LNB arms | SatelliteGuys.US
LNB arms
GoWulfpack919
116
2
NC
Crazy question I know......but will the LNB arm from a DISH 500 fit onto a 1000.2 ?
I realize it won't be long enough but I'm more curious if the 4 holes in the 1000.2 reflector will match with those from the 500.
I can't answer your question but what are you trying to accomplish?
I want to build what schneid built in this thread....
http://www.satelliteguys.us/xen/threads/phase-iii-dish-sl3-lnb-camping-dish.283692/
I have several parts from various dishes. I have an old Dish500 arm, a SL3 LNB with Slimline arm to stack and I going to buy a 1000.2 reflector. I ask the original question because I wasn't sure if the Dish500 arm would match up to the four holes on the 1000.2 reflector. Per the link above I am going to stack the slimline arm so the length of the Dish500 arm is immaterial. I just want to four holes to match.
Wow... That's insane!
It makes for a smaller tailgating option that allows for both 99 and 103. I used the Phase III as many in that thread did but getting both 99 and 103 is a challenge for me for whatever reason. Therefore I want to go with this slightly larger option without buying a bunch of new parts.
Sound Issues with Hopper w/sling
Dish Pointing help and what Dish is this
