Looking for a satellite finder with Signal and Quality on LCD Screen | SatelliteGuys.US
enb141
267
7
Central America
Hi guys I'm looking for a digital satellite finder that has Signal Strength and Quality, if possible with DVB-S and DVB-S2, I looked around and I've found Lexium 6100Mini and I would like to know if that's the best option or there's something better without breaking my pockets.
Thanks.
Look for a sathero SH-200(self powered) or SH-100 needs to be in-line with receiver for power.
I've looked around for sathero SH-200 and it looks cool but unfortunately (correct me if I'm wrong) it only shows signal strength and no signal quality.
Q is relative. Every brand/model will show something different. Look closely and you'll notice it displays C/N ratio and BER. Carrier noise ratio and BER are not relative, they are real values. More valuable than "Q".
Thanks for that advice about C/N and BER but after looking for videos and other reviews of the Sathero SH-200 I've found that it needs a serial port in order to update the software and also the C/N and BER are just numbers and not meters like others.
I been looking at the super satbuddy meter. Sometimes you can find a used one a bit cheaper than a new one. What is the difference between the super satbuddy and hte super satbuddy 29?
I currently don't have a serial port on my PC so a mini USB to USB will work?
No you need a USB to serial as FaT showed above.
I have not used one with this meter(I have a serial port), but I have used the adapters for other things. I always have mixed results and hair pulling depending on what brand I use and what OS and computer, the device I am using is hooked up to.
Thanks.
What price range is not breaking the bank? Breaking the bank is kinda different for everyone, $20 for some, couple of hundred for others.
I myself have a First Strike FS1 meter and I really like it, but I don't think it's DVB-S2, I paid two something for it. Another thing to consider when buying a meter might be how rugged it is, if you're at all a clumsy clutz like I am, :eek: my meter has hit the ground way too many times, but it still works fine!
Cough cough could that because someone is using that windows 8 junk in the trunk lol
Ha nope I only tested one with Windows 8.1 and worked fine, last time I had issues was back in the XP days. I know you are joking around, but back then tons of people had issues, I think it was cause they were just hitting the market. Computers were starting to make the transition to no RS-232, but still tons of stuff with using it.
To me not breaking my pockets means no more than $180.00 - $200.00 top, I currently have the cheapest analog brandless sat finder and that I remember I never droped it so I basically care about something very usefull at roof without needing to go up and down a zillion times as I'm doing right now.
By the way I ended up buying the SATHERO SH-200, I was almost going to buy the Lexium 6100Mini or any similar clone but I hope I've made a good decision.
Thanks for your help guys.
I suffer from Cheap Bastard's disease. It prevents me from spending hundreds on a sat finder when I have a $30 openbox x3 and old $40 10" digital picture frame that plays composite video and does a great job at tuning a dish.
I was also considering using a USB DVB-S tunner and climbing with a laptop but it is too heavy and also I wanted something faster and less complicated to go to the roof.
You made the right choice if you have to climb on the roof. I am lucky that I have my dishes easily accessible at ground level. If I had to do that I'd want something a little more convenient also.
Criminal Minds and Frasier on KTV2
30'' prodlin dish
