You mean you disconnected an external drive and the error still occurred? Or you disconnected the internal drive?I have a HR21-100 and getting this error message. I disconnected the Hard drive however still getting this error.
I don't care about the HD so is there anything I can do to fix this without buying a new hard drive
thanks
You definitely need a HD of some sort, internal or external in order to run the DVR ...I disconnected the internal Drive. This is a owned reciever.
So I have to have a hard drive in order for this to work.
I thought I just could remove the internal drive and be good.. they must have something written int he OS
It's a DVR. It won't work at all without the disk drive, it won't even boot up.I disconnected the internal Drive. This is a owned reciever.
IF you look for a EHD, make sure its an ESATA HDNo I have maybe I will dig one up. Thanks for the heads up I thought these could work with just removing the HD
yep it worked once I connected a internal drive. I was hopeing this would work without a HD.
I might have to sell this one to get one without a harddrive.
Limited time offer
