I noticed I have National PBS. I do not want National PBS. How can I drop it? I went to my account online and it's not listed in an area where I can "uncheck" it.
Thanks....
PM a DIRT member or call DISH.I noticed I have National PBS. I do not want National PBS. How can I drop it? I went to my account online and it's not listed in an area where I can "uncheck" it.
Thanks....
That won't remove it from the OP bill.Go into the setup menu, channel locks, and LOCK the channel. If you have a lock code set on the Locks menu, it'll cause that channel to vanish and not show in the guide.
Nation PBS is a grandfathered channel from when DISH used to sell distant nets. If you had it you get to keep it unless you request its removal. Once removed you can never get it back.Are you even allowed to remove one channel from your programming package like that with Dish?
When you called Dish, they weren't able to remove it ?I noticed I have National PBS. I do not want National PBS. How can I drop it?
One can apparently make a number of changes including changing the base package (although there may be some issues in the case of a major downgrade or adding channels that require a hardware change).Are you even allowed to remove one channel from your programming package like that with Dish?
Limited time offer
