxial cables,SWM 4-way splitter,& screws that I ordered,I'm installing the SWM-16(SL-3 4 cable LNB) I have now so I can reactivate my repaired HR23-700 to go with my HR24-200,HR24-500,& HR22-100 DVR's,& H25-500 & H24-700 receivers for 10 tuners total. Only having to use 2 screws really helps a lot.
DIRECTV Announces Second Quarter 2014 Results
DTV locals off 129 sat?
