Back in the day,here in the mountainous terrain of nc,there were lots of areas that had a few antennas atop the highest peaks,that served several homes.The antennas weren't on the homeowners property.Was that,or would that be considered illegal?
AFAIK, there was never anything illegal about master or community antennas.Back in the day,here in the mountainous terrain of nc,there were lots of areas that had a few antennas atop the highest peaks,that served several homes.The antennas weren't on the homeowners property.Was that,or would that be considered illegal?
You are leasing a house with an antenna, not paying someone else to rebroadcast a channel without the rights.
6) I contact a company that will rent me a space, put up an antenna, and the equivalent of a TiVo and Sling. They maintain it for as long as I pay them a fee. I can watch channels from that antenna anywhere I want. Is this okay?
If any of these are NOT okay, I'd like to know conceptually what the difference is.
This is where you run into trouble. In each of the scenarios you have physical control over the antenna and equipment as an individual. You may not in #6, depending on the arrangement. You may hire someone to do the work for you, but you as an individual can choose to do it all yourself.
With Aereo, they claim that that are renting you an antenna, but in reality you do not have property control over that antenna like you would if you leased the real estate and put up your own antenna.
If you were able to visit your cubic centimeter and adjust your antenna with Aereo, then perhaps it would really be fair use of your property.
There is a distinct difference. You as an individual receiving OTA signals have a statutory exemption from copyright laws to receive them free of charge. Cable and DBS as you know have statutory exemptions when they receive permission from the stations by either must carry or paying an agreed upon fee. Does Aereo acting on your behalf (which is what it pretty much boils down to) have that copyright exemption extended to them? I would bet that they will eventually lose that argument since you do not have any control of the system as an individual, so they are selling a service, not renting you a bunch of items.
Yes, you can. And, you can have a single OTA antenna atop an apt building, and have it feed all of the apartments. You can also have a tower-mounted community antenna feeding everybody in town.But can't you use an antenna at home and have it hooked to multiple tvs? Obviously an antenna at home recieves the entire spectrum, where as Aereo's setup only can allegedly get just one channel at a time.
You remind me of the guy I used to argue with about whether or not his tapping into the cable feed in his apartment was actually stealing, as the connection was there in his unit, and had signal. So, in his mind, it was not stealing.I disagree. Whether I put an antenna on my house or put it on the roof of my commercial building a few miles away and then run the signal through phone/data lines should not even be relevant.
Or if a tenant pays me to rent a second antenna and do the same, why is this?
Renting from Aereo is no different, in my opinion
So your distinction is whether I can visit my antenna or not and adjust it? I just don't see it that way. If I have an antenna problem on my roof I am calling a TV guy to crawl up there and deal with it. If my antenna is not working with Aereo then I am calling the tech support guy to adjust it.
You do forget one big thing in all of this - these channels broadcast over the airwaves and are free tv. This is simply a technological update to an existing model.
We used to have a knob on the tv to turn the channels. Then someone made a remote control. The basic function is just that - to turn the channel.
Clearly three justices in the 10th circuit ruled one way and the 2nd circuit felt differently.
Time will tell.
The whole matter must be sent back to the lower courts no matter what. This is about the injunction and is not in any way related to a ruling on the merits.we will find out if and when SCOTUS rules. Isay if because they send the whole matter back to the lower courts.
Tony the problem with your scenarios is that you are saying you can watch the channels anywhere. With Aereo this is not the case. You can only watch from within the dma. If you try logging in from outside the dma you are blocked.
I fully support Aereo.
That should be fine, then. But, why would one subscribe to that vs just doing it themselves at home?In Aereo's example, I lease a remote antenna and a remote storage device. I use my remote antenna to pull down broadcast signals that are free over the air signals. I use data lines to transmit the broadcasts to me and only me. I live in the same metro area as the broadcast.
Limited time offer
