5 fully integrated tuners with H/SJ vs 6 non integrated tuners for a 2H system. Non integrated meaning for live viewing and setting recordings from any location.
Edit: I was a little late.
I see it as a great upgrade for customers that currently have one Hopper and 2 or 3 Joeys in their setup and have a family of 3 or 4. These customers are sure to be having issues with timer conflicts and now all they'll have to do swap out a Joey with the Super Joey to add an extra 2 tuners for $3 more a month. I think it's a great deal for them.
For a customer like myself with 2 Hoppers and 2 Joeys I see no major benefit from it other than the integration.
This is how you would wire a 4 TV house with a Hopper, Super Joey and 2 Joeys.
It won't work via LAN only as the tuners come from the sat feed.
Full Integration would be the big thing if you consider that an advantage (for me, it will be...for others it may not.). One single repository for timers, recordings, conflict mgmt, etc. vs. having to split things manually across two Hoppers.
forgive my ignorance, but with 2 hoppers, isn't each able to view the other's recordings via a drop down box?
We were thinking swap an existing Joey for a Super - move to 1 Hopper, 1 Joey, 1 Super (believe it or not, we have timer conflicts with 1 Hopper and 2 Joeys). But I notice it says RG6 from integrator to Super Joey. I think the Joey requirement is RG59 - if we don't have any problems now, can we assume existing Joey cable will be ok for Super Joey?
But if I want to set a timer on the BR hopper while I'm in the LR I can't do it, I can't even see if the timer is already there - I can only see/watch what has been recorded. Now the Joey is a different thing, since I can switch between Hoppers & set timers on either. Just want the whole-home system to actually be whole-home, with timers available to be set/edited from anywhere which I would be able to do with a hopper/super joey system. Too bad that if I replace a hopper with a super joey I lose the $5 discount & it would cost me more than it does now - has that been confirmed, if anyone knows?
To my knowledge, Dish never said anything even semi-officially on Hopper integration. Originally, at Team Summit three years ago, nearly a year before release, it was metioned as intent, but anything that far ahead of release should be ignored.Is that also called "soon"? Been hearing it since I got 2 Hoppers quite a while ago, just like other rumors may never happen.
Limited time offer
